| 0003006 | PartDesign | Bug | public | 2017-04-29 15:05 | 2017-06-16 00:04 |
| Reporter | kkremitzki | Assigned To | kkremitzki | ||
| Summary | 0003006: PartDesign Mirrored features fail due to unexpected inversion | ||||
| Description | The Mirrored feature is inverted in two ways. For example, a cube at the origin mirrored about the vertical sketch axis is being mirrored about the horizontal axis instead. Additionally, it is mirrored on the other side of the plane of padding. | ||||
| Steps To Reproduce | Create a document and switch to PD WB. Create a body and add a sketch to any plane. Fix a rectangle to the origin and then stretch it out to some distance; lock that point to constrain the sketch. Pad it. Click on the padded feature. Click the Mirrored button. Observe the bug. | ||||
| Additional Information | Original thread: https://forum.freecad.org/viewtopic.php?f=3&t=21694&p=169385#p169385 | ||||
| related to | 0002235 | closed | kkremitzki | Cannot mirror mirrored object (within Part Design) |
| related to | 0002863 | assigned | ickby | Add Mirror body feature to PartDesign |
Is this a dupe of 0002235 ? |
@Kunda1 I don't think it can be said for sure until this one is fixed. It may be that that bug is being caused by an issue with mirroring a mirrored object specifically, rather than the fact that mirroring is broken in general. |
My explanation is maybe not too clear, so here's a screenshot. Note the coordinate vectors in the bottom right. This cube should be getting mirrored about the Y axis. |
Will be fixed with FreeCAD Pull Request 818 |
Fixed in master |
| 2017-04-29 15:05 | Kunda1 | New Issue | |
| 2017-04-29 15:05 | Kunda1 | Status | new => assigned |
| 2017-04-29 15:05 | Kunda1 | Assigned To | => kkremitzki |
| 2017-04-29 15:06 | Kunda1 | Reporter | Kunda1 => kkremitzki |
| 2017-05-02 11:28 | Kunda1 | Relationship added | related to 0002235 |
| 2017-05-02 11:29 | Kunda1 | Relationship added | related to 0002863 |
| 2017-05-02 11:32 | Kunda1 | Note Added: 0008850 | |
| 2017-05-22 12:34 | kkremitzki | Note Added: 0009078 | |
| 2017-05-25 13:35 | kkremitzki | File Added: 3006.png | |
| 2017-05-25 13:35 | kkremitzki | Note Added: 0009132 | |
| 2017-06-12 07:15 | kkremitzki | Note Added: 0009350 | |
| 2017-06-16 00:04 | kkremitzki | Status | assigned => closed |
| 2017-06-16 00:04 | kkremitzki | Resolution | open => fixed |
| 2017-06-16 00:04 | kkremitzki | Fixed in Version | => 0.17 |
| 2017-06-16 00:04 | kkremitzki | Note Added: 0009395 |
