0003097PathFeaturepublic2017-07-11 23:15
ReporterKonstantin Assigned Tosliptonic
PrioritynormalSeverityfeatureReproducibilityhave not tried
Status closedResolutionfixed
Summary0003097: Drill bit tip angle compensation
DescriptionAs I spoke here.
Drill tip has some angle, which i can specify in Tool Table. Need to use that in drilling depth calculation. For example:
I need a hole 10mm diameter 20 mm deep. The angle of drill bit is 120°. So in fact it should drill to ~-22.9mm.
And more, add an option in Drill tool for additional depth for through holes, to be able to go a bit deeper.
TagsDrilling
2017-06-28 21:52
administrator   ~0009584
Changed to 'Feature'
sliptonic
2017-07-11 23:15
manager   ~0009724
FreeCAD Pull Request 865
2017-06-24 09:31 Konstantin New Issue
2017-06-24 09:31 Konstantin Tag Attached: Drilling
2017-06-24 09:31 Konstantin Tag Attached: Path
2017-06-24 10:31 Kunda1 Tag Detached: Path
2017-06-28 21:51 Kunda1 Category Patch => Feature
2017-06-28 21:52 Kunda1 Note Added: 0009584
2017-07-11 23:15 sliptonic Assigned To => sliptonic
2017-07-11 23:15 sliptonic Status new => closed
2017-07-11 23:15 sliptonic Resolution open => fixed
2017-07-11 23:15 sliptonic Note Added: 0009724
