| 0003034 | Path | Bug | public | 2017-05-16 07:52 | 2017-11-26 00:52 |
| Reporter | Jakob Lundberg | Assigned To | mlampert | ||
| Summary | 0003034: HoldingTags dressup adds move to origin | ||||
| Description | The HoldingTags dressup adds a move to origin at the begining of the operation. This is not present when doing a normal profile operation and should not be necessary. | ||||
| Steps To Reproduce | 1. Create two bodies 2. Add profiling operations to the bodies 3. Add HoldingTags dressup to the operations Result: After the first profiling operation the spindle will return to origin. | ||||
| Additional Information | OS: Ubuntu 16.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.11084 (Git) Build type: None Branch: master Hash: fa00b4f06a0c96de57a777d6532467dfd8e5d141 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 | ||||
Forum thread: https://forum.freecadweb.org/viewtopic.php?f=15&t=22429 |
The issue is that the dressup converts the base g-code to edges. G-code does not have a defined starting point, but edges do. The first move of each op is typically a G0 to ClearanceHeight (no X or Y coordinates specified). For the edge 0 is used and then when transforming back to g-code the X and Y coordinates are used in the command. |
https://github.com/FreeCAD/FreeCAD/pull/1106/commits/8985372d1afa38ac1657f45e0a45858dea759f27 |
Committed in c:FreeCAD:737ca980f6e5c06f09020a7fb2c55f0059c2f4d4: |
| 2017-05-16 07:52 | Jakob Lundberg | New Issue | |
| 2017-05-16 07:52 | Jakob Lundberg | File Added: return_to_origin.png | |
| 2017-05-16 11:53 | Kunda1 | Note Added: 0009030 | |
| 2017-11-21 06:11 | mlampert | Assigned To | => mlampert |
| 2017-11-21 06:11 | mlampert | Status | new => assigned |
| 2017-11-21 06:16 | mlampert | Note Added: 0010448 | |
| 2017-11-22 18:35 | mlampert | Status | assigned => resolved |
| 2017-11-22 18:35 | mlampert | Resolution | open => fixed |
| 2017-11-22 18:35 | mlampert | Fixed in Version | => 0.17 |
| 2017-11-22 18:35 | mlampert | Note Added: 0010457 | |
| 2017-11-26 00:51 | Kunda1 | Note Added: 0010472 | |
| 2017-11-26 00:52 | Kunda1 | Status | resolved => closed |
