| 0002974 | Path | Feature | public | 2017-03-19 01:07 | 2017-08-13 15:20 |
| Reporter | mlampert | Assigned To | mlampert | ||
| Summary | 0002974: Holding tags dressup support for ArchPanela | ||||
| Description | The holding tags dressup currently looks for a single closed wire at the bottom Z-axis of a path, which it uses as the base to create the tags (in positive Z direction). If it doesn't find that it throws an Exception. ArchPanels deviate from the Path standard of one part per job. Holding tags needs to be enhanced to deal with multiple parts (Paths) that form a closed wire. Each one of them needs their own set of holding tags. | ||||
| 2017-03-19 01:07 | mlampert | New Issue | |
| 2017-03-19 01:07 | mlampert | Status | new => assigned |
| 2017-03-19 01:07 | mlampert | Assigned To | => mlampert |
| 2017-08-12 06:13 | mlampert | Note Added: 0009889 | |
| 2017-08-12 06:14 | mlampert | Status | assigned => resolved |
| 2017-08-12 06:14 | mlampert | Resolution | open => fixed |
| 2017-08-13 15:20 | Kunda1 | Status | resolved => closed |
| 2017-08-13 15:20 | Kunda1 | Fixed in Version | => 0.17 |
| 2017-08-13 15:20 | Kunda1 | Note Added: 0009898 |
