| 0003090 | Path | Feature | public | 2017-06-16 13:13 | 2017-06-18 21:05 |
| Reporter | nahshon | Assigned To | |||
| Summary | 0003090: There is no default Units schema translation for Unit::Velocity | ||||
| Description | Velocity will show as mm/s independent of the units schema selected. AFAIK this only affects the display of tool controls feed rate in the path module. (Fixed in my branch, a pull request will follow). | ||||
| related to | 0001978 | closed | FreeCAD | App::PropertySpeed needs units extended |
OP submitted fixes in FreeCAD Pull Request 821 CC @sliptonic |
Is this the same issue as 0001978? |
Yes, it is same as 0001978 |
https://github.com/FreeCAD/FreeCAD/commit/634cbf156639e3f4224080b4292f1ae095f7c34a |
@sliptonic does the fix wmayer applied also address 0001978 ? |
| 2017-06-16 13:13 | nahshon | New Issue | |
| 2017-06-16 14:31 | Kunda1 | Note Added: 0009411 | |
| 2017-06-16 15:35 | sliptonic | Note Added: 0009414 | |
| 2017-06-16 15:37 | Kunda1 | Note Edited: 0009414 | |
| 2017-06-17 20:46 | nahshon | Note Added: 0009423 | |
| 2017-06-18 15:22 | wmayer | Status | new => closed |
| 2017-06-18 15:22 | wmayer | Resolution | open => fixed |
| 2017-06-18 15:22 | wmayer | Note Added: 0009447 | |
| 2017-06-18 17:14 | Kunda1 | Note Added: 0009451 | |
| 2017-06-18 21:05 | wmayer | Relationship added | related to 0001978 |
