| 0002943 | PartDesign | Bug | public | 2017-03-05 23:34 | 2017-03-21 23:08 |
| Reporter | wynn | Assigned To | kkremitzki | ||
| Summary | 0002943: Unable to pocket multiple holes on third level sketch | ||||
| Description | A hole radial pattern about the origin. Select pocket command through all symetrical to plane OK Input error: Failed to validate broken face. | ||||
@wynn Thanks for the report. Some feedback: 1) please post your Help > About FreeCAD > Copy to clipboad so the devs are informed you're working on the latest 0.17 2) better to post to a forum thread first to get community attention and afterwards post a ticket to the tracker. Sometimes issues are solved before they need a ticket. 3) bi-directionally link ticket <=> thread for ideal documentation and following the progress of the bug. |
Your sketch is invalid because you are using real and not construction geometry. |
This is why it's important to use the forums before opening a ticket on the tracker. This is user error as per @kkremitzki. Resolving ticket. |
| 2017-03-05 23:34 | wynn | New Issue | |
| 2017-03-05 23:34 | wynn | File Added: FailedToPocektBrokenFace.fcstd | |
| 2017-03-05 23:47 | Kunda1 | Note Added: 0008544 | |
| 2017-03-09 22:30 | kkremitzki | File Added: FailedToPocektBrokenFace (1).fcstd | |
| 2017-03-09 22:30 | kkremitzki | Note Added: 0008594 | |
| 2017-03-09 23:38 | Kunda1 | Status | new => resolved |
| 2017-03-09 23:38 | Kunda1 | Resolution | open => no change required |
| 2017-03-09 23:38 | Kunda1 | Note Added: 0008596 | |
| 2017-03-21 23:08 | kkremitzki | Assigned To | => kkremitzki |
| 2017-03-21 23:08 | kkremitzki | Status | resolved => closed |
