0002927FreeCADBugpublic2021-02-06 06:50
Reporterian.rees Assigned Toian.rees
Status assignedResolutionopen
Target Version0.20
Summary0002927: Mac application bundler doesn't track library versions
DescriptionI've run in to an issue on my own machine, where the linker finds a newer version of a library than the one that ends up getting copied in to the application bundle. This causes the older library to not be loaded by dyld when the bundle is launched, which can cause a range of problems.
There are several (and, to me at least, some are non-obvious) places in the existing script that need to take library versions in to account. After mucking around with it script for a few hours to find the source of my problem, I'm thinking that it'll be best to re-write the part that creates the graph of dependencies.
(note to self: Local branch is 20170225-bundle-tool)
Other changes:
  * dir_filter in main() needs to be more Python version-agnostic
  * before calling otool, etc on libraries mentioned, the script should ensure that the library actually exists, and respond accordingly.
Tags#post-to-forum, macOS, packaging
Relationships
related to 0002906 closedian.rees Python API error: No module named PartDesign
2019-09-05 21:41
administrator   ~0013546
Dedicated forum thread: https://forum.freecad.org/viewtopic.php?f=8&t=39122
yorik
2022-03-03 13:55
administrator   ~0016518
This ticket has been migrated to GitHub as issue 5683.
2017-02-26 05:49 ian.rees New Issue
2017-02-26 05:49 ian.rees Status new => assigned
2017-02-26 05:49 ian.rees Assigned To => ian.rees
2017-02-26 05:51 ian.rees Description Updated
2017-03-13 15:20 Kunda1 Relationship added related to 0002906
2017-06-20 20:53 Kunda1 Tag Attached: MacOSX
2017-06-29 05:10 Kunda1 Tag Attached: packaging
2017-06-29 05:38 Kunda1 Tag Attached: #post-to-forum
2019-09-05 21:41 Kunda1 Note Added: 0013546
2020-11-13 14:08 Kunda1 Tag Renamed MacOSX => macOS
2021-02-06 06:50 abdullah Target Version => 0.20
