| 0002972 | TechDraw | Bug | public | 2017-03-18 21:28 | 2017-05-10 16:08 |
| Reporter | sankey | Assigned To | wandererfan | ||
| Platform | Linux | OS | Ubuntu | OS Version | 16.04 |
| Summary | 0002972: TechDraw PDF export from Python can only make PDFs of a Page in foreground | ||||
| Description | With Python it is only possible to export TechDraw Pages which are open and in the foreground. | ||||
| Steps To Reproduce | Experiment 1: 1. Create two TechDraw pages and draw things in them to identify them. 2. View the first page ("Page"). It should be in the foreground. 3. Open the python console and try to export the second page ("Page001") as PDF:
4. Observe that the exported PDF is in fact a rendering of the first page ("Page")Experiment 2: 1. Continue from the same document as Experiment 1. 2. Close all TechDraw pages. 3. Try again to export "Page001" as PDF. 4. Observe that the exported PDF is completely blank! | ||||
| Additional Information | OS: Ubuntu 16.04.1 LTS Word size of OS: 32-bit Word size of FreeCAD: 32-bit Version: 0.17.10476 (Git) Build type: None Branch: master Hash: b6150097e9cf4d7b0f5ad71f2f8750f2e7aac0d9 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 | ||||
| Tags | python | ||||
| related to | 0002971 | closed | wandererfan | hiding foreground TechDraw page from Python causes segfault |
| child of | 0003002 | closed | wandererfan | TechDraw - Update python bindings |
Forum thread: https://forum.freecadweb.org/viewtopic.php?f=35&t=21855 Edit: @sgrogan mentioned that this ticket actually evolved out of this thread (but OP didn't mention it): https://forum.freecadweb.org/viewtopic.php?f=22&t=21384 |
[quote="wmayer"] obj = FreeCAD.ActiveDocument.getObject("Page001") FreeCADGui.export([obj], u"/tmp/Page001.pdf") [/quote] [quote="wmayer"] [mono]FreeCADGui.export[/mono] is part of the core system and thus doesn't know anything about objects of extension modules. This function gets the object to check which document it is part of and then simply uses the active view of this document and export that as pdf. See https://github.com/FreeCAD/FreeCAD/blob/master/src/Gui/ApplicationPy.cpp#L528 So to achieve what you want there are some alternatives how to realize it: * add a function to the Py interface of TechDrawGui that accepts a [mono]DrawPage[/mono] object and path name. Inside this function can access the correct mdi page via the view provider and export the content as pdf * another way could be to implement a specialized Python wrapper for the view provider that offers the needed interface for export[/quote] |
FreeCAD: master 5a0f53d7 2017-05-09 00:43:39 WandererFan Committer: wmayer Details Diff |
Fix 0002972 Export Pdf Page Not in Foreground exposes TechDrawGui.exportPageAsPdf(page,file) also adds TechDrawGui.exportPageAsSvg(page,file) |
Affected Issues 0002972 |
| mod - src/Mod/TechDraw/Gui/AppTechDrawGui.cpp | Diff File | ||
| mod - src/Mod/TechDraw/Gui/AppTechDrawGuiPy.cpp | Diff File | ||
| mod - src/Mod/TechDraw/Gui/MDIViewPage.cpp | Diff File | ||
| mod - src/Mod/TechDraw/Gui/MDIViewPage.h | Diff File | ||
| mod - src/Mod/TechDraw/Gui/ViewProviderPage.h | Diff File | ||
| 2017-03-18 21:28 | sankey | New Issue | |
| 2017-03-20 12:32 | Kunda1 | Project | FreeCAD => TechDraw |
| 2017-03-20 12:33 | Kunda1 | Relationship added | related to 0002971 |
| 2017-04-28 02:18 | Kunda1 | Tag Attached: python | |
| 2017-04-28 02:18 | Kunda1 | Note Added: 0008790 | |
| 2017-04-28 14:38 | Kunda1 | Note Added: 0008800 | |
| 2017-04-28 14:39 | Kunda1 | Note Edited: 0008800 | |
| 2017-04-28 21:49 | Kunda1 | Note Edited: 0008790 | |
| 2017-04-29 11:48 | Kunda1 | Status | new => confirmed |
| 2017-04-29 15:27 | Kunda1 | Relationship added | child of 0003002 |
| 2017-05-10 16:04 | wmayer | Changeset attached | => FreeCAD master 5a0f53d7 |
| 2017-05-10 16:08 | wmayer | Assigned To | => wandererfan |
| 2017-05-10 16:08 | wmayer | Status | confirmed => closed |
| 2017-05-10 16:08 | wmayer | Resolution | open => fixed |
| 2017-05-10 16:08 | wmayer | Fixed in Version | => 0.17 |
