| 0003024 | Sketcher | Bug | public | 2017-05-07 03:22 | 2017-09-24 22:15 |
| Reporter | barnacleduck | Assigned To | |||
| Summary | 0003024: Sketcher crashes on expression referring to named constraint | ||||
| Description | If I try to set a constraint by reference to a named constraint FreeCAD crashes. The only output I get is: Segmentation fault (core dumped) | ||||
| Steps To Reproduce | Start FreeCAD New document Select Part Design workbench Task-> create a body Task -> create sketch Select -> XY plane -> ok create a line (any two points) fix a length of line -> 1-line length = 10mm name = my_dist create a second line fix a length of line -> 2-line for length click expression icon Either: Type C Use down arrow to choose Constraints.my_dist = Segmentation fault (core dumped) or type Constraints.my_dist = Segmentation fault (core dumped) | ||||
| Additional Information | OS: "openSUSE Leap 42.2" Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.10236 (Git) (Packman) Build type: Release Branch: master Hash: dd20ba3d068c4a0903417d93144f8ac7fed068e9 Python version: 2.7.12 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.9.1.oce-0.18-dev | ||||
| Tags | expressions | ||||
Please open a forum thread and bidirectionally link ticket <=> thread |
Sorry, this is my first report. Where do I open the thread and how do I link it? (just include https://freecadweb.org/tracker/view.php?id=3024 ?) |
Thanks, please open a thread in https://forum.freecadweb.org/viewforum.php?f=8 And paste the description of the bug and a link to the ticket. Then notate the URL of the forum thread to the ticket |
Xref: https://forum.freecadweb.org/viewtopic.php?f=8&t=22322 NB: my (short) experience of FreeCAD is that it is not very stable generally. It may be something in my environment? |
No problem here. The crash reported might be due to an outdated version OS: Ubuntu 14.04.5 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.10993 (Git) Build type: None Branch: master Hash: bf5f3484f6f5506795b6e9b86288c75ab7357291 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 7.1.0 |
I have downloaded the latest appimage from here: https://www.freecadweb.org/wiki/Download That is: https://github.com/FreeCAD/FreeCAD/releases/download/0.16/FreeCAD-0.16.6707.glibc2.17-x86_64.AppImage It seems to be an older version: OS: "openSUSE Leap 42.2" Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6707 (Git) Build type: None Branch: releases/FreeCAD-0-16 Hash: 5465bc47c95db45e0be85dc0e2872419efadce0f Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 However, it doesn't crash with these constraints, but doesn't update changed constraints. Also, contraints with an expression don't seem to work - eg =Constraints.my_dist+3 I have gone to github to get the development version: OS: "openSUSE Leap 42.2" Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.10600 (Git) Build type: None Branch: master Hash: 4d9169faf778e9716fc647fb3fcf46462b5d99a4 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 7.1.0 (apparently still not quite up to date?) That does not crash. Constraint dependencies are updated when the parent constraint is updated. Does not parse =Constraint.my_dist+3 Am I supposed to use a spreadsheet for this (=Constraint.my_dist+3) instead? |
@eivindkvedalen do you mind weighing in on this? |
When you enter formulas in the Constraint dialog box, don't use the equal sign; write the expression directly. The equal sign is only used in the spreadsheet workbench to differentiate formulas from text/numbers. |
@eivindkvedalen isn't that how excel spreadsheet triggers the formula editor? If so, not to do that would be, in my mind, not very intuitive. |
| 2017-05-07 03:22 | barnacleduck | New Issue | |
| 2017-05-07 13:57 | Kunda1 | Note Added: 0008899 | |
| 2017-05-07 15:01 | Kunda1 | Tag Attached: expressions | |
| 2017-05-07 23:05 | barnacleduck | Note Added: 0008907 | |
| 2017-05-08 01:25 | Kunda1 | Note Added: 0008908 | |
| 2017-05-08 05:46 | barnacleduck | Note Added: 0008912 | |
| 2017-05-08 06:20 | chrisb | Note Added: 0008914 | |
| 2017-05-15 12:54 | barnacleduck | Note Added: 0009019 | |
| 2017-05-15 14:56 | Kunda1 | Note Added: 0009022 | |
| 2017-06-09 20:17 | eivindkvedalen | Note Added: 0009320 | |
| 2017-06-09 21:52 | Kunda1 | Note Added: 0009322 | |
| 2017-09-24 22:15 | wmayer | Status | new => closed |
| 2017-09-24 22:15 | wmayer | Resolution | open => no change required |
| 2017-09-24 22:15 | wmayer | Fixed in Version | => 0.17 |
