0003106SketcherBugpublic2017-12-15 16:05
Reportergraffy Assigned To
PlatformLinuxOSMintOS Version18.1
Product Version0.16
Target Version0.17
Summary0003106: Sketches do not retain custom grid sizes
DescriptionChanging the size of a grid in a sketch is not retained if the user exits eidting mode and then re-enters it. Other sketch properties appear to be retained properly.
Steps To Reproduce1. Create new sketch
2. Change the grid size
3. Exit Edit Mode
4. Re-enter Edit Mode
Additional InformationNo associated error messages.
OS: Linux Mint 18.1 Serena
Version: 0.16.6707 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Hash: 5465bc47c95db45e0be85dc0e2872419efadce0f
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
graffy
2017-06-26 13:24
reporter   ~0009538
If the grid spacing is set in the Edit Controls drop down under the Tasks tab, it appears the value is retained.
Editing it in the Property / Value grid control under the Model tab, however appears to be broken.
2017-06-26 16:08
administrator   ~0009547
@chrisb do you mind trying to reproduce this? OP says he can reproduce on 0.17 as well (not sure the which 0.17 revision though)
2017-12-12 03:11
administrator   ~0010579
Forum thread: https://forum.freecadweb.org/viewtopic.php?f=8&t=25831
chrisb
2017-12-12 07:12
developer   ~0010581
I cannot confirm. This version below saves the grid size even after closing FreeCAD.
More about the behaviour in the Help Forum
OS: Ubuntu 16.04.3 LTS
Version: 0.17.12802 (Git)
Build type: None
Hash: 91bb7ed0c51ba47f011199af7bc0a3a2964cf5be
Python version: 2.7.12
Qt version: 4.8.7
OCC version: 7.1.0
2017-12-12 13:56
administrator   ~0010582
Thanks chrisb, @graffy can you reproduce on the latest AppImage of 0.17 ?
chrisb
2017-12-12 14:18
developer   ~0010583
It's not a bug since the grid does not belong to the sketch it is an editing aid and the preset values are saved until reentering Sketcher.
abdullah
2017-12-15 13:04
manager   ~0010603
@kunda1
If this is not reproducible, should we close it?
chrisb
2017-12-15 13:05
developer   ~0010604
Yes please.
2017-12-15 16:05
administrator   ~0010605
Done
2017-06-26 11:06 graffy New Issue
2017-06-26 13:24 graffy Note Added: 0009538
2017-06-26 15:19 Kunda1 Additional Information Updated
2017-06-26 16:08 Kunda1 Note Added: 0009547
2017-09-25 06:16 wmayer Target Version => 0.17
2017-09-30 15:59 Kunda1 Tag Attached: #post-to-forum
2017-12-12 03:11 Kunda1 Note Added: 0010579
2017-12-12 03:11 Kunda1 Tag Detached: #post-to-forum
2017-12-12 07:12 chrisb Note Added: 0010581
2017-12-12 13:56 Kunda1 Note Added: 0010582
2017-12-12 13:57 Kunda1 Tag Attached: #tobeclosed
2017-12-12 14:18 chrisb Note Added: 0010583
2017-12-15 13:04 abdullah Note Added: 0010603
2017-12-15 13:05 chrisb Note Added: 0010604
2017-12-15 16:05 Kunda1 Status new => closed
2017-12-15 16:05 Kunda1 Resolution open => unable to reproduce
2017-12-15 16:05 Kunda1 Note Added: 0010605
2017-12-15 16:05 Kunda1 Tag Detached: #tobeclosed
