| 0003045 | PartDesign | Bug | public | 2017-05-21 16:10 | 2017-08-13 15:32 |
| Reporter | Hannu | Assigned To | |||
| Summary | 0003045: Fillet, shortcomings(?) | ||||
| Description | My experience since long is that - if the fillet has "less space" than the radius indicates ANYWHERE then the creation fails. This might be a VERY small fault in the structure of the part attachements; zoom in a lot and you might find it, and the remedy has always been a remake of the model parts joint. Now (b, below) I have one that I fail to find a remedy on. | ||||
| Steps To Reproduce | a) Understandable failure: Add a cube (default side is 10mm) Fillet all edges with 4.9mm radius -> OK Redo with 5.0 or more -> Failure b) Not so easy to understand; I hope this is help to fault find the trouble: Attached is Clip.fcstd - In the Combo-view Tree select "Fusion" and then click "Fillet" on the Parts wb, enable Edge 9 and 26, set any(?) radius - click OK -> Crash | ||||
| Additional Information | OS: Ubuntu 16.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6710 (Git) Build type: None Branch: releases/FreeCAD-0-16 Hash: f8eca0f9311f07c125dd6742a607724c1fa0b77c Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
| Tags | fillet, linux, Part Design | ||||
https://forum.freecadweb.org/viewtopic.php?f=3&t=5236 |
Opening the Clip, setting 1.5 or 0.2mm fillet for edge 9 and 26, click OK: --- $ freecad -l FreeCAD 0.16, Libs: 0.16R6710 (Git) © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2015 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## SIGSEGV signal raised Segmentation fault (core dumped) $ --- Can't be more clear. Just try it. |
On Win Fails with "BRep_API" command not done" w/both 0.16.6707 and 0.17.11126 It's a tricky one. 2 pairs of 3 non-planer faces meeting at an edge. If it matters the fillet fails on SW 2012 after export/import by step. |
I see quick "shutdowns" on attempting to fillet almost any edge on the Clip. For a) - the cube - I see the "error" indication in the Combo-view tree appear first at a 8mm fillet, where anything beyond 5 (inclusive) reasonably should indicate. A 7.9mm "fillet" renders as a seemingly random "flower". I often use fillets to strengthen parts that are to be 3D-printed and have seen a number of failures in this manner. FWIW it appears to me that the Fillet function is fairly picky with what it accepts as input. |
@Hannu can you re-attach Clip.fcstd please? We recently restored the tracker from a backup and many attachments didn't make it. Thanks! |
@kunda1 - ok. Done. |
Noted just now: "Select ALL edges" and set 0.9 mm radius (or below) and it works just fine. |
@Hannu what version did you test with? Same one? |
The curvature of Face6 and Face10 don't match where they meet, same thing for the outer faces (Face5 and Face8). Your model has very poor geometry, sgrogan already mentioned the fillet fails in SolidWorks, I'll bet it will fail in an CAD program. You need good geometry to start with. The software needs to blend the joining faces together when creating a fillet, it cannot do so if the faces don't match. This should have been posted in the forum before creating a bug report. IMHO this should be closed as invalid, unless you manage to create a proper model with faces that meet perfectly and still suffer from this issue. |
@Hannu I'm going to resolve this ticket based on NormandC's feedback. If you follow his advice, correct the model and then retest to find the bug still exists; please reopen ticket. But as I pasted above in my reply to you, please follow the guidelines of reporting bugs to FC. Thanks you. |
Closing. |
| 2017-05-21 16:10 | Hannu | New Issue | |
| 2017-05-21 16:10 | Hannu | File Added: Clip.fcstd | |
| 2017-05-21 16:13 | Hannu | Tag Attached: fillet | |
| 2017-05-21 16:13 | Hannu | Tag Attached: linux | |
| 2017-05-21 16:14 | Hannu | Tag Attached: Part Design | |
| 2017-05-21 16:34 | Kunda1 | Note Added: 0009074 | |
| 2017-05-24 23:29 | Hannu | Note Added: 0009131 | |
| 2017-05-24 23:33 | Hannu | Note Edited: 0009131 | |
| 2017-05-25 22:36 |
Note Added: 0009144 | |
| 2017-05-26 11:47 | Hannu | Note Added: 0009146 | |
| 2017-06-24 10:40 | Kunda1 | Status | new => feedback |
| 2017-06-24 10:40 | Kunda1 | Note Added: 0009503 | |
| 2017-06-27 15:07 | Hannu | File Added: Clip-2.fcstd | |
| 2017-06-27 15:07 | Hannu | Note Added: 0009563 | |
| 2017-06-27 15:07 | Hannu | Status | feedback => new |
| 2017-06-27 15:25 | Hannu | Note Added: 0009564 | |
| 2017-06-27 15:37 | Kunda1 | Project | FreeCAD => PartDesign |
| 2017-06-27 15:39 | Kunda1 | Status | new => confirmed |
| 2017-06-27 15:40 | Kunda1 | Note Added: 0009566 | |
| 2017-06-28 05:09 | normandc | Note Added: 0009568 | |
| 2017-06-28 05:14 | normandc | Note Edited: 0009568 | |
| 2017-06-28 12:33 | Kunda1 | Note Added: 0009570 | |
| 2017-06-28 12:35 | Kunda1 | Note Edited: 0009570 | |
| 2017-06-28 12:36 | Kunda1 | Status | confirmed => resolved |
| 2017-06-28 12:36 | Kunda1 | Resolution | open => no change required |
| 2017-08-13 15:32 | Kunda1 | Status | resolved => closed |
| 2017-08-13 15:32 | Kunda1 | Note Added: 0009905 |
