| 0000848 | PartDesign | Feature | public | 2012-09-27 06:18 | 2018-09-16 16:52 |
| Reporter | pperisin | Assigned To | abdullah | ||
| Summary | 0000848: [PartDesign] Keep Transparency and Colors when adding a feature | ||||
| Description | Hi, It would be nice if transparency + colors (solid color and color-per-face) are not lost when adding a feature to a solid (such as Pad, Pocket, Groove, Revolution, and Patterns). 0.14 should get robust references (Or Names, I do not know how it will be called). Maybe this should wait until that is implemented. Regards Petar | ||||
| Tags | colors, transparency | ||||
| related to | 0002806 | closed | yorik | FreeCAD | Loading a boolean objects Transparency get lost |
| related to | 0001626 | closed | chennes | FreeCAD | Transparency not respected when highlighting |
| related to | 0001029 | closed | yorik | FreeCAD | Transparency lost in compound |
| related to | 0003028 | assigned | abdullah | PartDesign | [PartDesign] Per face colors and keeping colors when adding a feature |
| related to | 0003148 | closed | wmayer | PartDesign | PartDesign does not allow colouring of single faces for non-primitives |
| related to | 0002725 | closed | wmayer | PartDesign | Random color for features in PartDesignNext |
Wouldn't this be part of the new PartDesign? I haven't used it for a while. Shouldn't only the Body Feature be the only feature that can have the material properties set... |
Abdullah wrote: I am not sure of the current applicability of this issue: 1. Keeping transparency, I just fixed this a couple of days ago. 2. Per face colors, I do not think it is currently possible with PD NEXT (I do not know how at least). Maybe this feature request should be updated/rewritten in line with the current user requirements for v0.17 PD NEXT. @Abdullah what commit did you add for number 1? Since this ticket is old I'm not sure @pperisin will respond to point number 2. How to proceed if not? |
https://github.com/FreeCAD/FreeCAD/pull/685 Face per color is a feature PD should have. So I think that a feature request asking for this is appropriate. We should have a procedure for those cases where part of a bug is fixed but not the whole and the same for feature request. Something like splitting a ticket into two, so that one can be marked as fixed while the other remains open. Or a new ticket deriving from an old one... |
@abdullah I'd be happy to clone this ticket and you can edit the clone so that it's rewritten correctly to PDN specs? |
@kunda1 Sure!! Give me the new ticket number and I will edit it. |
@abdullah awesome! 0003028 |
Fixed by commit b53c12d3 for the whole body transparency, separate issue 0003028 was created for face color and transparency. |
| 2012-09-27 06:18 | pperisin | New Issue | |
| 2014-02-04 15:39 | yorik | Project | FreeCAD => PartDesign |
| 2014-02-08 00:37 | mrlukeparry | Note Added: 0004165 | |
| 2017-02-10 04:59 | Kunda1 | Tag Attached: transparency | |
| 2017-02-10 05:03 | Kunda1 | Relationship added | related to 0001029 |
| 2017-02-10 05:06 | Kunda1 | Relationship added | related to 0002806 |
| 2017-02-10 05:07 | Kunda1 | Relationship added | related to 0001626 |
| 2017-04-28 11:34 | Kunda1 | Assigned To | => abdullah |
| 2017-04-28 11:34 | Kunda1 | Status | new => feedback |
| 2017-04-28 11:34 | Kunda1 | Note Added: 0008794 | |
| 2017-04-29 16:51 | abdullah | Note Added: 0008829 | |
| 2017-05-13 12:35 | Kunda1 | Note Added: 0008984 | |
| 2017-05-13 12:47 | abdullah | Note Added: 0008985 | |
| 2017-05-13 12:49 | Kunda1 | Issue cloned: 0003028 | |
| 2017-05-13 12:49 | Kunda1 | Relationship added | related to 0003028 |
| 2017-05-13 12:50 | Kunda1 | Note Added: 0008991 | |
| 2017-06-07 21:16 | Kunda1 | Tag Attached: colors | |
| 2017-10-19 11:32 | Kunda1 | Relationship added | related to 0003148 |
| 2017-10-19 11:33 | Kunda1 | Relationship added | related to 0002725 |
| 2018-09-16 16:52 | normandc | Status | feedback => closed |
| 2018-09-16 16:52 | normandc | Resolution | open => fixed |
| 2018-09-16 16:52 | normandc | Fixed in Version | => 0.17 |
| 2018-09-16 16:52 | normandc | Note Added: 0011765 |
