| 0003048 | Path | Bug | public | 2017-05-26 21:32 | 2017-07-18 16:07 |
| Reporter | mlampert | Assigned To | sliptonic | ||
| Summary | 0003048: Individual Path visibility not maintained across restarts | ||||
| Description | Loading a document makes all individual Path features (like a Contour or Profile) visible, regardless of their state when the document was saved. In order to hide a Path it is currently necessary to set visibility of the feature in question /and/ its Job to false - only the Job's setting is restored when the document is loaded. | ||||
Some more observations ... it seems the visibility is properly maintained after all. Loading a file restores all individual Path's visibility setting the way they were saved. However each one of them requires a recompute (not sure why) - and the recompute sets the Path to visible. This can easily be verified by setting the visibility of a Path to false, then "Mark to recompute" and finally pressing the recomupte button. |
I can't duplicate this. Are you still seeing it? I've tested with both the recompute method and the save/restore and it seems to be preserving state for me. |
The behaviour has slightly changed. Visibility seems to be maintained during save/restore. However, an individual Path will make itself visible whenever it is recomputed. * turn visibility of a profile off * mark to recompute * recompute -> profile is visible again This is a different issue as the original one - we can close this on and create a new one or keep this one. |
FreeCAD Pull Request 865 |
FreeCAD: master 48337e03 2017-07-08 15:16:03 sliptonic Committer: Yorik van Havre Details Diff |
Path: fix 0003048 Visibility on recompute is now preserved |
Affected Issues 0003048 |
| mod - src/Mod/Path/PathScripts/PathDrilling.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathEngrave.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathMillFace.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathPocket.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathProfile.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathProfileEdges.py | Diff File | ||
| 2017-05-26 21:32 | mlampert | New Issue | |
| 2017-05-28 01:15 | mlampert | Note Added: 0009175 | |
| 2017-07-08 16:45 | sliptonic | Note Added: 0009688 | |
| 2017-07-08 17:48 | mlampert | Note Added: 0009691 | |
| 2017-07-11 23:14 | sliptonic | Assigned To | => sliptonic |
| 2017-07-11 23:14 | sliptonic | Status | new => closed |
| 2017-07-11 23:14 | sliptonic | Resolution | open => fixed |
| 2017-07-11 23:14 | sliptonic | Fixed in Version | => 0.17 |
| 2017-07-11 23:14 | sliptonic | Note Added: 0009723 | |
| 2017-07-18 16:07 | Kunda1 | Changeset attached | => FreeCAD master 48337e03 |
