| 0002967 | TechDraw | Feature | public | 2017-03-15 12:59 | 2017-11-25 15:04 |
| Reporter | HoWil | Assigned To | wandererfan | ||
| Summary | 0002967: Automatically opening of drawing - switch needed | ||||
| Description | When opening a .fcstd file including a (techdraw-) drawing also the drawing is opened automatically. This is somehow annoying for my ? .. I do not always need the drawing at startup and have to close it than. Is it possible to insert a switch in the preferences so drawings (similar to the spreadsheets) are not opened automatically ? Discussion in Forum see https://forum.freecadweb.org/viewtopic.php?f=10&t=21315#p165291 | ||||
| Tags | drawing, TechDraw | ||||
@wandererfan do you mind weighing in? |
@HoWil: is the problem having the tabs open, or the delay while the features are computed? I assume it is the delay, but the fixes are different, so I just want to be sure. |
It is a problem that the drawing opens automatically even if it was closed when saving the document. So yes it the point 'having the tabs open'. |
I don't think the FCSTD file remembers what tabs were open at save/close time, but I'll look into it. |
Fix by wandererfan in FreeCAD Pull Request 977 |
https://github.com/FreeCAD/FreeCAD/commit/b68b7badca17cad635609076af1ddb19a292ce30 |
I cannot confirm that this feature is implemented. When opening a project with a techdraw drawing it is still displayed after project load. I would have expected a check inside ViewProviderPage::finishRestoring() not to invoke showMDIViewPage() |
https://github.com/FreeCAD/FreeCAD/commit/7de79e799747cfa138bb9534bb7e618961af43ed |
| 2017-03-15 12:59 | HoWil | New Issue | |
| 2017-03-15 12:59 | HoWil | Tag Attached: drawing | |
| 2017-03-15 12:59 | HoWil | Tag Attached: TechDraw | |
| 2017-03-15 20:50 | Kunda1 | Project | FreeCAD => TechDraw |
| 2017-03-15 20:51 | Kunda1 | Note Added: 0008633 | |
| 2017-05-09 00:55 | wandererfan | Note Added: 0008921 | |
| 2017-06-23 20:25 | HoWil | Note Added: 0009494 | |
| 2017-06-24 14:49 | wandererfan | Note Added: 0009519 | |
| 2017-09-08 18:01 | Kunda1 | Note Added: 0010095 | |
| 2017-09-08 18:01 | Kunda1 | Assigned To | => wandererfan |
| 2017-09-08 18:01 | Kunda1 | Status | new => assigned |
| 2017-09-10 13:39 | wmayer | Status | assigned => closed |
| 2017-09-10 13:39 | wmayer | Resolution | open => fixed |
| 2017-09-10 13:39 | wmayer | Fixed in Version | => 0.17 |
| 2017-09-10 13:39 | wmayer | Note Added: 0010103 | |
| 2017-09-10 15:00 | wmayer | Status | closed => new |
| 2017-09-10 15:00 | wmayer | Resolution | fixed => reopened |
| 2017-09-10 15:00 | wmayer | Note Added: 0010104 | |
| 2017-11-25 15:04 | wmayer | Status | new => closed |
| 2017-11-25 15:04 | wmayer | Note Added: 0010471 |
