| 0003020 | Part | Bug | public | 2017-05-05 07:30 | 2019-01-26 21:55 |
| Reporter | Gauthier | Assigned To | wmayer | ||
| Platform | Windows + Linux | OS | Windows + Debian | OS Version | W10 + stretch |
| Summary | 0003020: 2D offset of circle are not in the right place | ||||
| Description | When using the Part/2D offset of a circle, the resulting offset is moved to a XY parallel plane or/and translated from the original position of the origin circle. The only solution to have the right offset from a circle is if the origine circle is in the XY plan and centered on the origine or the circle is inside a sketch and if the sketch is not moved in the XY plan. | ||||
| Steps To Reproduce | - Start new model - In the Draft workbench, draw a circle not centered on the origine or not on the XY plan then select the circle - In the Part workbench, select 2D Offset => The offset geometry of the circle is moved on the XY plan if the circle is not on this plan And the offset geometry is not centered on the circle. | ||||
| Tags | Part | ||||
FreeCAD version on Windows : OS: Windows 10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.10993 (Git) Build type: Release Branch: master Hash: bf5f3484f6f5506795b6e9b86288c75ab7357291 Python version: 2.7.8 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 FreeCAD version on Linux : OS: Debian GNU/Linux 9.0 (stretch) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.10967 (Git) Build type: Release Branch: master Hash: 38388cf650ef49cbce48af5dd33bdbe2487c8cbe Python version: 2.7.13 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 |
Please open a forum thread and bidirectionally link thread <=> ticket |
@normandc care to weigh in? |
Forum thread opened today : https://forum.freecadweb.org/viewtopic.php?f=8&t=22343 |
As pointed out by ChrisG setting the inverse placement moves the offset to the correct location. https://forum.freecadweb.org/viewtopic.php?f=8&t=22343#p206673 But of the source object is a disk then the offset looks broken, too. |
https://github.com/FreeCAD/FreeCAD/commit/dbc09e3a2342af8784045d3d0ae3565ec869bef6 |
| 2017-05-05 07:30 | Gauthier | New Issue | |
| 2017-05-05 07:30 | Gauthier | Tag Attached: Part | |
| 2017-05-05 07:43 | Gauthier | Note Added: 0008888 | |
| 2017-05-05 12:03 | Kunda1 | Note Added: 0008889 | |
| 2017-05-05 22:21 | Kunda1 | Note Added: 0008891 | |
| 2017-05-08 06:27 | Kunda1 | Status | new => feedback |
| 2017-05-09 06:55 | Gauthier | Note Added: 0008923 | |
| 2017-05-09 06:55 | Gauthier | Status | feedback => new |
| 2017-05-10 19:57 | Kunda1 | Project | FreeCAD => Part |
| 2017-09-15 20:24 | wmayer | Target Version | => 0.17 |
| 2017-10-01 19:49 | wmayer | Status | new => confirmed |
| 2018-01-13 17:48 | wmayer | Note Added: 0010757 | |
| 2018-02-19 18:08 | wmayer | Target Version | 0.17 => 0.18 |
| 2019-01-26 21:55 | wmayer | Assigned To | => wmayer |
| 2019-01-26 21:55 | wmayer | Status | confirmed => closed |
| 2019-01-26 21:55 | wmayer | Resolution | open => fixed |
| 2019-01-26 21:55 | wmayer | Fixed in Version | => 0.18 |
| 2019-01-26 21:55 | wmayer | Note Added: 0012529 |
