| 0003094 | Draft | Bug | public | 2017-06-22 10:02 | 2017-07-04 00:42 |
| Reporter | chrisb | Assigned To | wandererfan | ||
| Summary | 0003094: ShapeString: Tracking is not a distance but a factor | ||||
| Description | The Tracking of a ShapeString should be the distance between characters. In the attached example a tracking value of 1000mm leads in fact to a tracking of 8.3 mm. It is dependent on the font and it's size. In the discussion thread wandererfan has already pointed out how the tracking is calculated. | ||||
| Steps To Reproduce |
| Additional Information | The attached file has two ShapeStrings one with and one without tracking. Additionally there is a sketch showing the distance. To check what happens with different tracking values open the sketch, change to the data tab of the tree and change the parameters tracking and size. The Sketch updates the tracking distance. The ShapeStrings use the fontfiles from a ubuntu system, other fonts may break the sketch and you may have to reattach it and recreate the external geometry. | ||||
| Tags | shapestring | ||||
ADMIN: This bug is in Draft, not PartDesign. |
Thanks wf ATM some technical difficulty is hindering me from doing that. Once that gets solved I'll move the ticket. Thanks! |
@wandererfan fix committed in FreeCAD master 674aabe8 |
FreeCAD: master 674aabe8 2017-06-24 20:11:28 WandererFan Details Diff |
fix 0003094 ShapeString tracking |
Affected Issues 0003094 |
| mod - src/Mod/Part/App/FT2FC.cpp | Diff File | ||
FreeCAD: master f919345e 2017-06-26 09:08:47 Yorik van Havre Committer: GitHub Details Diff |
Merge pull request 0000836 from WandererFan/SSTrack fix 0003094 ShapeString tracking |
| 2017-06-22 10:02 | chrisb | New Issue | |
| 2017-06-22 10:02 | chrisb | File Added: shapeStringTracking.fcstd | |
| 2017-06-24 14:52 | wandererfan | Assigned To | => wandererfan |
| 2017-06-24 14:52 | wandererfan | Status | new => confirmed |
| 2017-06-24 14:52 | wandererfan | Note Added: 0009520 | |
| 2017-06-24 16:01 | Kunda1 | Tag Attached: shapestring | |
| 2017-06-24 16:11 | Kunda1 | Note Added: 0009521 | |
| 2017-06-25 00:16 | kkremitzki | Project | PartDesign => Draft |
| 2017-06-26 15:30 | Kunda1 | Note Added: 0009545 | |
| 2017-06-26 15:34 | Kunda1 | Status | confirmed => assigned |
| 2017-06-26 17:27 | wmayer | Status | assigned => closed |
| 2017-06-26 17:27 | wmayer | Resolution | open => fixed |
| 2017-06-26 17:27 | wmayer | Fixed in Version | => 0.17 |
| 2017-07-04 00:40 | Kunda1 | Changeset attached | => FreeCAD master f919345e |
| 2017-07-04 00:42 | Kunda1 | Changeset attached | => FreeCAD master 674aabe8 |
