0003023ArchBugpublic2017-06-05 16:00
Reportervectro Assigned Toyorik
Status closedResolutionfixed
PlatformLinuxOSUbuntuOS Version16.04
Product Version0.17
Summary0003023: Crash in Arch CutPlane
DescriptionWhen attempting an Arch CutPlane using the attached file, FreeCad generates a stack trace as follows (and the command fails):
Running the Python command 'Arch_CutPlane' failed:
  File "/usr/lib/freecad-daily/Mod/Arch/ArchCutPlane.py", line 77, in Activated
    panel=_CutPlaneTaskPanel()
  File "/usr/lib/freecad-daily/Mod/Arch/ArchCutPlane.py", line 96, in __init__
    self.previewCutVolume(self.combobox.currentIndex())
  File "/usr/lib/freecad-daily/Mod/Arch/ArchCutPlane.py", line 117, in previewCutVolume
    cutVolume = ArchCommands.getCutVolume(FreeCADGui.Selection.getSelectionEx()[1].SubObjects[0], FreeCADGui.Selection.getSelectionEx()[0].Object.Shape)
tuple index out of range
Steps To Reproduce
  1. Open the attached file.
  2. Select 'pear001' and 'Plane'
  3. Run Arch CutPlane
Additional InformationOS: Ubuntu 16.04.2 LTS
Version: 0.17.10993 (Git)
Build type: None
Hash: bf5f3484f6f5506795b6e9b86288c75ab7357291
Python version: 2.7.12
Qt version: 4.8.7
OCC version: 7.1.0
2017-05-06 20:32
administrator   ~0008898
@yorik do you mind checking this out?
yorik
2017-05-08 13:41
administrator   ~0008917
Hm must be some safety check missing... I'll handle this!
vectro
2017-05-21 22:59
reporter   ~0009076
FWIW it seems this shape is immune to a boolean operation also (the only message is "Boolean Operation Failed").
vectro
2017-05-22 10:45
reporter   ~0009077
I also get an error if I try to Draft Clone pear001.
  File "/usr/lib/freecad-daily/Mod/Draft/Draft.py", line 5758, in execute
    sh = sh.transformGeometry(m)
<class 'Part.OCCError'>:
yorik
2017-05-25 13:58
administrator   ~0009134
I don't see the attached file anymore, it might be because of the tracker failure some weeks ago... could you reupload it?
vectro
2017-06-02 02:11
reporter   ~0009250
Probably my error. Attaching now.
2017-06-02 02:25
administrator   ~0009251
@vectro still don't see the attachment
vectro
2017-06-03 00:58
reporter   ~0009269
Oh I see, the problem is that the attachment is too large. It seems the tracker must reject it without an error.
I have posted it to the web here: http://vectro.org/3023.fcstd
2017-06-03 02:09
administrator   ~0009271
Thx for the heads up about the tracker. We’re testing to see if we can reproduce the tracker behavior. Also, thx for the attachment.
yorik
2017-06-05 15:59
administrator   ~0009289
Thanks for the file. I now added a couple of safeguards to help the user to select things correctly and avoid the error above. The cutplane operation now works on your shape.
Note that these shape files thatare generated from mesh objects will rarely give very good results with booleans, unless they are very carefully modelled. This one has a number of defects that won't produce a very good result..
yorik
2017-06-05 16:00
administrator   ~0009290
Fixed with commit 43a8a94e6
2017-05-06 14:42 vectro New Issue
2017-05-06 19:06 Kunda1 Description Updated
2017-05-06 20:32 Kunda1 Note Added: 0008898
2017-05-08 13:41 yorik Note Added: 0008917
2017-05-08 13:41 yorik Assigned To => yorik
2017-05-08 13:41 yorik Status new => assigned
2017-05-21 22:59 vectro Note Added: 0009076
2017-05-22 10:45 vectro Note Added: 0009077
2017-05-22 13:48 Kunda1 Note Edited: 0009077
2017-05-25 13:58 yorik Note Added: 0009134
2017-05-25 15:29 Kunda1 Status assigned => feedback
2017-06-02 02:11 vectro Note Added: 0009250
2017-06-02 02:11 vectro Status feedback => assigned
2017-06-02 02:25 Kunda1 Note Added: 0009251
2017-06-03 00:58 vectro Note Added: 0009269
2017-06-03 02:09 Kunda1 Note Added: 0009271
2017-06-05 15:59 yorik File Added: Screenshot from 2017-06-05 12-56-01.png
2017-06-05 15:59 yorik Note Added: 0009289
2017-06-05 16:00 yorik Note Added: 0009290
2017-06-05 16:00 yorik Status assigned => closed
2017-06-05 16:00 yorik Resolution open => fixed
