0003029PartDesignBugpublic2017-05-15 11:22
Reportervectro Assigned To
PlatformLinuxOSUbuntuOS Version16.04.2
Product Version0.17
Summary0003029: PartDesign Pad does not extrude multiple manifolds
DescriptionIn the attached file, only one of two sketch manifolds is extruded by PartDesign Pad. This is a regression since 0.15.
Steps To Reproduce1. Import the attached file.
2. Observe that the sketch has two manifolds but only one is extruded by the pad.
Additional InformationOS: Ubuntu 16.04.2 LTS
Version: 0.17.11054 (Git)
Build type: None
Hash: 36c60d3f8d924799e805ce56cb6e8fe6e49cf12b
Python version: 2.7.12
Qt version: 4.8.7
OCC version: 7.1.0
vectro
2017-05-13 15:46
reporter
2017-05-13 21:05
administrator   ~0008995
@NormandC do you mind testing ?
normandc
2017-05-13 21:37
manager   ~0008996
This is not a regression, this is expected behaviour since the early conception of the PartDesign workbench. If it worked before, it was an unintended bug.
Please look at the PartDesign Workbench documentation page, it is very clear about this:
https://www.freecadweb.org/wiki/PartDesign_Workbench
The Part Design Workbench provides tools for modelling complex solid parts and is based on a Feature editing methodology to produce a single contiguous solid.
The wiki
So the new behaviour in 0.17 actually restores things to what they should always have been, therefore this bug is invalid.
2017-05-13 15:46 vectro New Issue
2017-05-13 15:46 vectro File Added: Seat Rail GoPro Mount.fcstd
2017-05-13 21:05 Kunda1 Note Added: 0008995
2017-05-13 21:37 normandc Note Added: 0008996
2017-05-13 21:40 Kunda1 Status new => resolved
2017-05-13 21:40 Kunda1 Resolution open => no change required
2017-05-15 11:22 Kunda1 Status resolved => closed
