| 0003026 | FreeCAD | Bug | public | 2017-05-09 11:24 | 2017-10-01 20:21 |
| Reporter | hokieengr | Assigned To | |||
| Summary | 0003026: IGES export results in empty IGES file | ||||
| Description | After creating some geometry in Part Design, I exported the resulting body to an IGES file. The resulting IGES file did not contain any geometry. The only real difference I can think of between this file and it's predecessor (which exported properly) is that this body has been rotated and translated. | ||||
| Steps To Reproduce | Load attached "example_iges_export_issue.fcstd" and export to IGES file. Examine resulting IGES file. | ||||
| Additional Information | OS: Ubuntu 15.10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.10993 (Git) Build type: Debug Branch: master Hash: bf5f3484f6f5506795b6e9b86288c75ab7357291 Python version: 2.7.10 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.7.0 | ||||
| Tags | IGES | ||||
@hokieengr would you please state how to recreate the bug step by step? Also if you'd like to potentially expedite a fix you can bidirectionally link ticket <=> forum thread to get more exposure to the community. Thx |
@Kunda1 The steps to reproduce the problem are in the issue details:
Forum link: https://forum.freecadweb.org/viewtopic.php?f=8&t=22270 |
After looking at this more last night, I do not believe this is an issue with the IGES export code. I discovered that all file formats exported a blank model thus I looked more on the FreeCAD side. It appears that somehow the "Tip" field was blank in the only body in that model. When I figured out how to point that to some geometry it exported to IGES without issues. How that field ended up blank is a mystery to me. It was not intuitive that that was the issue or how to fix it. |
When exporting a body instead of one of its sub-elements then you have to make sure to set the requested sub-element as tip. A shape of a body which hasn't set the tip is indeed empty. So far the issue is expected behaviour. |
| 2017-05-09 11:24 | hokieengr | New Issue | |
| 2017-05-09 11:24 | hokieengr | File Added: example_iges_export_issue.fcstd | |
| 2017-05-09 11:24 | hokieengr | Tag Attached: IGES | |
| 2017-05-09 12:13 | Kunda1 | Relationship added | related to 0001591 |
| 2017-05-09 12:14 | Kunda1 | Relationship deleted | related to 0001591 |
| 2017-05-10 11:48 | Kunda1 | Note Added: 0008930 | |
| 2017-05-10 18:34 | hokieengr | Note Added: 0008943 | |
| 2017-05-10 18:39 | hokieengr | Note Added: 0008944 | |
| 2017-09-24 19:55 | wmayer | Target Version | => 0.17 |
| 2017-10-01 20:21 | wmayer | Status | new => closed |
| 2017-10-01 20:21 | wmayer | Resolution | open => no change required |
| 2017-10-01 20:21 | wmayer | Note Added: 0010231 |
