| 0003105 | FreeCAD | Bug | public | 2017-06-25 11:12 | 2017-06-28 14:37 |
| Reporter | sadskull | Assigned To | yorik | ||
| Summary | 0003105: Arch fails to load with 'ascii' codec can't decode byte 0xc2 in position 22: ordinal not in range(128) | ||||
| Description | When loading the Arch workbench, the following error message appears in a window titled "Defective workbench":
The python console displays:
The error happens in French rather than in English. Adding following code to file /usr/lib/freecad-daily/Mod/Draft/DraftTools.py after line 41 works around the issue:
| Steps To Reproduce | 1. Set FreeCAD language to French: Edit -> Preferences -> General -> Language -> Français 2. Load Arch workbench | ||||
| Additional Information | OS: Debian GNU/Linux 9.0 (stretch) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.11432 (Git) Build type: None Branch: master Hash: 0768ae99cfd6036601f66658f6e0f923de9af6f2 Python version: 2.7.13 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 | ||||
| Tags | Arch, crash, GUI, linux, locale, python, Start Workbench | ||||
CC @normandc |
Please write bug reports in English!!! Most people simply do not speak French. I have translated the report. |
Deleting external image link from report description since OP uploaded it. |
My system is suffering from the same bug. This is related to the Draft workbench failing to load. See forum topic https://forum.freecadweb.org/viewtopic.php?f=4&t=23106 OS: Ubuntu 16.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.11433 (Git) Build type: Unknown Branch: master Hash: 3ada1416bad6518f3ee69bbcf7e11bbcbb2ff7ee Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 |
As I wrote previously the real problem is caused by the Draft workbench failing to load. I'm not sure if I should create a separate bug report and link it to this one. |
I tested the following accented languages: Čeština Português do Brasil Español de España Slovenčina So far only French is affected by the issue. |
This should be fixed with commit 3ada1416bad65 |
As per my comment https://freecadweb.org/tracker/view.php?id=3105#c9530 commit 3ada1416 does not fix the issue. |
@sadskull please test fix on latest v0.17 revision. Thanks! |
Hi @Kunda1 revision 11455, always the same issue. |
Does revision 11455 include git commit 3ada1416 ? |
You need to test with revision 11456 or later. Commit 859b94e is the one that fixes the issue for me. Tested on OS: Ubuntu 16.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.11457 (Git) Build type: Unknown Branch: master Hash: b41624590d4b2d734588456655fa7fb30f9dac15 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 https://github.com/FreeCAD/FreeCAD/commit/859b94e311e5e62d44e712115b2351bf655aa0ce 3ada1416 was revision 11433, it's old news, please read my two previous comments. |
Hi Yep, it's fixe the issue for me too. |
Great! Thanks to all involved. Fix by yorik in FreeCAD master 859b94e3 |
| 2017-06-25 11:12 | sadskull | New Issue | |
| 2017-06-25 11:12 | sadskull | Tag Attached: Arch | |
| 2017-06-25 11:12 | sadskull | Tag Attached: crash | |
| 2017-06-25 11:12 | sadskull | Tag Attached: GUI | |
| 2017-06-25 11:12 | sadskull | Tag Attached: linux | |
| 2017-06-25 11:12 | sadskull | Tag Attached: python | |
| 2017-06-25 11:12 | sadskull | Tag Attached: Start Workbench | |
| 2017-06-25 11:20 | sadskull | File Added: Freecad.png | |
| 2017-06-25 12:31 | Kunda1 | Description Updated | |
| 2017-06-25 12:31 | Kunda1 | Note Added: 0009523 | |
| 2017-06-25 12:32 | Kunda1 | Assigned To | => normandc |
| 2017-06-25 12:32 | Kunda1 | Status | new => assigned |
| 2017-06-25 15:59 | normandc | Assigned To | normandc => |
| 2017-06-25 15:59 | normandc | Summary | 'ascii' codec can't decode byte 0xc2 in position 22: ordinal not in range(128) => Arch fails to load with 'ascii' codec can't decode byte 0xc2 in position 22: ordinal not in range(128) |
| 2017-06-25 15:59 | normandc | Description Updated | |
| 2017-06-25 15:59 | normandc | Steps to Reproduce Updated | |
| 2017-06-25 15:59 | normandc | Note Added: 0009528 | |
| 2017-06-25 16:01 | normandc | Description Updated | |
| 2017-06-25 16:01 | normandc | Note Added: 0009529 | |
| 2017-06-25 16:01 | normandc | Note Edited: 0009529 | |
| 2017-06-25 16:07 | normandc | Note Added: 0009530 | |
| 2017-06-25 16:08 | normandc | Assigned To | => yorik |
| 2017-06-25 16:08 | normandc | Status | assigned => confirmed |
| 2017-06-25 16:09 | normandc | Note Edited: 0009530 | |
| 2017-06-25 16:12 | normandc | Note Edited: 0009530 | |
| 2017-06-25 16:16 | normandc | Note Added: 0009531 | |
| 2017-06-25 16:25 | normandc | Note Added: 0009532 | |
| 2017-06-26 13:25 | Kunda1 | Tag Attached: locale | |
| 2017-06-26 13:58 | yorik | Note Added: 0009539 | |
| 2017-06-26 14:10 | normandc | Note Added: 0009544 | |
| 2017-06-27 11:40 | Kunda1 | Status | confirmed => feedback |
| 2017-06-27 11:40 | Kunda1 | Note Added: 0009560 | |
| 2017-06-27 12:14 | sadskull | Note Added: 0009561 | |
| 2017-06-27 12:14 | sadskull | Status | feedback => assigned |
| 2017-06-27 12:59 | Kunda1 | Note Added: 0009562 | |
| 2017-06-28 03:42 | normandc | Note Added: 0009567 | |
| 2017-06-28 12:25 | Kunda1 | Status | assigned => feedback |
| 2017-06-28 14:33 | sadskull | Note Added: 0009579 | |
| 2017-06-28 14:33 | sadskull | Status | feedback => assigned |
| 2017-06-28 14:36 | Kunda1 | Status | assigned => closed |
| 2017-06-28 14:36 | Kunda1 | Resolution | open => fixed |
| 2017-06-28 14:36 | Kunda1 | Note Added: 0009580 | |
| 2017-06-28 14:37 | Kunda1 | Fixed in Version | => 0.17 |
| 2017-06-28 14:37 | Kunda1 | Note Edited: 0009580 |
