| 0003100 | Path | Bug | public | 2017-06-24 11:24 | 2017-08-13 15:21 |
| Reporter | Konstantin | Assigned To | sliptonic | ||
| Summary | 0003100: Different behavior of Clearance parameter in Face milling | ||||
| Description | In attached file you can see three tools are used. Don't know why, but Face mill tool sets it's Clearance to 10.0. Other tools sets to 35.0. Face mill is doing it wrong. Attached generated code to. | ||||
| Steps To Reproduce | To reproduce - in my file I create Job, Change tool to face mill, press Facing operation button, press Ok. Clearance is set to 10, which in fact will be inside of my blank. | ||||
| Additional Information | OS: "Manjaro Linux" Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.11432 (Git) Build type: Release Branch: master Hash: 0768ae99cfd6036601f66658f6e0f923de9af6f2 Python version: 2.7.13 Qt version: 4.8.7 Coin version: 3.1.3 OCC version: 7.1.0 | ||||
Missing attachment + has duplicate 3101,3102 (edit: I've deleted those tickets now) |
@Konstantin thx for your bug reports please familiarize yourself with how to report bugs in FC http://forum.freecadweb.org/viewtopic.php?f=3&t=5236 |
Changed from 'patch' to 'bug' |
Sorry, I couldn't attach my file (it says something "file does not exists"), and didn't know, that it still posts my bug. Why is that? Wrong file format? To big? Or it's just because my connection lagging today? I have wrote the bug submission guideline but didn't found anything about it. Sorry, once again. |
Here's full textInvalid upload path. Directory either does not exist or not writable to webserver. |
@konstantin no worries, per FC guidelines we encourage opening a thread first to discuss the issue with the community. Many issues get resolved that way before needing to be posted to the tracker. There is a size limit on attachments in the tracker, if you exceed it you can always upload to s third party cloud-like service and link to it from the ticket. |
@konstantin thanks for reporting that. Looks like a tracker problem. CC @kkremitzki |
Sorry, created a thred in forum with attachments. Here it is |
Confirmed. If PathMillFace is working on the entire solid, it doesn't guess at depths correctly. It uses a unique logic. I'll probably fix this in two steps. First a quick hack to get the clearance height right. The better solution is to move the setDepths logic used in other operations into the PathUtils module and have it return a depth_params object which the operations can then use to set their starting values. setDepths needs to be expanded a bit to handle subelement selection though. |
FreeCAD Pull Request 847 |
Closing |
| 2017-06-24 11:24 | Konstantin | New Issue | |
| 2017-06-24 11:29 | Kunda1 | Note Added: 0009508 | |
| 2017-06-24 11:30 | Kunda1 | Note Added: 0009509 | |
| 2017-06-24 11:38 | Kunda1 | Category | Patch => Bug |
| 2017-06-24 11:38 | Kunda1 | Note Added: 0009510 | |
| 2017-06-24 11:39 | Konstantin | Note Added: 0009511 | |
| 2017-06-24 11:39 | Kunda1 | Note Edited: 0009508 | |
| 2017-06-24 11:41 | Konstantin | Note Added: 0009512 | |
| 2017-06-24 11:42 | Kunda1 | Note Added: 0009513 | |
| 2017-06-24 11:43 | Kunda1 | Note Edited: 0009512 | |
| 2017-06-24 11:44 | Kunda1 | Note Added: 0009514 | |
| 2017-06-24 11:52 | Konstantin | Note Added: 0009515 | |
| 2017-06-24 13:56 | sliptonic | Note Added: 0009518 | |
| 2017-06-24 13:56 | sliptonic | Assigned To | => sliptonic |
| 2017-06-24 13:56 | sliptonic | Status | new => assigned |
| 2017-06-29 18:44 | sliptonic | Status | assigned => resolved |
| 2017-06-29 18:44 | sliptonic | Resolution | open => fixed |
| 2017-06-29 18:44 | sliptonic | Note Added: 0009615 | |
| 2017-08-13 15:21 | Kunda1 | Status | resolved => closed |
| 2017-08-13 15:21 | Kunda1 | Fixed in Version | => 0.17 |
| 2017-08-13 15:21 | Kunda1 | Note Added: 0009900 |
