| 0003017 | FEM | Feature | public | 2017-05-01 12:03 | 2017-06-24 07:08 |
| Reporter | HoWil | Assigned To | berndhahnebach | ||
| Summary | 0003017: highlighting of selected elements in FEM-wb | ||||
| Description | It would be extremely helpfull if elements like faces of solids selected for meshing (e.g. face selection in mesh-region) or constraint-assignment be highlighted when re-selecting them in the appropriate Task menu. The behavior is similar to the selection of elements int Tree-view. When selecting a Part-box in tree-view, the box is highlighted in 3D-view. For mesh-regions and mesh-groups is it otherwise not possible to see which elements were selected/added in Task-view. Constraints do get at least symbols in 3D but it is not directly possible to figure out which element listed in task-view is which element in 3D. For non-covered elements in 3d is a workaround to hover the mouse over the elements to see their names in the status line but this is not working for inner selections. The behavior should be like in the attached screenshots. After selecting a element like 'Face2' in Task view it is highlighted in 3D. See also the related discussion in the forum: https://forum.freecadweb.org/viewtopic.php?f=18&t=18780&hilit=clipping&start=30#p147758 | ||||
| Additional Information | Related macro is: https://forum.freecadweb.org/viewtopic.php?f=18&t=12381&p=151950#p151950 | ||||
@HoWil please re-add both screenshots, thx! |
Re-added (new) screenshots of selected Face2 without and with highlighting of the selected element. |
CfdFoam-wb already has this feature implemented see.... https://github.com/jaheyns/CfdFoam |
@HoWil do you mind specifying where in the source code the feature is located? thanks! |
may be helpful ... https://forum.freecadweb.org/viewtopic.php?f=22&t=16875 https://forum.freecadweb.org/viewtopic.php?f=8&t=17693#p139340 |
What exactly would be best? My idea: - if the constraint is opened mark all referece shapes of the conxtraint by a color - if a reference shape is selected in the task panel it is marked by another color |
workaround: As a hint, if the status line is activated and the mouse is moved over the shapes in the main window the shape names are printed in the status line. This helps to indicate which shape should be removed if one would like to remove a specific shape. bernd |
+1 I'm curious |
From my point of view the Constryaint Fixed has something in this regard already. If a edge or face in task panel in Constraint Fixed reference shapes is selected the shape is selected in the Main window with the model. Is this what you would like to see in all conatraints HoWil? |
I would like to add an screencast of how it works in CFDFoam but it looks like I am not allowed to upload .webm or .zip. Is there a reason why the two last pics from my where deleted? EDIT: I like both, the colors for the groups and the highlighting for the selected item in the task view. The selection via list is a long therm must have when you think of inner boundaries and models with hundrets of boundaries. |
https://github.com/jaheyns/CfdFoam/blob/master/_TaskPanelCfdFluidBoundary.py @Kunda: I think this is the file used to create the 'advanced' boundary selection menu. 'faceHighlightChange' is used to highlight the selected items in the task view. |
https://github.com/berndhahnebach/FreeCAD_bhb/commit/7d3b8c45d60026c461160a7f1e2dc54119a29aeb but it needs some more love ... |
this should do the trick: https://github.com/berndhahnebach/FreeCAD_bhb/commit/6cf727c9a2d86c3030541de5995c3a4a70b5a2a1 but it needs a bugfix too: https://github.com/berndhahnebach/FreeCAD_bhb/commit/728fba763c25479f4103d9f1d5508494f3ad5fbf both are in https://github.com/berndhahnebach/FreeCAD_bhb/commits/femdev |
https://github.com/FreeCAD/FreeCAD/pull/835 |
I'm gone add the other Python Constraints once this is in master and has been proved to work for a few days. |
I did test it with your femdev branch. It's exactly what I requested! I will close this request and open an separate one for the list selection. Thx Howil |
tested it in femdeb branch of bhb. Faces are highlighted after selecting them in Task view. |
| 2017-05-01 12:03 | Kunda1 | New Issue | |
| 2017-05-01 12:03 | Kunda1 | Status | new => assigned |
| 2017-05-01 12:03 | Kunda1 | Assigned To | => berndhahnebach |
| 2017-05-01 12:05 | Kunda1 | Reporter | Kunda1 => HoWil |
| 2017-05-01 12:06 | Kunda1 | Note Added: 0008838 | |
| 2017-06-14 08:46 | HoWil | File Added: Screenshot from 2017-06-14 10-44-24.png | |
| 2017-06-14 08:46 | HoWil | File Added: Screenshot from 2017-06-14 10-44-11.png | |
| 2017-06-14 08:46 | HoWil | Note Added: 0009361 | |
| 2017-06-14 09:03 | HoWil | Note Added: 0009362 | |
| 2017-06-14 12:28 | Kunda1 | Note Added: 0009363 | |
| 2017-06-16 04:40 | berndhahnebach | Note Added: 0009401 | |
| 2017-06-16 04:42 | berndhahnebach | Note Added: 0009402 | |
| 2017-06-16 04:44 | berndhahnebach | Note Added: 0009403 | |
| 2017-06-16 04:45 | berndhahnebach | Note Added: 0009404 | |
| 2017-06-16 04:45 | berndhahnebach | Note Edited: 0009404 | |
| 2017-06-21 16:02 | berndhahnebach | Note Added: 0009485 | |
| 2017-06-21 16:03 | berndhahnebach | Note Edited: 0009485 | |
| 2017-06-21 19:15 | Kunda1 | Status | assigned => feedback |
| 2017-06-23 19:50 | HoWil | Note Added: 0009492 | |
| 2017-06-23 19:50 | HoWil | Status | feedback => assigned |
| 2017-06-23 20:05 | HoWil | Note Edited: 0009492 | |
| 2017-06-23 20:16 | HoWil | Note Added: 0009493 | |
| 2017-06-23 21:33 | berndhahnebach | Note Added: 0009496 | |
| 2017-06-23 23:36 | berndhahnebach | Note Added: 0009497 | |
| 2017-06-23 23:43 | berndhahnebach | Note Added: 0009498 | |
| 2017-06-23 23:43 | berndhahnebach | Note Added: 0009499 | |
| 2017-06-24 06:59 | HoWil | Note Added: 0009501 | |
| 2017-06-24 07:08 | HoWil | Status | assigned => closed |
| 2017-06-24 07:08 | HoWil | Resolution | open => fixed |
| 2017-06-24 07:08 | HoWil | Fixed in Version | => 0.17 |
| 2017-06-24 07:08 | HoWil | Note Added: 0009502 |
