| 0003038 | FEM | Feature | public | 2017-05-18 10:50 | 2018-09-22 11:03 |
| Reporter | Kunda1 | Assigned To | joha2 | ||
| Summary | 0003038: FEM - solver Fenics integration (Ongoing) | ||||
| Description | Integrate the Fenics as a solver for FEM Fenics Project - http://fenicsproject.org/ Goals:
| Additional Information | Forum thread: https://forum.freecadweb.org/viewtopic.php?f=18&t=4677 Dev branch: https://github.com/berndhahnebach/FreeCAD_bhb/tree/femdev | ||||
| Tags | FEM, fenics, Solver(FEM) | ||||
c:FreeCAD:e98d6321bbf261a8ad34114e50c98a43aba72ebc: c:FreeCAD:10dd719631392752a6963e78d872f8b86e083dc6: |
FreeCAD master 7b5adb94 |
@berndhahnebach shall we add to the bug title (Ongoing) or should we resolve ticket? |
BTW: I do not do any development in this regard. Assigning to me make no sense IMHO. May be we could resove the ticket, because the integration will take some time. It is even not clear if it will be integrated in FreeCAD or if it will be a separate module like the CFD analysis. The advantage of haveing such an issue is we could refere to the issue, and we could collect forum links here. bernd |
My dev branch ( https://github.com/berndhahnebach/FreeCAD_bhb/tree/femdev ) is just the half official FEM dev branch where I collect all kind of FEM development from all kind of people and try to resolve any problems before makeing a PR. This just to make it easier for Werner and Yorik. That is why the Fenics mesh stuff was collected in my dev branch. bernd |
@Kunda1 I would suggest, you assign this issue to me. Further I would recommend to (like you suggested) to put (ongoing) into title. This is because it is a large effort to implement an appropriate Fenics interface in FreeCAD and we just went through the very first steps (i.e. mesh import/export). Best wishes Johannes |
Ahh I did not know you have an account Johannes. Than for sure it is best to assign this issue to Johannes (joha2). @Johannes: Do you guys have branch where all the development is taking place or do you go step by step? |
A-Ok @joha2 Soon you will have elevated tracker permissions and we can then assign this ticket to you. |
Thanks @Kunda1 Unfortunately I have no own branch for these Fenics integrations. I just do it step by step and for every new part of the feature I make a new feature branch which is deleted once integrated into master. Best whishes Johannes |
@berndhahnebach ahhh I thought your questions from 2017-07-01 14:07 came from Kunda1, sorry! I think at the moment it's only me who's developing some Fenics interface. Loooo had some nice ideas about a quite generic solver interface which should also be capable to feed Fenics a while ago, but now he is busy porting FreeCAD to python3, afaik. Most of the guys using Fenics told me that the most cumbersome task is to setup a mesh with the appropriate boundary conditions, so I think mesh and selecting parts of it and marking them is the primary task. Up to now for these small enhancements it was not necessary to open up an own branch, therefore I only let you merge small feature branches. (Maybe they are also better for review.) I am not sure if it is really necessary to provide a nice interface like for the calculix solver. Maybe it is sufficient to provide only a raw python scripting interface which loads Fenics and all other necessary modules and also contains the main code of the finite element analysis. Afterwards it would be nice to do the post processing with the vtk interfaces anyway. But these are things to be clarified in the far future. Best wishes Johannes |
. FreeCAD is a bit different (smarter) than most FEM tools, even the quite expensive ones. In FreeCAD FEM we do not select parts of the mesh, we select parts of the geometry instead. All constraints and boundaries are defined at the geometry. Afterwards a smart meshing process generates a mesh which includes all the constraint and boundary groups for the solver. It is what we do with Calculix and z88. The elmer integration (GSoC project) is done the same way. Have you tried some mechanical CalculiX analysis? I like your way of going in small steps and merge them into master immediately. That way we have what we have. We try to do that in FreeCAD mostly. That way we do not produce some dead code branch if someone for some reason has a break in his develpment or stops development at all. In the regard of solver handling and Fenics we could disscuss this if we have something set up what works. In the regard of solver handling in general we will probably see some improvement in FEM soon as a result of the Elmer GSoC project. Stay tuned! keep up the good work bernd |
@Kunda1: I can not reassign this to joha2. Might because he is a reporter and not a developer? bernd |
Hey bernd, yes I think my access level is too low to be assigned to a ticket. I think Kunda1 will lift it to developer, soon. I remember we had some discussion about marking the boundaries and stuff in the Fenics thread. I also tried some mechanical Calculix analyses, but since my OCC kernel is quite old (6.8.0 I think), I had more or less some problems performing them. But the standard one-side fixed beam example worked well. HoWil implemented some Fenics script doing the same model and I performed also a modal analysis for that example in Fenics. Nevertheless I also thought about implementing marking via NodeSets and via tool parts which is a bit incompatible with the mesh groups, but offers some more flexibility (since the mesh functions of Fenics are also quite general.) Maybe we should discuss how all three approaches could be put together appropriately in more detail soon. Best wishes Johannes |
@joha2 I just set your access level to developer. |
@kkremitzki thanks! |
https://github.com/FreeCAD/FreeCAD/pull/923 https://github.com/FreeCAD/FreeCAD/commit/0d471dbed872782c66b5b04a815dc356886c3423 |
@Kunda1 and @berndhahnebach maybe it is trivial, but since this issue is quite outdated I want to add some changesets from the last few months to the changeset history but I cannot find out how. Is it possible that my access level is too low? Best wishes and thanks in advance Johannes |
@joha2 the changeset addon of this bugtracker is very buggy, teoretically you can submit PRs and reference in the commit summary and the changeset should be immediately attached (which doesn't work consistently anymore). You do need a higher permission to add a changeset from within the bugtracker, which is also subject to not working consistently. Let me know which commits and I will manually associate them (if possible under the current buggy conditions). |
@kunda1 thanks for this information. So this means the bugtracker is buggy? Is it a problem of the underlying software? Is this subject to be fixed or is it not fixable? The changesets following are taken from the git commit history from master (my username together with Fenics related stuff) and are ordered from oldest to newest:
Thanks for your efforts. If you need further information, do not hessitate to ask me. Best wishes Johannes |
@joha2 the issue is the MantisBT plugin called SourceIntegration that integrates with Github, it malfunctions in a way that we have to manually manage it most of the time. @kkremitzki have tried working on it. Anyway, if I wrote those commits a certain way and they turn in to link this will tell us which commits are currently recognized by this plugin (note the plugin needs to be bumped since we are behind about 1 month in git commits). c:FreeCAD:785d660dd78fdc7dfd643a88b7f2bf3d54b3e7cc: c:FreeCAD:0b98673c7cb9b490d557bffceab8687e9e2d7989: c:FreeCAD:bd4bc9c2578ecc1d6b07736d22437658137bd1e7: c:FreeCAD:f95ca7185c128a5bfd31a3521269783f4683360f: c:FreeCAD:b611cfc8ed3c08131f8f60571e3aa374eb80edf2: c:FreeCAD:0456928fd13ad328596e435f909af9ae0ebc4d06: c:FreeCAD:8da914fb7036bfc8536227091b3bebc30cb5296d: c:FreeCAD:7161b98a7987fc4e6625b7a73e36732307a7ad9e: c:FreeCAD:fa05b1b068a36b782c29d68b76a25eef649b38ed: c:FreeCAD:0d471dbed872782c66b5b04a815dc356886c3423: c:FreeCAD:90f3aada2df7e9449f879f79effc348d39755753: c:FreeCAD:7072b3f938f328aef315eb95969d7c1142f34650: c:FreeCAD:3b8fa5cb24ff331512c8c0d59456265384ca7c54: c:FreeCAD:ccfe39d115c546027897f32e03ab9e19f6ee3c4b: c:FreeCAD:24452df93e94ee5d8f4dcba9f697dd9b43a96ac9: |
@kkremitzki when you get a chance could you bump the SI plugin ? Thanks |
@kkremitzki thanks for updating SI and bumping commits. As you can see above the plugin is still malfunctioning. By doing a search on FreeCAD/FreeCAD in GH using author-name:joha2 shows many of the above commits have not been pulled in by SourceIntegration. |
https://github.com/FreeCAD/FreeCAD/commit/bf45030595c6f32a5186af53f6bf92b8ae9ecda3 |
I just cleaned FEM issues. I did closed a few of such ongoing issues. Do we really need such ongoing issue? IMHO it is better to open an issue for a specific problem or feature and close it if this specific problem is solved. All this ongoing conversation takes place in the forum ATM. jm2c bernd |
@joha2 per bernd in 0003038:0011794 please open a new ticket related Fenics integration when appropriate. Closing this ticket for now. |
FreeCAD: master d751423d 2017-03-03 09:25:31 joha2 Committer: yorik Details Diff |
FEM: fenics xml mesh format, add mesh import |
Affected Issues 0003038 |
| mod - src/Mod/Fem/Init.py | Diff File | ||
| mod - src/Mod/Fem/importFenicsMesh.py | Diff File | ||
FreeCAD: master 7f72f9ed 2017-03-05 12:16:52 joha2 Committer: yorik Details Diff |
FEM: fenics import/export: one line documentation, fixed make_femmesh call |
FreeCAD: master 85c2e6a1 2017-05-26 15:41:13 joha2 Committer: Yorik van Havre Details Diff |
FEM: Fenics meshes, add support for xdmf format, some more improvements |
| mod - src/Mod/Fem/App/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Fem/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Fem/importToolsFem.py | Diff File | ||
| add - src/Mod/Fem/readFenicsXDMF.py | Diff File | ||
| add - src/Mod/Fem/readFenicsXML.py | Diff File | ||
| add - src/Mod/Fem/writeFenicsXDMF.py | Diff File | ||
| add - src/Mod/Fem/writeFenicsXML.py | Diff File | ||
FreeCAD: master 3708c760 2017-05-26 15:41:17 Bernd Hahnebach Committer: Yorik van Havre Details Diff |
FEM: Fenics meshes, flake8 |
| mod - src/Mod/Fem/readFenicsXDMF.py | Diff File | ||
| mod - src/Mod/Fem/readFenicsXML.py | Diff File | ||
FreeCAD: master 7b5adb94 2017-06-27 05:15:40 joha2 Committer: Bernd Hahnebach Details Diff |
FEM: issue 0003038 Fenics mesh import/export: removed lxml dependency |
| mod - src/Mod/Fem/writeFenicsXDMF.py | Diff File | ||
| mod - src/Mod/Fem/writeFenicsXML.py | Diff File | ||
| 2017-05-18 10:50 | Kunda1 | New Issue | |
| 2017-05-18 10:55 | Kunda1 | Status | new => confirmed |
| 2017-05-26 20:53 | Kunda1 | Changeset attached | => FreeCAD master d751423d |
| 2017-05-26 20:54 | Kunda1 | Changeset attached | => FreeCAD master 7f72f9ed |
| 2017-05-27 00:41 | Kunda1 | Note Added: 0009164 | |
| 2017-05-28 00:05 | Kunda1 | Changeset attached | => FreeCAD master 3708c760 |
| 2017-05-28 00:05 | Kunda1 | Changeset attached | => FreeCAD master 85c2e6a1 |
| 2017-07-01 11:07 | Kunda1 | Note Added: 0009632 | |
| 2017-07-01 11:10 | Kunda1 | Assigned To | => berndhahnebach |
| 2017-07-01 11:10 | Kunda1 | Status | confirmed => assigned |
| 2017-07-01 11:12 | Kunda1 | Note Added: 0009633 | |
| 2017-07-01 11:13 | Kunda1 | Tag Attached: #pending | |
| 2017-07-01 12:25 | berndhahnebach | Note Added: 0009635 | |
| 2017-07-01 12:25 | berndhahnebach | Note Edited: 0009635 | |
| 2017-07-01 12:28 | berndhahnebach | Note Added: 0009636 | |
| 2017-07-01 12:28 | berndhahnebach | Note Edited: 0009636 | |
| 2017-07-01 13:03 | joha2 | Note Added: 0009638 | |
| 2017-07-01 14:07 | berndhahnebach | Note Added: 0009639 | |
| 2017-07-01 21:57 | Kunda1 | Summary | FEM - Fenics integration => FEM - Fenics integration (Ongoing) |
| 2017-07-01 21:57 | Kunda1 | Note Added: 0009642 | |
| 2017-07-01 22:00 | joha2 | Note Added: 0009643 | |
| 2017-07-01 22:01 | joha2 | Note Edited: 0009643 | |
| 2017-07-01 22:03 | joha2 | Tag Attached: FEM | |
| 2017-07-01 22:03 | joha2 | Tag Attached: fenics | |
| 2017-07-02 09:19 | joha2 | Note Added: 0009645 | |
| 2017-07-02 09:55 | berndhahnebach | Note Added: 0009646 | |
| 2017-07-02 09:55 | berndhahnebach | Note Edited: 0009646 | |
| 2017-07-02 09:58 | berndhahnebach | Note Added: 0009647 | |
| 2017-07-02 10:11 | joha2 | Note Added: 0009648 | |
| 2017-07-02 23:27 | kkremitzki | Note Added: 0009650 | |
| 2017-07-03 01:14 | Kunda1 | Assigned To | berndhahnebach => joha2 |
| 2017-07-03 22:28 | joha2 | Note Added: 0009662 | |
| 2017-07-04 00:39 | Kunda1 | Changeset attached | => FreeCAD master 7b5adb94 |
| 2017-07-08 16:05 | berndhahnebach | Summary | FEM - Fenics integration (Ongoing) => FEM - solver Fenics integration (Ongoing) |
| 2017-07-13 11:23 | Kunda1 | Tag Attached: Solver(FEM) | |
| 2017-07-15 14:41 | Kunda1 | Tag Detached: #pending | |
| 2017-08-12 11:55 | wmayer | Note Added: 0009894 | |
| 2018-07-19 22:41 | joha2 | Note Added: 0011538 | |
| 2018-07-19 22:42 | joha2 | Note Edited: 0011538 | |
| 2018-07-19 22:49 | joha2 | Product Version | 0.17 => 0.18 |
| 2018-07-19 22:49 | joha2 | Description Updated | |
| 2018-07-19 22:53 | joha2 | Description Updated | |
| 2018-07-27 13:59 | Kunda1 | Note Added: 0011548 | |
| 2018-07-29 16:41 | joha2 | Note Added: 0011563 | |
| 2018-07-30 00:01 | Kunda1 | Note Added: 0011564 | |
| 2018-08-01 20:13 | Kunda1 | Note Added: 0011579 | |
| 2018-08-03 22:15 | Kunda1 | Note Added: 0011589 | |
| 2018-08-07 15:41 | wmayer | Note Added: 0011603 | |
| 2018-09-18 15:59 | berndhahnebach | Note Added: 0011794 | |
| 2018-09-22 11:03 | Kunda1 | Status | assigned => closed |
| 2018-09-22 11:03 | Kunda1 | Resolution | open => fixed |
| 2018-09-22 11:03 | Kunda1 | Note Added: 0011808 |
