| 0002978 | FreeCAD | Bug | public | 2017-03-21 10:39 | 2017-07-15 10:57 |
| Reporter | r-frank | Assigned To | Kunda1 | ||
| OS | Windows | OS Version | 7 64-bit | ||
| Summary | 0002978: Loading spreadsheet-document ignores rows >AA | ||||
| Description | Creating spreadsheet document with information in rows bigger than AA will save the information to disk. But closing the document and re-opening it will ignore the rows >AA upon loading. | ||||
| Steps To Reproduce | See description | ||||
| Additional Information | see discussion thread in german sub-forum | ||||
| Tags | spreadsheet | ||||
CC @eivindkvedalen |
The problem seems to be that the column address "AB" is converted in some places to "BA". This is visible, if an alias is created for a cell in this column range. The yellow color of an alias at "AB1" can be found at the cell "BA1". The same "address-conversion" can be found for aliases in the document.xml in the FreeCAD-document. But I am not a C++-programmer able to find the responsible code for this problem. |
The same situation. |
Oops. My script works fine. Sry. |
Made a pullrequest to fix the issue: https://github.com/FreeCAD/FreeCAD/pull/669 |
Resolved by ulrich1 in: c:FreeCAD:42efec9b23ee68fa270cb563fe5d85af8ff1fdd1: c:FreeCAD:e58b74793a128ea7e0f8380cba77b8273ecd39f3: Bugtracker Note: once source-integration plugin is up-to-date then attach commits to this ticket and close. |
| 2017-03-21 10:39 | r-frank | New Issue | |
| 2017-03-21 10:39 | r-frank | Tag Attached: spreadsheet | |
| 2017-03-21 12:29 | Kunda1 | Note Added: 0008675 | |
| 2017-03-21 20:59 | ulrich1a | Note Added: 0008684 | |
| 2017-03-21 21:41 | gift | Note Added: 0008685 | |
| 2017-03-21 21:58 | gift | Note Added: 0008686 | |
| 2017-04-02 20:35 | ulrich1a | Note Added: 0008749 | |
| 2017-04-25 11:45 | Kunda1 | Status | new => resolved |
| 2017-04-25 11:45 | Kunda1 | Resolution | open => fixed |
| 2017-04-25 11:45 | Kunda1 | Fixed in Version | => 0.17 |
| 2017-04-25 11:45 | Kunda1 | Note Added: 0008750 | |
| 2017-07-15 10:57 | Kunda1 | Assigned To | => Kunda1 |
| 2017-07-15 10:57 | Kunda1 | Status | resolved => closed |
