| 0002905 | Part | Feature | public | 2017-02-17 14:17 | 2021-02-06 06:46 |
| Reporter | easyw-fc | Assigned To | |||
| Priority | high | Severity | feature | Reproducibility | always |
| Summary | 0002905: cannot make a compound or a union or even a simple copy of the App::Part structure | ||||
| Description | for App::Part models in its structure I miss the option to: 1) make a compound 2) make a union 3) make a simple copy | ||||
| Steps To Reproduce | 1) in FC 0.17 create a new doc 2) go to Part Design Next 3) Make a Part 4) goto Part 5) create a Cube and a Cone 6) move Cube and Cone into Part container 7) select Part 8) try to make compound, make union or even make a single copy everything is disabled | ||||
| Additional Information | forum thread https://forum.freecad.org/viewtopic.php?f=22&t=20698&p=160405#p160384 | ||||
| Tags | 3D printing, App::Part, Part Design, simple copy, STEP, STL | ||||
An App::Part container is a universal object which can hold any kind of DocumentObject like meshs or Paths or even pictures. I can't work with Part tools (Booleans, Compound etc.) which work with Part::Features only and hence result in a undefined behavior. The App::Part object should not work with those tools. Current behavior is correct. |
To point 3: make a simple copy. I agree that the simple copy tool should handle App::Part objects, but this must involve creating a simple copy of all child DocumentObjects, as a DocumentObject is allowed to be only in a single local coordinate system (GeoFeatureGrouip, Which App::Part is). |
as for this forum post https://forum.freecad.org/viewtopic.php?f=22&t=21510 the option to make a simple copy of App::Part objects is becoming requested ... |
Is this 'General' or should I move it to 'Part' category? |
Changed from bug to feature |
@DeepSOIC do you mind weighing in? |
@easyw-fc do you mind updating this ticket illustrating it's status? Thanks! |
@Kunda1 an other user case where a single copy of App::Part and Body would be useful https://forum.freecad.org/viewtopic.php?f=3&t=24405&p=191408#p191408 |
@Kunda1 an other user case where this feature is required https://forum.freecad.org/viewtopic.php?f=28&t=21541#p195863 I suspect that the more people will use FC0.17 to elaborate STEP files, the more this issue will raise its relevance. Maurice |
bumping to higher priority |
@Kunda1 an other user case where this feature is required https://forum.freecad.org/viewtopic.php?f=3&t=26914 |
@wmayer may I make this an 0.18 target ? |
Just FYI, In Steps to reproduce, step 2 is no longer required. The Part container is now global and available in all workbenches within the Structure toolbar. |
and another user case https://forum.freecad.org/viewtopic.php?f=18&t=27537&p=229559#p229535 This is a function also useful for STL export and also for FEM meshing. |
This ticket has been migrated to GitHub as issue 5681. |
| 2017-02-17 14:17 | easyw-fc | New Issue | |
| 2017-02-17 14:17 | easyw-fc | Tag Attached: A | |
| 2017-02-17 14:19 | easyw-fc | Tag Detached: A | |
| 2017-02-17 14:20 | easyw-fc | Tag Attached: Part Design | |
| 2017-02-17 14:20 | easyw-fc | Tag Attached: App::Part | |
| 2017-02-17 14:31 | ickby | Note Added: 0008336 | |
| 2017-02-17 14:34 | ickby | Note Added: 0008337 | |
| 2017-02-17 14:44 | DeepSOIC | Priority | high => normal |
| 2017-03-23 22:34 | easyw-fc | Tag Attached: STEP | |
| 2017-03-25 16:00 | easyw-fc | Tag Attached: simple copy | |
| 2017-03-25 16:02 | easyw-fc | Note Added: 0008707 | |
| 2017-06-24 11:18 | Kunda1 | Note Added: 0009506 | |
| 2017-06-24 11:18 | Kunda1 | Category | Bug => Feature |
| 2017-06-24 11:18 | Kunda1 | Note Added: 0009507 | |
| 2017-06-24 11:20 | Kunda1 | Status | new => feedback |
| 2017-08-23 12:19 | Kunda1 | Note Added: 0010001 | |
| 2017-09-13 12:29 | Kunda1 | Note Added: 0010115 | |
| 2017-09-14 20:52 | easyw-fc | Note Added: 0010126 | |
| 2017-09-14 20:52 | easyw-fc | Status | feedback => new |
| 2017-09-14 20:54 | easyw-fc | Note Edited: 0010126 | |
| 2017-09-14 20:57 | easyw-fc | Note Edited: 0010126 | |
| 2017-10-20 21:44 | easyw-fc | Note Added: 0010334 | |
| 2017-10-20 23:10 | Kunda1 | Priority | normal => high |
| 2017-10-20 23:10 | Kunda1 | Note Added: 0010335 | |
| 2018-02-15 08:05 | easyw-fc | Note Added: 0010960 | |
| 2018-02-15 08:05 | easyw-fc | Tag Attached: STL | |
| 2018-02-15 08:05 | easyw-fc | Tag Attached: 3D printing | |
| 2018-02-15 12:10 | Kunda1 | Note Added: 0010961 | |
| 2018-02-15 12:11 | Kunda1 | Project | FreeCAD => Part |
| 2018-02-17 19:10 | normandc | Note Added: 0010962 | |
| 2018-02-17 19:13 | normandc | Note Edited: 0010962 | |
| 2018-04-23 13:16 | easyw-fc | Note Added: 0011181 | |
