0003025FreeCADBugpublic2017-09-30 17:47
Reportergrandcross Assigned Towmayer
Status closedResolutionreopened
Product Version0.17
Target Version0.17Fixed in Version0.17
Summary0003025: Unhandled unknown exception caught in GUIApplication::notify when opening file + memory leak
DescriptionThis exception is encountered when opening the attached file. As a result nothing is visible in the display.
I have been able to make the object display again by selecting all objects that are part of the cut and selecting 'View->Visibility->Show Selection', but this is not consistently reproducible.
This file opens and displays fine in earlier builds (eg 10291)
Steps To ReproduceOpen the attached file. View the error in the 'Report View' window.
Additional InformationOS: Windows 7
Version: 0.17.10999 (Git)
Branch: debugging
Hash: 297b20e9b532858a9472d3df6eb6b21aa946983d
Python version: 2.7.8
Qt version: 4.8.7
OCC version: 7.0.0
Tagsmemory leak
Relationships
related to 0003191 closedwmayer Readily reproducible memory leak - FreeCAD doesn't reclaim memory on object deletion / project close.
grandcross
2017-05-07 19:47
reporter
Q Ball.FCStd (228,061 bytes)
2017-05-11 03:08
administrator   ~0008948
Please open a forum thread to discuss this with the FC community. Then bidirectionally link ticket <=> thread.
grandcross
2017-05-16 00:47
reporter   ~0009027
Forum thread: https://forum.freecad.org/viewtopic.php?f=19&t=22470&p=174321
Also, some other visibility issues probably related...
You can make the object visible by selecting the cut and hitting the space bar. However, if you try to edit a sketch, the display is empty. Similarly, if you delete the cut, the display is empty.
2017-05-16 08:42
administrator   ~0009028
The actual crash is fixed now.
However, there is still a massive memory leak. When loading the project which only has 46 objects then around 200 DocumentObjectItem instances are created but less than 100 are destroyed when closing the document.
2017-05-16 09:18
administrator   ~0009029
Add the test code into DocumentObjectItem::DocumentObjectItem
Base::Console().Message("Create item: %d, Object: %s\n", ++countItems, viewObject->getObject()->getNameInDocument());
and in DocumentObjectItem::~DocumentObjectItem()
Base::Console().Message("Delete item: %d, Object: %s\n", countItems--, viewObject->getObject()->getNameInDocument());
When reading the project the output is:
Create item: 1, Object: Sketch
Create item: 2, Object: Sketch
Create item: 3, Object: Revolution
Create item: 4, Object: Revolution
Create item: 5, Object: Part
Create item: 6, Object: Part
Create item: 7, Object: PartOrigin
Create item: 8, Object: PartOrigin
Create item: 9, Object: X_Axis
Create item: 10, Object: X_Axis
Create item: 11, Object: Y_Axis
Create item: 12, Object: Y_Axis
Create item: 13, Object: Z_Axis
Create item: 14, Object: Z_Axis
Create item: 15, Object: XY_Plane
Create item: 16, Object: XY_Plane
Create item: 17, Object: XZ_Plane
Create item: 18, Object: XZ_Plane
Create item: 19, Object: YZ_Plane
Create item: 20, Object: YZ_Plane
Create item: 21, Object: RevolutionBody
Create item: 22, Object: RevolutionBody
Create item: 23, Object: RevolutionBodyOrigin
Create item: 24, Object: RevolutionBodyOrigin
Create item: 25, Object: X_Axis001
Create item: 26, Object: X_Axis001
Create item: 27, Object: Y_Axis001
Create item: 28, Object: Y_Axis001
Create item: 29, Object: Z_Axis001
Create item: 30, Object: Z_Axis001
Create item: 31, Object: XY_Plane001
Create item: 32, Object: XY_Plane001
Create item: 33, Object: XZ_Plane001
Create item: 34, Object: XZ_Plane001
Create item: 35, Object: YZ_Plane001
Create item: 36, Object: YZ_Plane001
Create item: 37, Object: Part002
Create item: 38, Object: Part002
Create item: 39, Object: Part002Origin
Create item: 40, Object: Part002Origin
Create item: 41, Object: X_Axis004
Create item: 42, Object: X_Axis004
Create item: 43, Object: Y_Axis004
Create item: 44, Object: Y_Axis004
Create item: 45, Object: Z_Axis004
Create item: 46, Object: Z_Axis004
Create item: 47, Object: XY_Plane004
Create item: 48, Object: XY_Plane004
Create item: 49, Object: XZ_Plane004
Create item: 50, Object: XZ_Plane004
Create item: 51, Object: YZ_Plane004
Create item: 52, Object: YZ_Plane004
Create item: 53, Object: Body001
Create item: 54, Object: Body001
Create item: 55, Object: Body001Origin
Create item: 56, Object: Body001Origin
Create item: 57, Object: X_Axis005
Create item: 58, Object: X_Axis005
Create item: 59, Object: Y_Axis005
Create item: 60, Object: Y_Axis005
Create item: 61, Object: Z_Axis005
Create item: 62, Object: Z_Axis005
Create item: 63, Object: XY_Plane005
Create item: 64, Object: XY_Plane005
Create item: 65, Object: XZ_Plane005
Create item: 66, Object: XZ_Plane005
Create item: 67, Object: YZ_Plane005
Create item: 68, Object: YZ_Plane005
Create item: 69, Object: Sketch003
Create item: 70, Object: Sketch003
Create item: 71, Object: Revolution002
Create item: 72, Object: Revolution002
Create item: 73, Object: Sketch004
Create item: 74, Object: Sketch004
Create item: 75, Object: Pocket001
Create item: 76, Object: Pocket001
Create item: 77, Object: Sketch005
Create item: 78, Object: Sketch005
Create item: 79, Object: Pocket002
Create item: 80, Object: Pocket002
Create item: 81, Object: Sketch006
Create item: 82, Object: Sketch006
Create item: 83, Object: Pocket003
Create item: 84, Object: Pocket003
Create item: 85, Object: Mirrored
Create item: 86, Object: Mirrored
Create item: 87, Object: Sketch007
Create item: 88, Object: Sketch007
Create item: 89, Object: Pocket004
Create item: 90, Object: Pocket004
Create item: 91, Object: Cut
Create item: 92, Object: Cut
and
Create item: 93, Object: Sketch003
Create item: 94, Object: Revolution002
Create item: 95, Object: Sketch004
Create item: 96, Object: Pocket001
Create item: 97, Object: Sketch005
Create item: 98, Object: Pocket002
Create item: 99, Object: Sketch006
Create item: 100, Object: Pocket003
Create item: 101, Object: Mirrored
Create item: 102, Object: Sketch007
Create item: 103, Object: Pocket004
Create item: 104, Object: Sketch003
Create item: 105, Object: Revolution002
Create item: 106, Object: Sketch004
Create item: 107, Object: Pocket001
Create item: 108, Object: Sketch005
Create item: 109, Object: Pocket002
Create item: 110, Object: Sketch006
Create item: 111, Object: Pocket003
Create item: 112, Object: Mirrored
Create item: 113, Object: Sketch007
Create item: 114, Object: Pocket004
Create item: 115, Object: Sketch003
Create item: 116, Object: Revolution002
Create item: 117, Object: Sketch004
Create item: 118, Object: Pocket001
Create item: 119, Object: Sketch005
Create item: 120, Object: Pocket002
Create item: 121, Object: Sketch006
Create item: 122, Object: Pocket003
Create item: 123, Object: Mirrored
Create item: 124, Object: Sketch007
Create item: 125, Object: Pocket004
Create item: 126, Object: Sketch003
Create item: 127, Object: Revolution002
Create item: 128, Object: Sketch004
Create item: 129, Object: Pocket001
Create item: 130, Object: Sketch005
Create item: 131, Object: Pocket002
Create item: 132, Object: Sketch006
Create item: 133, Object: Pocket003
Create item: 134, Object: Mirrored
Create item: 135, Object: Sketch007
Create item: 136, Object: Pocket004
Create item: 137, Object: Sketch003
Create item: 138, Object: Revolution002
Create item: 139, Object: Sketch004
Create item: 140, Object: Pocket001
Create item: 141, Object: Sketch005
Create item: 142, Object: Pocket002
Create item: 143, Object: Sketch006
Create item: 144, Object: Pocket003
Create item: 145, Object: Mirrored
Create item: 146, Object: Sketch007
Create item: 147, Object: Pocket004
Create item: 148, Object: Sketch003
Create item: 149, Object: Revolution002
Create item: 150, Object: Sketch004
Create item: 151, Object: Pocket001
Create item: 152, Object: Sketch005
Create item: 153, Object: Pocket002
Create item: 154, Object: Sketch006
Create item: 155, Object: Pocket003
Create item: 156, Object: Mirrored
Create item: 157, Object: Sketch007
Create item: 158, Object: Pocket004
Create item: 159, Object: Sketch003
Create item: 160, Object: Revolution002
Create item: 161, Object: Sketch004
Create item: 162, Object: Pocket001
Create item: 163, Object: Sketch005
Create item: 164, Object: Pocket002
Create item: 165, Object: Sketch006
Create item: 166, Object: Pocket003
Create item: 167, Object: Mirrored
Create item: 168, Object: Sketch007
Create item: 169, Object: Pocket004
Create item: 170, Object: Sketch003
Create item: 171, Object: Revolution002
Create item: 172, Object: Sketch004
Create item: 173, Object: Pocket001
Create item: 174, Object: Sketch005
Create item: 175, Object: Pocket002
Create item: 176, Object: Sketch006
Create item: 177, Object: Pocket003
Create item: 178, Object: Mirrored
Create item: 179, Object: Sketch007
Create item: 180, Object: Pocket004
Create item: 181, Object: Revolution002
Create item: 182, Object: Pocket001
Create item: 183, Object: Pocket002
Create item: 184, Object: Pocket003
Create item: 185, Object: Mirrored
Create item: 186, Object: Pocket004
Create item: 187, Object: Revolution002
Create item: 188, Object: Pocket001
Create item: 189, Object: Pocket002
Create item: 190, Object: Pocket003
Create item: 191, Object: Mirrored
Create item: 192, Object: Pocket004
Create item: 193, Object: Revolution
Create item: 194, Object: Pocket004
Create item: 195, Object: Revolution
Create item: 196, Object: Pocket004
Create item: 197, Object: Sketch
Create item: 198, Object: Sketch
Now expanding all items in the tree view a few more items are allocated
Create item: 199, Object: Sketch007
Create item: 200, Object: Sketch007
Create item: 201, Object: Sketch006
Create item: 202, Object: Sketch005
Create item: 203, Object: Sketch004
Create item: 204, Object: Sketch003
When closing the document less than 50% of the items are deleted:
Delete item: 204, Object: Part
Delete item: 203, Object: PartOrigin
Delete item: 202, Object: X_Axis
Delete item: 201, Object: Y_Axis
Delete item: 200, Object: Z_Axis
Delete item: 199, Object: XY_Plane
Delete item: 198, Object: XZ_Plane
Delete item: 197, Object: YZ_Plane
Delete item: 196, Object: RevolutionBody
Delete item: 195, Object: RevolutionBodyOrigin
Delete item: 194, Object: X_Axis001
Delete item: 193, Object: Y_Axis001
Delete item: 192, Object: Z_Axis001
Delete item: 191, Object: XY_Plane001
Delete item: 190, Object: XZ_Plane001
Delete item: 189, Object: YZ_Plane001
Delete item: 188, Object: Revolution
Delete item: 187, Object: Sketch
Delete item: 186, Object: Part002
Delete item: 185, Object: Part002Origin
Delete item: 184, Object: X_Axis004
Delete item: 183, Object: Y_Axis004
Delete item: 182, Object: Z_Axis004
Delete item: 181, Object: XY_Plane004
Delete item: 180, Object: XZ_Plane004
Delete item: 179, Object: YZ_Plane004
Delete item: 178, Object: Body001
Delete item: 177, Object: Body001Origin
Delete item: 176, Object: X_Axis005
Delete item: 175, Object: Y_Axis005
Delete item: 174, Object: Z_Axis005
Delete item: 173, Object: XY_Plane005
Delete item: 172, Object: XZ_Plane005
Delete item: 171, Object: YZ_Plane005
Delete item: 170, Object: Revolution002
Delete item: 169, Object: Pocket001
Delete item: 168, Object: Pocket002
Delete item: 167, Object: Pocket003
Delete item: 166, Object: Mirrored
Delete item: 165, Object: Pocket004
Delete item: 164, Object: Cut
Delete item: 163, Object: Revolution
Delete item: 162, Object: Sketch
Delete item: 161, Object: Pocket004
Delete item: 160, Object: Part
Delete item: 159, Object: PartOrigin
Delete item: 158, Object: X_Axis
Delete item: 157, Object: Y_Axis
Delete item: 156, Object: Z_Axis
Delete item: 155, Object: XY_Plane
Delete item: 154, Object: XZ_Plane
Delete item: 153, Object: YZ_Plane
Delete item: 152, Object: RevolutionBody
Delete item: 151, Object: RevolutionBodyOrigin
Delete item: 150, Object: X_Axis001
Delete item: 149, Object: Y_Axis001
Delete item: 148, Object: Z_Axis001
Delete item: 147, Object: XY_Plane001
Delete item: 146, Object: XZ_Plane001
Delete item: 145, Object: YZ_Plane001
Delete item: 144, Object: Revolution
Delete item: 143, Object: Sketch
Delete item: 142, Object: Part002
Delete item: 141, Object: Part002Origin
Delete item: 140, Object: X_Axis004
Delete item: 139, Object: Y_Axis004
Delete item: 138, Object: Z_Axis004
Delete item: 137, Object: XY_Plane004
Delete item: 136, Object: XZ_Plane004
Delete item: 135, Object: YZ_Plane004
Delete item: 134, Object: Body001
Delete item: 133, Object: Body001Origin
Delete item: 132, Object: X_Axis005
Delete item: 131, Object: Y_Axis005
Delete item: 130, Object: Z_Axis005
Delete item: 129, Object: XY_Plane005
Delete item: 128, Object: XZ_Plane005
Delete item: 127, Object: YZ_Plane005
Delete item: 126, Object: Revolution002
Delete item: 125, Object: Sketch003
Delete item: 124, Object: Pocket001
Delete item: 123, Object: Sketch004
Delete item: 122, Object: Pocket002
Delete item: 121, Object: Sketch005
Delete item: 120, Object: Pocket003
Delete item: 119, Object: Sketch006
Delete item: 118, Object: Mirrored
Delete item: 117, Object: Pocket004
Delete item: 116, Object: Sketch007
Delete item: 115, Object: Cut
Delete item: 114, Object: Revolution
Delete item: 113, Object: Sketch
Delete item: 112, Object: Pocket004
Delete item: 111, Object: Sketch007
2017-05-22 18:42
administrator   ~0009086
Fixed by wmayer. Closing.
2017-06-01 08:03
administrator   ~0009236
Although the originally reported bug is fixed, the report revealed a memory leak in the new tree view implementation which still needs to be fixed.
2017-06-27 11:21
administrator   ~0009558
Made this issue a PDN blocker due to remaining memory leak
2017-08-21 11:21
administrator   ~0009979
@kkremitzki do you have a moment to take a look?
2017-08-25 10:02
administrator   ~0010006
The first part (fixed) of the crash could be considered as urgent but the second part with the memory leak is not a show stopper bug and can be degraded to normal priority. Furthermore it's not related to PDN at all but is related to the core system.
2017-09-30 17:47
administrator   ~0010222
https://github.com/FreeCAD/FreeCAD/commit/53168d39d6ea03a21f38337363ae0669f1f31507
fixes the discovered memory leak
Related Changesets
FreeCAD: master f6656294
2017-05-16 08:37:34
Details Diff
issue 0003025: Unhandled unknown exception caught in GUIApplication::notify when opening file Affected Issues
0003025
mod - src/Gui/Tree.cpp Diff File
2017-05-07 19:47 grandcross New Issue
2017-05-07 19:47 grandcross File Added: Q Ball.FCStd
2017-05-07 19:47 grandcross File Added: QBall.PNG
2017-05-07 19:47 grandcross File Added: QBallErrors.PNG
2017-05-11 03:08 Kunda1 Note Added: 0008948
2017-05-16 00:47 grandcross Note Added: 0009027
2017-05-16 08:38 wmayer Changeset attached => FreeCAD master f6656294
2017-05-16 08:42 wmayer Assigned To => wmayer
2017-05-16 08:42 wmayer Status new => resolved
2017-05-16 08:42 wmayer Note Added: 0009028
2017-05-16 09:18 wmayer Note Added: 0009029
2017-05-16 09:19 wmayer Note Edited: 0009029
2017-05-22 18:42 Kunda1 Status resolved => closed
2017-05-22 18:42 Kunda1 Resolution open => fixed
2017-05-22 18:42 Kunda1 Fixed in Version => 0.17
2017-05-22 18:42 Kunda1 Note Added: 0009086
2017-06-01 08:03 wmayer Status closed => assigned
2017-06-01 08:03 wmayer Resolution fixed => reopened
2017-06-01 08:03 wmayer Note Added: 0009236
2017-06-27 11:18 Kunda1 Tag Attached: memory leak
2017-06-27 11:21 Kunda1 Priority normal => high
2017-06-27 11:21 Kunda1 Severity major => block
2017-06-27 11:21 Kunda1 Fixed in Version 0.17 =>
2017-06-27 11:21 Kunda1 Target Version => 0.17
2017-06-27 11:21 Kunda1 Summary Unhandled unknown exception caught in GUIApplication::notify when opening file => Unhandled unknown exception caught in GUIApplication::notify when opening file + memory leak
2017-06-27 11:21 Kunda1 Note Added: 0009558
2017-08-21 11:21 Kunda1 Note Added: 0009979
2017-08-25 10:02 wmayer Priority high => normal
2017-08-25 10:02 wmayer Severity block => major
2017-08-25 10:02 wmayer Note Added: 0010006
2017-08-25 10:02 wmayer Project PartDesign => FreeCAD
2017-09-30 11:36 Kunda1 Relationship added related to 0003191
2017-09-30 17:47 wmayer Status assigned => closed
2017-09-30 17:47 wmayer Fixed in Version => 0.17
2017-09-30 17:47 wmayer Note Added: 0010222
