| 0002965 | FEM | Feature | public | 2017-03-14 12:59 | 2017-06-08 12:37 |
| Reporter | HoWil | Assigned To | berndhahnebach | ||
| Priority | low | Severity | feature | Reproducibility | always |
| Summary | 0002965: FEM - GUI, removing warning when creating a mesh from boolean fragments | ||||
| Description | There is a warning :!: displayed when meshing boolean-fragments basically saying that problems can arise when meshing a component. The thing is, that a boolean-fragments should by definition make no problems for meshing. There can't be any intersecting solids and therfore gmsh should always produce a nice result. I use boolean fragments together with gmsh mesh in Fc on a daily basis and always clicking this warning is annoying :?. I see three possibilities for implementing something against the above : * inserting a check on the content of the boolean-fragments compound before the warning is risen * insert a setting in the preferences to deselect for such warnings * insert a checkbox at the warning to never show it again This is for sure of low priority, since until now not so many use fc to create multi-body meshes. But I am sure that the numbers will rise at the latest when Openfoam and elmer are integrated. | ||||
| Tags | FEM, Mesh | ||||
The related discussion in the forum is https://forum.freecadweb.org/viewtopic.php?f=18&t=21314 Bernd asked to assign this task to him, looks like I do not have the rights to do that. |
we really need to get rid of this popup. The BooleanFragments generate very cool topology for meshing, but they are Compounds ( https://forum.freecadweb.org/viewtopic.php?f=8&t=22531&start=20#p175909 and following). Furthermore there need to be some changes at the warnings in GMSH mesh class. I will go for that hopefully soon. Bernd |
fixed with https://github.com/FreeCAD/FreeCAD/commit/20b4865061426ff7119a01e9f08ec936612c14d4 |
| 2017-03-14 12:59 | HoWil | New Issue | |
| 2017-03-14 12:59 | HoWil | Tag Attached: FEM | |
| 2017-03-14 12:59 | HoWil | Tag Attached: Mesh | |
| 2017-03-14 13:14 | HoWil | Note Added: 0008628 | |
| 2017-03-14 14:48 | berndhahnebach | Assigned To | => berndhahnebach |
| 2017-03-14 14:48 | berndhahnebach | Status | new => assigned |
| 2017-03-14 14:48 | berndhahnebach | Description Updated | |
| 2017-03-14 19:18 | Kunda1 | Note View State: 0008628: public | |
| 2017-05-08 06:07 | Kunda1 | Relationship added | related to 0003021 |
| 2017-05-28 21:49 | berndhahnebach | Note Added: 0009179 | |
| 2017-05-28 21:50 | berndhahnebach | Note Edited: 0009179 | |
| 2017-05-28 21:55 | berndhahnebach | Summary | removing warning when creating a mesh from boolean fragments => FEM - GUI, removing warning when creating a mesh from boolean fragments |
| 2017-06-08 04:48 | berndhahnebach | Note Added: 0009311 | |
| 2017-06-08 04:50 | berndhahnebach | Status | assigned => closed |
| 2017-06-08 04:50 | berndhahnebach | Resolution | open => fixed |
| 2017-06-08 12:37 | Kunda1 | Fixed in Version | => 0.17 |
