| 0003019 | File formats | General | public | 2017-05-04 08:33 | 2017-05-11 20:48 |
| Reporter | Ognian | Assigned To | keithsloan52 | ||
| Summary | 0003019: implement or fix text() in csg and scad import | ||||
| Description | Hello, first of all thank you for building this wonderful tool. I'm using the latest 0.17_pre: OS: Mac OS X Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.10986 (Git) Build type: Release Branch: (detached from a328e1f) Hash: a328e1fe737a882c8bdb48da1ed30f77cde019f6 Python version: 2.7.13 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.1.0 I'm having the following error when trying to import an csg file generated from an scad file: ('$fa', '12') ('$fs', '2') textmsg : text ( text="ESP8266MOD", size = 0.8, spacing = "1", font = "Arial:style=Bold", direction = "ltr", language = "en", script = "Latn", halign = "left", valign = "center", $fn = 72, $fa = 12, $fs = 2); Fontconfig warning: line 144: blank doesn't take any effect anymore. please remove it from your fonts.conf DXF libraries not found. Trying to download... Traceback (most recent call last): File "<string>", line 1, in <module> File "/Applications/FreeCAD 2.app/Contents/Mod/OpenSCAD/importCSG.py", line 121, in insert processcsg(filename) File "/Applications/FreeCAD 2.app/Contents/Mod/OpenSCAD/importCSG.py", line 145, in processcsg result = parser.parse(f.read()) File "/Applications/FreeCAD 2.app/Contents/Mod/OpenSCAD/ply/yacc.py", line 265, in parse return self.parseopt_notrack(input,lexer,debug,tracking,tokenfunc) File "/Applications/FreeCAD 2.app/Contents/Mod/OpenSCAD/ply/yacc.py", line 971, in parseopt_notrack p.callable(pslice) File "/Applications/FreeCAD 2.app/Contents/Mod/OpenSCAD/importCSG.py", line 1078, in p_text_action p[0] = [processTextCmd(t)] File "/Applications/FreeCAD 2.app/Contents/Mod/OpenSCAD/importCSG.py", line 734, in processTextCmd face = importDXFface(tmpfilename,None,None) File "/Applications/FreeCAD 2.app/Contents/Mod/OpenSCAD/OpenSCAD2Dgeom.py", line 480, in importDXFface importDXF.getDXFlibs() File "/Applications/FreeCAD 2.app/Contents/Mod/Draft/importDXF.py", line 144, in getDXFlibs errorDXFLib(gui) File "/Applications/FreeCAD 2.app/Contents/Mod/Draft/importDXF.py", line 113, in errorDXFLib reply = QtGui.QMessageBox.question(None,"",message.decode('utf8'), File "/Applications/FreeCAD 2.app/Contents/lib/python2.7/encodings/utf_8.py", line 16, in decode return codecs.utf_8_decode(input, errors, True) <type 'exceptions.UnicodeEncodeError'>: 'ascii' codec can't encode character u'\xf6' in position 19: ordinal not in range(128) looks like text() has some problems original lines in csg are: ... group() { multmatrix([[1, 0, 0, -0.5], [0, 1, 0, 0.5], [0, 0, 1, 1.101], [0, 0, 0, 1]]) { linear_extrude(height = 0.2, center = true, convexity = 10, scale = [1, 1], $fn = 72, $fa = 12, $fs = 2) { text(text = "ESP8266MOD", size = 0.8, spacing = 1, font = "Arial:style=Bold", direction = "ltr", language = "en", script = "Latn", halign = "left", valign = "center", $fn = 72, $fa = 12, $fs = 2); } } multmatrix([[1, 0, 0, -0.5], [0, 1, 0, -0.5], [0, 0, 1, 1.101], [0, 0, 0, 1]]) { linear_extrude(height = 0.2, center = true, convexity = 10, scale = [1, 1], $fn = 72, $fa = 12, $fs = 2) { text(text = "AI-THINKER", size = 0.8, spacing = 1, font = "Arial:style=Bold", direction = "ltr", language = "en", script = "Latn", halign = "left", valign = "center", $fn = 72, $fa = 12, $fs = 2); } } multmatrix([[1, 0, 0, -0.5], [0, 1, 0, -1.5], [0, 0, 1, 1.101], [0, 0, 0, 1]]) { linear_extrude(height = 0.2, center = true, convexity = 10, scale = [1, 1], $fn = 72, $fa = 12, $fs = 2) { text(text = "", size = 0.8, spacing = 1, font = "Arial:style=Bold", direction = "ltr", language = "en", halign = "left", valign = "center", $fn = 72, $fa = 12, $fs = 2); } } multmatrix([[1, 0, 0, -0.5], [0, 1, 0, -2.5], [0, 0, 1, 1.101], [0, 0, 0, 1]]) { linear_extrude(height = 0.2, center = true, convexity = 10, scale = [1, 1], $fn = 72, $fa = 12, $fs = 2) { text(text = "ISM 2.4GHz", size = 0.8, spacing = 1, font = "Arial:style=Bold", direction = "ltr", language = "en", script = "Latn", halign = "left", valign = "center", $fn = 72, $fa = 12, $fs = 2); } } multmatrix([[1, 0, 0, -0.5], [0, 1, 0, -3.5], [0, 0, 1, 1.101], [0, 0, 0, 1]]) { linear_extrude(height = 0.2, center = true, convexity = 10, scale = [1, 1], $fn = 72, $fa = 12, $fs = 2) { text(text = "PA +25dBm", size = 0.8, spacing = 1, font = "Arial:style=Bold", direction = "ltr", language = "en", script = "Latn", halign = "left", valign = "center", $fn = 72, $fa = 12, $fs = 2); } } multmatrix([[1, 0, 0, -0.5], [0, 1, 0, -4.5], [0, 0, 1, 1.101], [0, 0, 0, 1]]) { linear_extrude(height = 0.2, center = true, convexity = 10, scale = [1, 1], $fn = 72, $fa = 12, $fs = 2) { text(text = "802.11b/g/n", size = 0.8, spacing = 1, font = "Arial:style=Bold", direction = "ltr", language = "en", script = "Latn", halign = "left", valign = "center", $fn = 72, $fa = 12, $fs = 2); } } } ... Direct scad import fails with the same error message too Any chance this to get fixed? Thanks Ognian | ||||
| Steps To Reproduce | 1. create new Document 2. import ogi_nodemcu.csg | ||||
| Tags | CSG, OpenSCAD | ||||
@Ognian best chances to get it fixed faster is to post to the forum first before opening a ticket, as the guidelines state. Please do that from here on out. CC @keithsloan52 |
@Kunda1 Thanks a lot, I will do so from now on. But just to let you know why I did so, I read this in the forum: Board index ->Users ->Help on using FreeCAD the first pinned entry: Bug submission guidelines .... Ognian |
I tried this on my freecad-daily and I got a different error. There is a bug in linear_extrude with twist and 2D objects. Its on my list of things to do, but applying for a Msc has to take top priority |
@yorik do you mind modifying the language on Per: https://forum.freecadweb.org/viewtopic.php?f=3&t=5236#p41597 So users quickly understand how to submit bugs the freecad way? |
@keithsloan52 it's understood. do you mind if I assign this ticket to you in the meantime? |
Yes fine to assign to me |
The error reported by the OP is apparently not in openscad but just an encoding issue in importDXF. I now fixed the original issue, @keithsloan52 up to you to decide if you work further on this or if we close it... |
When I tried it on freecad-daily I did not get the DXF error but another error to do with linear-extrude. I will investigate further. Hope to find some time later this week. |
Apart from the dxf problem which yorik has address the CSG file throws up a problem because of an empty text request see line 192 text(text = "", size = 0.8, spacing = 1, font = "Arial:style=Bold", direction = "ltr", language = "en", halign = "left", valign = "center", $fn = 72, $fa = 12, $fs = 2); Bypass is not to make text requests with empty string @Ognian |
@keithsloan52 Thank you for your efforts resolving this issue. I tested yesterday with the latest build on github and indeed the UTF8 error is now away but the extrude error was there. Searching for the empty string ("") an removing it manually from the .csg file worked. COOL. So I hope you will add some check to ignore empty text strings to be extruded. Then importing the actual scad file which in turn includes the library (with the empty string) will also succeed (I hope)... FYI the scad lib is http://www.thingiverse.com/thing:1933779 Ognian |
@keithsloan I guess we could associate the future commit of FreeCAD Pull Request 748 with this ticket even though its named for a non-existent bug in HEAD. |
No 748 is for a different bug one that happens with the file below. For this issue I need to add some code to check if linearextrude is trying to extrude a null object ( i.e. Null text ). Problem is what do I return to the object stack? A null object and if so what are the implications for other requests |
Should be fixed in Pull Request 752. Sorry not used to adding fix 0003019 to commit. Have to be patient for import but does work for Op's file. Saves FreeCAD file is over 7Mb |
Thx for all your work on this @keithsloan52 ! Closing ticket |
FreeCAD: master 73f23073 2017-05-08 13:51:04 Details Diff |
Draft: Fixed encoding in importDXF message - issue 0003019 |
Affected Issues 0003019 |
FreeCAD: master 1e04f7da 2017-05-11 13:41:27 Keith Sloan Committer: wmayer Details Diff |
Fix for linear_extrude request of null object i.e. null text |
| mod - src/Mod/OpenSCAD/importCSG.py | Diff File | ||
| 2017-05-04 08:33 | Ognian | New Issue | |
| 2017-05-04 08:33 | Ognian | File Added: ogi_nodemcu.csg | |
| 2017-05-04 10:35 | Kunda1 | Note Added: 0008882 | |
| 2017-05-04 10:38 | Kunda1 | Tag Attached: CSG | |
| 2017-05-04 10:40 | Kunda1 | Tag Attached: OpenSCAD | |
| 2017-05-04 10:43 | Ognian | Note Added: 0008884 | |
| 2017-05-04 11:55 | keithsloan52 | Note Added: 0008885 | |
| 2017-05-06 11:04 | Kunda1 | Note Edited: 0008884 | |
| 2017-05-06 11:14 | Kunda1 | Note Added: 0008896 | |
| 2017-05-07 14:44 | Kunda1 | Note Added: 0008902 | |
| 2017-05-07 17:00 | keithsloan52 | Note Edited: 0008902 | |
| 2017-05-07 17:01 | keithsloan52 | Note Added: 0008905 | |
| 2017-05-07 17:01 | keithsloan52 | Note Edited: 0008902 | |
| 2017-05-07 20:01 | Kunda1 | Assigned To | => keithsloan52 |
| 2017-05-07 20:01 | Kunda1 | Status | new => assigned |
| 2017-05-08 13:51 | yorik | Changeset attached | => FreeCAD master 73f23073 |
| 2017-05-08 13:52 | yorik | Note Added: 0008918 | |
| 2017-05-08 14:57 | keithsloan52 | Note Added: 0008919 | |
| 2017-05-10 20:06 | keithsloan52 | Note Added: 0008945 | |
| 2017-05-11 09:02 | Ognian | Note Added: 0008950 | |
| 2017-05-11 11:52 | Kunda1 | Note Added: 0008952 | |
| 2017-05-11 12:09 | keithsloan52 | File Added: offsetTest2.scad | |
| 2017-05-11 12:09 | keithsloan52 | Note Added: 0008953 | |
| 2017-05-11 14:07 | keithsloan52 | Note Added: 0008957 | |
| 2017-05-11 14:08 | keithsloan52 | Note Edited: 0008957 | |
| 2017-05-11 20:45 | Kunda1 | Changeset attached | => FreeCAD master 1e04f7da |
| 2017-05-11 20:48 | Kunda1 | Status | assigned => closed |
| 2017-05-11 20:48 | Kunda1 | Resolution | open => fixed |
| 2017-05-11 20:48 | Kunda1 | Note Added: 0008963 |
