0003022DraftBugpublic2017-09-06 11:58
Reportergerd-melzer Assigned To
Status closedResolutionreopened
Platformi7OSWindowsOS Version10 64bit
Product Version0.16
Summary0003022: draft line error at XZ-axis
Descriptiondraw lines - confusion result while changing multiple between XY-XZ-YZ axises
Steps To Reproduce1. new draft
2. draw line at yx - ok
3. Change view and work plane to front (xz)
4. draw line at xz - nothing to see - no snap - undefined line as result
5. can see the line in back-view but not in front-view
6. Change the view and work plane multiple - different results for each line
Tags3dconnexion
2017-05-05 22:23
administrator   ~0008892
Please open a forum thread as well for the community to reproduce
2017-05-07 14:27
administrator   ~0008900
@gerd-melzer in addition to the above please also paste your
Help > About FreeCAD > Copy to clipboard
2017-05-10 11:53
administrator   ~0008931
@chrisb do you mind testing?
chrisb
2017-05-12 16:51
developer   ~0008978
I followed the points above, here is a precise description
  1. ok
  2. draw line from (0,0) to (1,1) - ok
  3. ok, line moves to the top out of sight
  4. draw line at the same visual position as before which starts now from (-4,0) - ok. 2nd line is visible, first is not.
  5. line visible in front and back view
  6. After "Fit the whole content on the screen" both lines are visible. They stay visible in all views at their expected positions.
This is definitely not an error, it is an inconvenience that after changing to front view the center is not at (0,0) but at (-4,0).
OS: Mac OS X
Version: 0.16.6706 (Git)
Branch: tag: 0.16.6706
Hash: f86a4e411ff7848dea98d7242f43b7774bee8fa0
Python version: 2.7.11
Qt version: 4.8.7
Coin version: 3.1.3
OCC version: 6.8.0.oce-0.17
2017-05-13 02:01
administrator   ~0008979
resolving. OP Please follow the guidelines next time to help utilize effectively the time volunteers put in to this work. Cheers.
Thanks Chrisb.
2017-08-13 15:30
administrator   ~0009904
@chrisb per your statement:
Should a Feature Request be open for this or should we just close this ticket?
2017-08-28 19:40
administrator   ~0010034
ping @chrisb
2017-08-29 09:39
administrator   ~0010039
unresolving so @chrisb can comment on ticket
2017-08-30 17:52
administrator   ~0010047
@chrisb please advise:
chrisb
2017-08-30 17:54
developer   ~0010048
Please close.
2017-09-06 11:58
administrator   ~0010073
Closing
2017-05-05 16:27 gerd-melzer New Issue
2017-05-05 22:23 Kunda1 Note Added: 0008892
2017-05-06 11:21 Kunda1 Summary draft line error at XZ-achis => draft line error at XZ-axis
2017-05-06 11:21 Kunda1 Description Updated
2017-05-06 11:22 Kunda1 Status new => feedback
2017-05-07 14:27 Kunda1 Note Added: 0008900
2017-05-10 11:53 Kunda1 Note Added: 0008931
2017-05-10 20:18 LAKSHMI PRASAD BUKKURI Tag Attached: 3dconnexion
2017-05-12 16:51 chrisb Note Added: 0008978
2017-05-13 02:01 Kunda1 Status feedback => resolved
2017-05-13 02:01 Kunda1 Resolution open => no change required
2017-05-13 02:01 Kunda1 Note Added: 0008979
2017-08-13 15:30 Kunda1 Note Added: 0009904
2017-08-13 15:31 Kunda1 Tag Attached: #pending
2017-08-28 19:40 Kunda1 Note Added: 0010034
2017-08-29 09:35 Kunda1 Note Edited: 0008978
2017-08-29 09:39 Kunda1 Status resolved => feedback
2017-08-29 09:39 Kunda1 Resolution no change required => reopened
2017-08-29 09:39 Kunda1 Note Added: 0010039
2017-08-30 17:52 Kunda1 Note Added: 0010047
2017-08-30 17:54 chrisb Note Added: 0010048
2017-09-06 11:58 Kunda1 Status feedback => closed
2017-09-06 11:58 Kunda1 Note Added: 0010073
2017-09-06 11:58 Kunda1 Tag Detached: #pending
