| 0002995 | Sketcher | Feature | public | 2017-04-01 17:29 | 2017-05-02 10:48 |
| Reporter | normandc | Assigned To | abdullah | ||
| Summary | 0002995: Sketcher horizontal/vertical constraints: implement their use to align points | ||||
| Description | This report proposes for horizontal and vertical constraints to support selection of two or more points. Currently, the only valid selection is line segment(s). It would be very useful to be able to align points from independent elements (lines, arc/circle centre points) either horizontally or vertically. Currently, the only way of doing that is to either add a horizontal/vertical dimensional constraint of zero value (which is not considered good practice) or a construction line joining the two points (which adds complexity to the sketch). Other constraints already support dual modes: tangent constraint doubles as a collinear constraint between lines, equal length constraint can work on arc/circle radii; therefore this implementation would comply with the sketcher philosophy. | ||||
| Additional Information | See forum topic: https://forum.freecadweb.org/viewtopic.php?f=3&t=21590 | ||||
Sketch::addHorizontalConstraint source Sketch::addVerticalConstraint source |
@abdullah wrote: implemented. https://forum.freecadweb.org/viewtopic.php?f=10&t=21878&p=170615#p170615 ---------------- Was it in fact implemented? FYI ticket thread was recreated from previous ticket. CC @DeepSOIC |
It is indeed implemented. It is not merged yet. It is waiting in my computer for the merge of this PR: https://github.com/FreeCAD/FreeCAD/pull/696 The reason is that it will conflict with it. As soon as that one is merged, I will rebase it to master and do a PR. |
Per Abdullah, commit is pending on FreeCAD Pull Request 696 |
https://github.com/FreeCAD/FreeCAD/pull/720 |
git show cfc2d8 40c6d4b 7bee2c5 |
FreeCAD master cfc2d86c FreeCAD master 40c6d4be FreeCAD master 7bee2c54 |
FreeCAD: master cfc2d86c 2017-04-20 14:54:26 Committer: wmayer Details Diff |
Sketcher: Horizontal alignment constraint command |
Affected Issues 0002995 |
| mod - src/Mod/Sketcher/Gui/CommandConstraints.cpp | Diff File | ||
FreeCAD: master 7bee2c54 2017-04-20 14:54:57 Committer: wmayer Details Diff |
Sketcher: Visualization of horizontal alignment constraint |
FreeCAD: master 40c6d4be 2017-04-20 15:04:35 Committer: wmayer Details Diff |
Sketcher: Vertical alignment constraint command |
| 2017-04-01 17:29 | normandc | New Issue | |
| 2017-04-01 17:30 | normandc | Additional Information Updated | |
| 2017-04-02 10:17 | kkremitzki | Note Added: 0008748 | |
| 2017-04-02 10:17 | kkremitzki | Tag Attached: #lowhangingfruit | |
| 2017-04-26 02:51 | Kunda1 | Assigned To | => abdullah |
| 2017-04-26 02:51 | Kunda1 | Status | new => assigned |
| 2017-04-26 02:54 | Kunda1 | Note Added: 0008768 | |
| 2017-04-26 16:49 | abdullah | Note Added: 0008779 | |
| 2017-04-28 02:06 | Kunda1 | Note Added: 0008787 | |
| 2017-04-30 16:58 | abdullah | Note Added: 0008834 | |
| 2017-05-02 10:41 | wmayer | Status | assigned => closed |
| 2017-05-02 10:41 | wmayer | Resolution | open => fixed |
| 2017-05-02 10:41 | wmayer | Fixed in Version | => 0.17 |
| 2017-05-02 10:41 | wmayer | Note Added: 0008846 | |
| 2017-05-02 10:46 | Kunda1 | Note Added: 0008847 | |
| 2017-05-02 10:47 | Kunda1 | Changeset attached | => FreeCAD master cfc2d86c |
| 2017-05-02 10:47 | Kunda1 | Changeset attached | => FreeCAD master 40c6d4be |
| 2017-05-02 10:48 | Kunda1 | Changeset attached | => FreeCAD master 7bee2c54 |
| 2017-05-02 10:48 | Kunda1 | Tag Detached: #lowhangingfruit |
