0003073FreeCADFeaturepublic2021-02-06 06:50
ReporterEscain Assigned To
PrioritynoneSeverityfeatureReproducibilityrandom
Status confirmedResolutionopen
PlatformPCOSLinux DebianOS VersionJessie 8.8
Product Version0.16
Target Version0.20
Summary0003073: "Labels & Attributes" tree mix-up randomly elements
DescriptionWhat I do:
I have several files, with several objects inside each. Elements are commonly default parts, sketchs and many boolean operations between.
I select elements in one file, Ctrl+C to copy and select "No" to get a simple copy.
In the other file, I paste with Ctrl+V
What happens:
For the few 10 elements, usually all is fine, after, the tree (where I paste) start to mix elements:
- Files name is replace by "Unnamed"
- Objects become sub-elements of others where they are unrelated
- Objects disappear
- Objects name start to point other objects in the view (e.g. I had a "Coin" for comparative size. The element "Coin" suddenly where pointing to my main part).
Apart of that, I want to congratulate you for this wonderful software!! I love it.
Steps To ReproduceIt seem random, it happens often, but I did not found a clear step-by-step.
Additional InformationOS: Debian GNU/Linux 8.8 (jessie)
Version: 0.16.
Build type: None
Python version: 2.7.9
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
2017-06-06 18:40
administrator   ~0009296
Please open a forum thread and bi-directionally connect ticket <=> thread
2017-06-06 18:48
administrator   ~0009299
@yorik is that well known click/drag tree bug?
yorik
2017-06-06 20:27
administrator   ~0009301
No, never seen that before...
2017-06-10 04:45
administrator   ~0009325
Forum thread opened: https://forum.freecad.org/viewtopic.php?f=8&t=22874
2017-06-12 22:00
administrator   ~0009352
Per @wmayer in the forum thread, I've changed this ticket from bug to feature
yorik
2022-03-03 13:55
administrator   ~0016544
This ticket has been migrated to GitHub as issue 5709.
2017-06-05 16:12 Escain New Issue
2017-06-06 18:40 Kunda1 Note Added: 0009296
2017-06-06 18:41 Kunda1 Status new => feedback
2017-06-06 18:41 Kunda1 Priority high => normal
2017-06-06 18:41 Kunda1 Severity block => minor
2017-06-06 18:48 Kunda1 Note Added: 0009299
2017-06-06 20:27 yorik Note Added: 0009301
2017-06-07 12:13 Kunda1 Priority normal => high
2017-06-07 12:13 Kunda1 Severity minor => major
2017-06-07 12:14 Kunda1 Tag Attached: #post-to-forum
2017-06-10 04:45 Kunda1 Note Added: 0009325
2017-06-11 11:01 wmayer Status feedback => confirmed
2017-06-11 11:28 wmayer Priority high => none
2017-06-11 11:28 wmayer Severity major => feature
2017-06-12 22:00 Kunda1 Category Bug => Feature
2017-06-12 22:00 Kunda1 Summary "Labels & Attributes" tree mix-up randombly elements => "Labels & Attributes" tree mix-up randomly elements
2017-06-12 22:00 Kunda1 Note Added: 0009352
2017-06-14 12:30 Kunda1 Tag Detached: #post-to-forum
2021-02-06 06:50 abdullah Target Version => 0.20
