0003074SketcherBugpublic2017-08-13 15:37
ReporterSparkyCola Assigned To
PrioritylowSeveritytrivialReproducibilitysometimes
PlatformDesktopOSUbuntuOS Version16.10
Product Version0.17
Summary0003074: When in sketch editing there is no response to File->Open (GUI should indicate operation is not supported)
DescriptionWhen I'm in sketch editing and even hit Ctrl+O or click on File->Open nothing happens, however after exiting the editing everything works just fine.
Steps To ReproduceJust open the sketch editing and try to open a new file (shortcut and menu have been tested)
Additional InformationOS: Ubuntu 16.10
Version: 0.17.11224 (Git)
Build type: None
Hash: d52f9f5d1a0c38a1a1b669fe694175cbd07d8d06
Python version: 2.7.12+
Qt version: 4.8.7
OCC version: 7.1.0
2017-06-06 18:43
administrator   ~0009297
@Abdullah can you reproduce?
hinckel
2017-06-06 19:32
reporter   ~0009300
This is standard behaviour. One should not open a file during sketch editing session.
SparkyCola
2017-06-06 21:20
developer   ~0009302
I guessed so and it should probably be this way but I think FreeCAD should tell you that if you're trying to do it. A dialog like would make it obvious to the user that he did something he/she's not supposed to do in this way.
abdullah
2017-06-07 12:41
manager   ~0009305
@kunda
As per you request:
It is accepted standard UI behaviour that when the program is in a special mode, the menu options that are not applicable are grayed out. A user that sees a grayed out option should assume that such option is not available, as per standard UI behaviour.
Like in any other software, it is a software requirement that a user can reasonably realize what action he should undertake to exit such special mode. It is my opinion that a user in sketch edit mode has the knowledge that he is in a special mode and that there is no much searching to do to find the button to get out of this mode.
As for the usage of Ctrl+O, it is to be expected that a user that uses the standard shortcut without reaching the expected goal would go to the menu and realize of the grayed out situation, so defaulting to the previous reasons.
There are three points:
1. It is grayed out => it is intended, it is a feature, it is standard in special modes.
2. I receive no further feedback => it is intended, it is a feature, it is standard in special modes.
3. I can not find how to exit edit mode => this is open to opinion whether it is sufficiently clear, I think it is clear enough by little experimenting, but that is just an opinion.
2017-06-07 21:02
administrator   ~0009308
Thanks Abdullah. Resolving ticket.
2017-08-13 15:37
administrator   ~0009910
Closing.
2017-06-05 17:18 SparkyCola New Issue
2017-06-06 18:43 Kunda1 Note Added: 0009297
2017-06-06 19:32 hinckel Note Added: 0009300
2017-06-06 21:20 SparkyCola Note Added: 0009302
2017-06-07 12:20 Kunda1 Summary When in sketch editing there is no response to open file => When in sketch editing there is no response to File->Open (GUI should indicate operation is not supported)
2017-06-07 12:41 abdullah Note Added: 0009305
2017-06-07 21:02 Kunda1 Status new => resolved
2017-06-07 21:02 Kunda1 Resolution open => no change required
2017-06-07 21:02 Kunda1 Note Added: 0009308
2017-08-13 15:37 Kunda1 Status resolved => closed
2017-08-13 15:37 Kunda1 Note Added: 0009910
