| 0002929 | TechDraw | Bug | public | 2017-02-27 21:23 | 2017-05-10 21:03 |
| Reporter | lambda | Assigned To | wandererfan | ||
| Summary | 0002929: GeomHatch doesn't draw lines from an absolute position | ||||
| Description | I have tried to write some patterns with dashed lines. However it seems TechDraw calculates the pattern from the border of the face instead of a fixed position, thus messing up the alignment of the individual lines if the border is not a straight line. See the attached screen shot for an example. The rectangle on the left side is ok, but in the circle on the right side the pattern is messed up. | ||||
| Tags | hatch | ||||
| related to | 0003015 | closed | wandererfan | TechDraw - Geometric Hatch PAT compatibility |
Please post your Help > About FreeCAD > Copy to clipboard Did you happen to ask on the forums before you posted to the tracker? |
No, I didn't post about this issue on the forum. Looks like a straight forward problem, not sure what I'd ask. OS: Debian GNU/Linux 8.0 (jessie) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.10237 (Git) Build type: Unknown Branch: master Hash: 64912a59cc7f11c6263c8cb47fc713da773aa9d1 Python version: 2.7.9 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.7.0 |
@wandererfan when you get a moment can you weigh in on this? |
@lambda is correct. The lines start out based on a fixed point, then get shifted to the face boundary in the conversion to Qt QGraphicsPathItems on the Gui side. There is a related problem with the deltaX part of the PAT specification too. No ETA on a fix yet, sorry. |
should be fixed by commit 7628089. |
FreeCAD master 76280891 |
Thanks wandererfan! @lambda please test and reopen if issue persists. |
FreeCAD: master 76280891 2017-03-28 01:10:33 WandererFan Committer: wmayer Details Diff |
DrawGeomHatch improvements -draw & align dash patterns correctly on all QPainters using QGPathItem -Allow patterns to start with space -ensure horiz & vert lines pass through pattern origin -Scalable complex patterns |
Affected Issues 0002929, 0003015 |
| mod - src/Mod/TechDraw/App/DrawGeomHatch.cpp | Diff File | ||
| mod - src/Mod/TechDraw/App/HatchLine.cpp | Diff File | ||
| mod - src/Mod/TechDraw/App/HatchLine.h | Diff File | ||
| mod - src/Mod/TechDraw/Gui/QGIFace.cpp | Diff File | ||
| mod - src/Mod/TechDraw/Gui/QGIFace.h | Diff File | ||
| 2017-02-27 21:23 | lambda | New Issue | |
| 2017-02-27 21:23 | lambda | File Added: hatch-1.png | |
| 2017-02-28 01:00 | Kunda1 | Note Added: 0008470 | |
| 2017-02-28 11:52 | lambda | Note Added: 0008472 | |
| 2017-02-28 19:47 | Kunda1 | Note Added: 0008478 | |
| 2017-02-28 20:12 | Kunda1 | Summary | GeomHatch doesn't draw lines from an absolute possition => GeomHatch doesn't draw lines from an absolute position |
| 2017-03-04 16:52 | wandererfan | Assigned To | => wandererfan |
| 2017-03-04 16:52 | wandererfan | Status | new => confirmed |
| 2017-03-04 16:52 | wandererfan | Target Version | => 0.17 |
| 2017-03-04 16:52 | wandererfan | Note Added: 0008541 | |
| 2017-05-09 19:29 | Kunda1 | Relationship added | related to 0003015 |
| 2017-05-10 01:32 | Kunda1 | Tag Attached: hatch | |
| 2017-05-10 17:53 | wandererfan | Note Added: 0008941 | |
| 2017-05-10 18:23 | Kunda1 | Note Added: 0008942 | |
| 2017-05-10 18:23 | Kunda1 | Changeset attached | => FreeCAD master 76280891 |
| 2017-05-10 18:24 | Kunda1 | Status | confirmed => resolved |
| 2017-05-10 18:24 | Kunda1 | Resolution | open => fixed |
| 2017-05-10 18:24 | Kunda1 | Fixed in Version | => 0.17 |
| 2017-05-10 21:03 | Kunda1 | Status | resolved => closed |
| 2017-05-10 21:03 | Kunda1 | Note Added: 0008947 |
