| 0002898 | Sketcher | Bug | public | 2017-02-11 12:02 | 2017-08-13 15:35 |
| Reporter | Victor | Assigned To | |||
| Platform | PC | OS | Linux | OS Version | Fedora 25 |
| Summary | 0002898: Unable to remove sketch vertex | ||||
| Description | I have a small 2D sketch in part design. On this sketch I have 2 vertices I want to delete. I can selected it, but when I hit delete-key, Freecad says "Not able to delete a constraint on point with given index : 43". The other point I can't select has index 46. I try to delete it using python console. I scan every vertice in my sketch ( len( obj.Shape.Vertexes ) == 12 ) I can not find the vertex I want to delete by position obj.Shape.Vertexes[i].X, obj.Shape.Vertexes[i].Y I try to repair my sketch using "Validate" menu item in "Sketcher" Freecad menu, but my vertex are still here and I still can't delete it... You can maybe add a repair option to remove points out the vertexes list ? | ||||
Correction in my above text : "I can NOT find the vertex I want to delete by position obj.Shape.Vertexes[i].X, obj.Shape.Vertexes[i].Y" |
Please open a forum thread to discuss the issue and then bidirectionally link thread <=> ticket Also:please post your Help > About FreeCAD > Copy to clipboard |
@Victor please follow up with 1) pasting your example file. 2) pasting your Help > About FreeCAD > Copy to clipboard 3) opening a forum thread to discuss the issue and then bidirectionally link thread <=> ticket |
Without the fcstd file that shows this issue, or a detailed clearly reproducible method, this report is utterly useless. |
@Victor I'm resolving this ticket. It will be closed unless you respond. |
Closing as no response from OP |
| 2017-02-11 12:02 | Victor | New Issue | |
| 2017-02-11 12:04 | Victor | Note Added: 0008272 | |
| 2017-02-13 14:21 | Kunda1 | Note Added: 0008282 | |
| 2017-02-13 14:22 | Kunda1 | Status | new => feedback |
| 2017-02-13 14:23 | Kunda1 | Note Edited: 0008282 | |
| 2017-03-14 11:47 | Kunda1 | Description Updated | |
| 2017-03-14 11:49 | Kunda1 | Note Added: 0008625 | |
| 2017-04-01 17:16 | normandc | Note Added: 0008744 | |
| 2017-04-28 16:42 | Kunda1 | Status | feedback => resolved |
| 2017-04-28 16:42 | Kunda1 | Resolution | open => unable to reproduce |
| 2017-04-28 16:42 | Kunda1 | Note Added: 0008810 | |
| 2017-08-13 15:35 | Kunda1 | Status | resolved => closed |
| 2017-08-13 15:35 | Kunda1 | Note Added: 0009908 |
