| 0003036 | Draft | Bug | public | 2017-05-17 15:58 | 2017-10-10 11:55 |
| Reporter | wtrssn | Assigned To | |||
| Platform | MAC | OS | Mac Os | OS Version | 10.12.4 |
| Summary | 0003036: Draft -> Clone feature doesn't work when you open file directly | ||||
| Description | On Mac OS 10.12.4 with FreeCad 0.16 If FreeCad is off and you open a * .FCStd file directly with double click and you try to make a clone (for example a cube), the clone is created but not seen, if you try to set the visibility = true, nothing changes, The clone can be seen. If FreeCad is turned on and you open a * .FCStd file from the File menu, and you try to make a clone (for example a cube), the clone is created and viewed. | ||||
| Steps To Reproduce | 1. if it is on, turn off the FreeCad application. 2. open a previously created * .FCStd file with double click. 3. Try to make a clone of a cube. 4. The clone is created but is invisible and inaccessible. | ||||
| Tags | Clone | ||||
Please ask in the forum and always post your Help > About FreeCAD > Copy to clipboard when asking for help. |
@wtrssn ping |
@chrisb can you reproduce? |
@Abdullah can you assist in determining how to proceed? |
Hi kunda1! tell me how could I help you? |
@warssn please follow up my request in 0003036:0009044 Also to get more attention, the most ideal way is to open a ticket on the FC forums. Especially with 0.16 issues since there is a high probability it's fixed already in 0.17 |
@wtrssn ^ |
It is weird. With: OS: Ubuntu 16.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.11215 (Git) Build type: None Branch: master Hash: 369cc735e1095557dc05d33c4520203c9c7b79b0 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 I cannot reproduce it because I get an error right away: Running the Python command 'Draft_Clone' failed: Traceback (most recent call last): File "/usr/lib/freecad-daily/Mod/Draft/DraftTools.py", line 4832, in Activated self.proceed() File "/usr/lib/freecad-daily/Mod/Draft/DraftTools.py", line 4841, in proceed FreeCADGui.doCommand("Draft.clone(FreeCAD.ActiveDocument."+obj.Name+")") File "<string>", line 1, in <module> name 'Draft' is not defined the work-around is to write in the python console "import Draft"... This is fixed in: OS: Ubuntu 16.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.11266 (Git) Build type: None Branch: master Hash: ab1b344410600b7d694abf6bb4ff2b71769978c5 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 In the latter I cannot reproduce the reporters issue. I open from the filemanager, switch to Draft WB, select my object (this may even be hidden) and the resulting clone is (nevertheless) shown. |
@wmayer can I close this? |
No, it should be checked if wtrssn or someone else with macOS can still reproduce the issue. IMO, this could be a macOS specific issue because there the mechanism to open a file by double-click works completely different compared to Linux or Windows. For further details have a look at: http://doc.qt.io/qt-5/qfileopenevent.html |
@peterl94 please weigh in on the OSX related ticket...? Thanks! |
I can't reproduce the issue with: OS: Mac OS X [10.12.5] Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6712 (Git) Build type: Release Branch: releases/FreeCAD-0-16 Hash: da2d364457257a7a8c6fb2137cea12c45becd71a Python version: 2.7.11 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 @wtrssn, does it always happen? Does it show up if you change its position after you open it? @Kunda1, I would close this issue if @wtrssn doesn't respond. |
No response from @wtrssn Resolving. |
| 2017-05-17 15:58 | wtrssn | New Issue | |
| 2017-05-17 15:58 | wtrssn | Tag Attached: Clone | |
| 2017-05-17 16:40 | Kunda1 | Note Added: 0009044 | |
| 2017-05-17 17:30 | Kunda1 | Status | new => feedback |
| 2017-05-19 11:55 | Kunda1 | Note Added: 0009056 | |
| 2017-05-26 16:23 | Kunda1 | Note Added: 0009150 | |
| 2017-06-02 00:12 | Kunda1 | Note Added: 0009249 | |
| 2017-06-02 07:28 | wtrssn | Note Added: 0009252 | |
| 2017-06-02 07:28 | wtrssn | Status | feedback => new |
| 2017-06-02 10:35 | Kunda1 | Note Added: 0009253 | |
| 2017-06-02 11:48 | Kunda1 | Summary | Draft -> Clone don feature Does not work when you open file directly => Draft -> Clone feature Does work when you open file directly |
| 2017-06-02 11:48 | Kunda1 | Summary | Draft -> Clone feature Does work when you open file directly => Draft -> Clone feature doesn't work when you open file directly |
| 2017-06-02 11:49 | Kunda1 | Note Added: 0009254 | |
| 2017-06-02 15:37 | Kunda1 | Relationship added | related to 0003066 |
| 2017-06-10 23:20 | abdullah | Note Added: 0009339 | |
| 2017-08-21 20:22 | Kunda1 | Note Added: 0009985 | |
| 2017-08-21 20:22 | Kunda1 | Tag Attached: #tobeclosed | |
| 2017-08-25 09:56 | wmayer | Note Added: 0010005 | |
| 2017-08-25 12:38 | Kunda1 | Note Added: 0010007 | |
| 2017-08-26 20:18 | peterl94 | Note Added: 0010010 | |
| 2017-09-25 13:07 | Kunda1 | Status | new => resolved |
| 2017-09-25 13:07 | Kunda1 | Resolution | open => unable to reproduce |
| 2017-09-25 13:07 | Kunda1 | Note Added: 0010189 | |
| 2017-10-10 11:55 | Kunda1 | Status | resolved => closed |
| 2017-10-10 11:55 | Kunda1 | Tag Detached: #tobeclosed |
