0003028 | PartDesign | Feature | public | 2017-05-13 12:49 | 2021-02-06 06:43 |
Reporter | Kunda1 | Assigned To | abdullah | ||
Priority | normal | Severity | feature | Reproducibility | always |
Status | assigned | Resolution | open | ||
Product Version | 0.17 | ||||
Target Version | 0.20 | ||||
Summary | 0003028: [PartDesign] Per face colors and keeping colors when adding a feature | ||||
Description | Hi, This is a cloned version of an old ticket to keep part of the original feature request. - Per face colors in PDN. - Keep preexisting per face colors of a solid when adding a feature (such as Pad, Pocket, Groove, Revolution, and Patterns). Original request by Petar | ||||
Tags | colors | ||||
FreeCAD Information | |||||
related to | 0000848 | closed | abdullah | PartDesign | [PartDesign] Keep Transparency and Colors when adding a feature |
related to | 0001626 | closed | chennes | FreeCAD | Transparency not respected when highlighting |
related to | 0003148 | closed | wmayer | PartDesign | PartDesign does not allow colouring of single faces for non-primitives |
Wouldn't this be part of the new PartDesign? I haven't used it for a while. Shouldn't only the Body Feature be the only feature that can have the material properties set... |
Abdullah wrote: I am not sure of the current applicability of this issue: 1. Keeping transparency, I just fixed this a couple of days ago. 2. Per face colors, I do not think it is currently possible with PD NEXT (I do not know how at least). Maybe this feature request should be updated/rewritten in line with the current user requirements for v0.17 PD NEXT. @Abdullah what commit did you add for number 1? Since this ticket is old I'm not sure @pperisin will respond to point number 2. How to proceed if not? |
https://github.com/FreeCAD/FreeCAD/pull/685 Face per color is a feature PD should have. So I think that a feature request asking for this is appropriate. We should have a procedure for those cases where part of a bug is fixed but not the whole and the same for feature request. Something like splitting a ticket into two, so that one can be marked as fixed while the other remains open. Or a new ticket deriving from an old one... |
@abdullah I'd be happy to clone this ticket and you can edit the clone so that it's rewritten correctly to PDN specs? |
@kunda1 Sure!! Give me the new ticket number and I will edit it. |
@Abdullah here is the cloned ticket of 0000848 |
@kunda1 I acknowledge I have been notified. I will take action in due time. |
linked 0001626 to this ticket as well |
This ticket has been migrated to GitHub as issue 5696. |
2017-05-13 12:49 | Kunda1 | New Issue | |
2017-05-13 12:49 | Kunda1 | Issue generated from: 0000848 | |
2017-05-13 12:49 | Kunda1 | Note Added: 0008986 | |
2017-05-13 12:49 | Kunda1 | Note Added: 0008987 | |
2017-05-13 12:49 | Kunda1 | Note Added: 0008988 | |
2017-05-13 12:49 | Kunda1 | Note Added: 0008989 | |
2017-05-13 12:49 | Kunda1 | Note Added: 0008990 | |
2017-05-13 12:49 | Kunda1 | Relationship added | related to 0000848 |
2017-05-27 19:18 | Kunda1 | Note Added: 0009170 | |
2017-05-27 20:29 | abdullah | Note Added: 0009172 | |
2017-05-31 14:50 | abdullah | Summary | [PartDesign] Keep Transparency and Colors when adding a feature => [PartDesign] Per face colors and keeping colors when adding a feature |
2017-05-31 14:50 | abdullah | Description Updated | |
2017-06-07 21:16 | Kunda1 | Tag Attached: colors | |
2017-10-19 11:31 | Kunda1 | Relationship added | related to 0003148 |
2018-05-30 23:46 | Kunda1 | Assigned To | => abdullah |
2018-05-30 23:46 | Kunda1 | Status | new => assigned |
2018-05-30 23:47 | Kunda1 | Relationship added | related to 0001626 |
2018-05-30 23:47 | Kunda1 | Note Added: 0011317 | |
2021-02-06 06:43 | abdullah | Target Version | => 0.20 |
