| 0003046 | FreeCAD | Bug | public | 2017-05-23 13:05 | 2017-05-26 21:08 |
| Reporter | glockpod | Assigned To | |||
| Platform | Dell Precision T3500 | OS | Debian Linux | OS Version | Wheezy |
| Summary | 0003046: Wrong number of template arguments NCollection_DataMap<> | ||||
| Description | I am working under Linux Wheezy, having cloned FreeCAD from the git hub, and now using the latest pull from the github. All compile requirements are satisfied, according to CMake. After running make, the compile fails with: ======================================= Now run 'make' to build FreeCAD ======================================= -- Configuring done -- Generating done -- Build files have been written to: /home/chuck/FreeCAD/free-cad-code chuck@glockpod:~/FreeCAD/free-cad-code$ make [ 1%] Built target SMDS [ 1%] Built target MEFISTO2 [ 1%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMESHDS.dir/src/SMESHDS/SMESHDS_Document.cpp.o In file included from /home/chuck/FreeCAD/free-cad-code/src/3rdParty/salomesmesh/inc/SMESHDS_Document.hxx:32:0, from /home/chuck/FreeCAD/free-cad-code/src/3rdParty/salomesmesh/src/SMESHDS/SMESHDS_Document.cpp:29: /home/chuck/FreeCAD/free-cad-code/src/3rdParty/salomesmesh/inc/SMESHDS_Mesh.hxx:62:69: error: wrong number of template arguments (3, should be 2) In file included from /home/chuck/FreeCAD/free-cad-code/src/3rdParty/salomesmesh/inc/SMESHDS_Mesh.hxx:59:0, from /home/chuck/FreeCAD/free-cad-code/src/3rdParty/salomesmesh/inc/SMESHDS_Document.hxx:32, from /home/chuck/FreeCAD/free-cad-code/src/3rdParty/salomesmesh/src/SMESHDS/SMESHDS_Document.cpp:29: /usr/lib/oce-0.9.1/../../include/oce/NCollection_DataMap.hxx:39:54: error: provided for ‘template<class TheKeyType, class TheItemType> class NCollection_DataMap’ In file included from /home/chuck/FreeCAD/free-cad-code/src/3rdParty/salomesmesh/inc/SMESHDS_Document.hxx:32:0, from /home/chuck/FreeCAD/free-cad-code/src/3rdParty/salomesmesh/src/SMESHDS/SMESHDS_Document.cpp:29: /home/chuck/FreeCAD/free-cad-code/src/3rdParty/salomesmesh/inc/SMESHDS_Mesh.hxx:62:88: error: invalid type in declaration before ‘;’ token make[2]: *** [src/3rdParty/salomesmesh/CMakeFiles/SMESHDS.dir/src/SMESHDS/SMESHDS_Document.cpp.o] Error 1 make[1]: *** [src/3rdParty/salomesmesh/CMakeFiles/SMESHDS.dir/all] Error 2 make: *** [all] Error 2 ----- Checking Git just in case something has changed: chuck@glockpod:~/FreeCAD/free-cad-code$ git pull Already up-to-date. --- After wading through the FreeCAD source, it is apparent that this is the problem area: chuck@glockpod:~/FreeCAD/free-cad-code/src/3rdParty/salomesmesh/inc$ grep -n "NCollection_DataMap" *.hxx GEOMUtils.hxx:39:#include <NCollection_DataMap.hxx> GEOMUtils.hxx:116: typedef NCollection_DataMap<TopoDS_Shape, std::pair<double, double> > GEOMUtils_DataMapOfShapeDouble; SMESHDS_DataMapOfShape.hxx:33: * This method needed for instance NCollection_DataMap with TopoDS_Shape as key SMESHDS_Mesh.hxx:57: * So this functionality implement on new NCollection_DataMap technology SMESHDS_Mesh.hxx:59:#include <NCollection_DataMap.hxx> SMESHDS_Mesh.hxx:62:typedef NCollection_DataMap< TopoDS_Shape, THypList, SMESHDS_Hasher > ShapeToHypothesis; ---- Two different ideas of what the arguments for NCollection_DataMap<> should be. I'm not sure how this was missed, as you all seem to be making changes, and gliding right by the problem... -Chuck | ||||
| Steps To Reproduce | Debian Wheezy with all of the latest upgrades, 1)Install the necessary requirements per the Unix compile on this website 2) git clone https://github.com/FreeCAD/FreeCAD.git free-cad-code 3) cmake -DFREECAD_USE_EXTERNAL_PIVY=1 -DCMAKE_BUILD_TYPE=Release 4) make And the failure appears. | ||||
Please open a forum thread per https://forum.freecadweb.org/viewtopic.php?f=3&t=5236 |
Hmm, I tried to open a forum thread, per your link, but how one does that truly isn't obvious to me. "Report Issue" is right there on the side of this screen for all to see, Open a forum thread is nowhere to be found. But no matter, I did all of the things the link you referenced asked: I checked to see if the problem had been reported, it hadn't. I made sure I was using the latest FreeCAD version, I was. I didn't just think it might be a bug, it is a bug. I showed how to reveal the problem. I showed exactly where in the FreeCAD source the problem was. I would fix it myself, but I thought I would try to give something back to the community, I guess protocol is more important.... though not important enough to make opening a thread easily done. So what is the problem? Do you want to know about this bug, or not? -Chuck |
@glockpod thanks for making the effort to report an issue. That's not something we want to discourage. Just the opposite we welcome the feedback. The issue here is more on our end to make it more streamlined for the community to troubleshoot issues. Most of the activity of the FC community is via the forums. In other words you would get way more exposure and potentially faster response times posting directly to it. There are very few active bugtracker volunteers. That's the gist. The forum to post in would be the Install and Compile section: https://forum.freecadweb.org/viewforum.php?f=4 |
Ok, thanks. I have submitted my issue to the Compile/Install forum. I think I have introduced some typo's in my attempt at recreating the above report there, but I hope it won't be too bad. -Chuck |
Forum thread: https://forum.freecadweb.org/viewtopic.php?f=4&t=22617 |
Resolving issue per ickby in https://forum.freecadweb.org/viewtopic.php?f=4&t=22617&p=175296#p175296 Reason: inferior OCC version being used. |
| 2017-05-23 13:05 | glockpod | New Issue | |
| 2017-05-23 16:24 | Kunda1 | Note Added: 0009100 | |
| 2017-05-23 16:43 | glockpod | Note Added: 0009101 | |
| 2017-05-23 19:27 | Kunda1 | Note Added: 0009103 | |
| 2017-05-23 19:49 | glockpod | Note Added: 0009105 | |
| 2017-05-23 20:35 | Kunda1 | Note Added: 0009106 | |
| 2017-05-24 07:12 | Kunda1 | Status | new => resolved |
| 2017-05-24 07:12 | Kunda1 | Resolution | open => no change required |
| 2017-05-24 07:12 | Kunda1 | Note Added: 0009108 | |
| 2017-05-26 21:08 | Kunda1 | Status | resolved => closed |
