0003091SketcherBugpublic2018-08-26 15:22
Reporterulrich1a Assigned Toabdullah
Status closedResolutionfixed
Product Version0.17
Fixed in Version0.17
Summary0003091: Sketcher Polyline Arc: auto point on object constraint gets applied to wrong vertex
DescriptionThe bug is present in the sketcher polyline tool at drawing an arc. When the arc should end at another object, the automatic constraint is applied to the start of the arc instead of the end of the arc.
Steps To Reproduce1. create a sketch
2. choose the polyline tool and draw a line
3. hit the "m"-key three times to enter the arc-mode
4. draw the arc to an axis, so that the point on object constraint appears and click
The constraint is now applied to the start of the arc and not to the end of the arc.
Additional InformationTested version which does have the bug. FreeCAD 0.16, linux. FreeCAD 0.17, 64 bit Linux and Windows version.
See pictures below, showing the sketch before and after the application of point on object constraint.
Forum thread: https://forum.freecad.org/viewtopic.php?f=8&t=23044
Tagsconstraints
ulrich1a
2017-06-17 15:45
reporter
ulrich1a
2017-06-17 15:58
reporter   ~0009421
OS: Debian GNU/Linux 8.8 (jessie)
Version: 0.17.11301 (Git)
Branch: Rueck6
Hash: 76822e26e476da24772296b1d62cb84780eff79e
Python version: 2.7.9
Qt version: 4.8.6
OCC version: 7.1.0
2017-06-17 20:06
administrator   ~0009422
@ulrich1a has anyone reproduced this on the forums?
ulrich1a
2017-06-18 10:57
reporter   ~0009444
I did not report on the forums. I tested myself with 3 different versions of FreeCAD on two different operating systems.
2017-06-21 10:32
administrator   ~0009475
Added forum thread as per guidelines.
2017-06-21 12:44
administrator   ~0009481
Confirmed by @bejant on the forum
2017-06-29 17:00
administrator   ~0009614
@abdullah have anytime to look at this sketcher polyline bug?
abdullah
2017-07-01 11:18
manager   ~0009634
@Kunda1
ATM I am under heavy load from my job, so I cannot act in a short time. I will leave the notification email unread so as to handle it after the current storm of work.
abdullah
2017-12-07 05:56
manager   ~0010531
https://github.com/FreeCAD/FreeCAD/pull/1150
2017-12-07 10:37
administrator   ~0010539
https://github.com/FreeCAD/FreeCAD/commit/324c31d4e21e80f1e00f51fb4ddd78a2385dbeb1
2017-06-17 15:45 ulrich1a New Issue
2017-06-17 15:45 ulrich1a File Added: Sketcher_polyline_bug1.png
2017-06-17 15:45 ulrich1a File Added: Sketcher_polyline_bug2.png
2017-06-17 15:58 ulrich1a Note Added: 0009421
2017-06-17 20:05 Kunda1 Tag Attached: constraints
2017-06-17 20:06 Kunda1 Note Added: 0009422
2017-06-18 10:57 ulrich1a Note Added: 0009444
2017-06-21 10:27 Kunda1 Tag Attached: #post-to-forum
2017-06-21 10:32 Kunda1 Additional Information Updated
2017-06-21 10:32 Kunda1 Note Added: 0009475
2017-06-21 10:32 Kunda1 Tag Detached: #post-to-forum
2017-06-21 12:44 Kunda1 Status new => confirmed
2017-06-21 12:44 Kunda1 Note Added: 0009481
2017-06-29 17:00 Kunda1 Note Added: 0009614
2017-06-29 17:01 Kunda1 Tag Attached: #pending
2017-07-01 11:18 abdullah Note Added: 0009634
2017-12-07 05:56 abdullah Assigned To => abdullah
2017-12-07 05:56 abdullah Status confirmed => assigned
2017-12-07 05:56 abdullah Note Added: 0010531
2017-12-07 10:37 wmayer Status assigned => closed
2017-12-07 10:37 wmayer Resolution open => fixed
2017-12-07 10:37 wmayer Fixed in Version => 0.17
2017-12-07 10:37 wmayer Note Added: 0010539
2018-08-26 15:22 Kunda1 Tag Detached: #pending
