| 0002936 | Sketcher | Bug | public | 2017-03-02 00:55 | 2017-12-12 22:36 |
| Reporter | digitalgoose | Assigned To | abdullah | ||
| Platform | 64 bit | OS | Windows 10 | ||
| Summary | 0002936: Merge Sketch Flattens Spreadsheet Functions to Values | ||||
| Description | I have started making parametric models by referencing global variables contained in a spreadsheet from the Spreadsheet workbench. If I build two sketches using the Part Design workbench and parameters from a spreadsheet, everything works well. If I then combine the two sketches using Part Design > Merge Sketches, the parametric relations are replaced with hard-coded values. | ||||
| Tags | Part Design, sketcher, spreadsheet | ||||
On further inspection, a further issue emerged. One of the two merged sketches now references distance from a vertex on the other sketch, whereas before it had referenced distance from the origin... |
@digitalgoose Please provide a FreeCAD file showing the issue. It will save time for developers and testers. Thanks. |
@bejant do you mind trying to reproduce this issue? |
I can recreate the issue that after merging two Sketches (Sketch and Sketch001 in the attached file), Distance Constraints in the resulting Sketch (Sketch002) have lost their Function link to the Spreadsheet. I couldn't recreate the issue noted 2017-03-02 of Constraints in the Merged Sketch referencing different vertices. I used Sketcher and Spreadsheet WBs only and no PDN. OS: Ubuntu 16.04.2 LTS Word size of OS: 32-bit Word size of FreeCAD: 32-bit Version: 0.17.11379 (Git) Build type: None Branch: master Hash: 654276c49d1b66cf3c2a5ec538629c6d9f77c489 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 |
@eivindkvedalen care to weigh in? |
@Kunda1 https://github.com/FreeCAD/FreeCAD/pull/1159 |
| 2017-03-02 00:55 | digitalgoose | New Issue | |
| 2017-03-02 00:55 | digitalgoose | Tag Attached: Part Design | |
| 2017-03-02 00:55 | digitalgoose | Tag Attached: sketcher | |
| 2017-03-02 01:02 | digitalgoose | Note Added: 0008486 | |
| 2017-06-18 00:01 | normandc | Project | PartDesign => Sketcher |
| 2017-06-18 00:03 | normandc | Note Added: 0009434 | |
| 2017-06-18 00:04 | normandc | Note Edited: 0009434 | |
| 2017-06-21 10:46 | Kunda1 | Note Added: 0009478 | |
| 2017-06-21 10:47 | Kunda1 | Status | new => feedback |
| 2017-06-22 04:36 | bejant | File Added: Bug2936-017.fcstd | |
| 2017-06-22 04:36 | bejant | Note Added: 0009489 | |
| 2017-06-22 10:59 | Kunda1 | Tag Attached: spreadsheet | |
| 2017-07-03 21:16 | Kunda1 | Tag Attached: #post-to-forum | |
| 2017-10-17 11:48 | Kunda1 | Note Added: 0010310 | |
| 2017-10-17 11:49 | Kunda1 | Status | feedback => confirmed |
| 2017-10-17 11:50 | Kunda1 | Summary | Merge Sketch Flattens Functions to Values => Merge Sketch Flattens Spreadsheet Functions to Values |
| 2017-12-12 14:36 | abdullah | Note Added: 0010584 | |
| 2017-12-12 14:36 | abdullah | Assigned To | => abdullah |
| 2017-12-12 14:36 | abdullah | Status | confirmed => assigned |
| 2017-12-12 15:48 | Kunda1 | Tag Detached: #post-to-forum | |
| 2017-12-12 22:36 | wmayer | Status | assigned => closed |
| 2017-12-12 22:36 | wmayer | Resolution | open => fixed |
| 2017-12-12 22:36 | wmayer | Fixed in Version | => 0.17 |
