| 0003110 | Sketcher | Feature | public | 2017-07-01 08:45 | 2021-02-06 05:55 |
| Reporter | normandc | Assigned To | abdullah | ||
| Summary | 0003110: Sketcher: add support of relevant constraints to B-splines | ||||
| Description | The current implementation of B-splines only support constraints on the B-spline vertices. It would be useful to use other constraints as well (point on object, tangent, perpendicular on the curve). | ||||
| Tags | b-splines, constraints | ||||
Back-link to relevant forum topic https://forum.freecad.org/viewtopic.php?f=10&t=28896 Can this be broken down into two parts? (1) BSpline is immutable and the other simpler geometry is forced to conform to it -- eg lines are forced equal length or forced perpendicular at point of intersection while the BSpline remains constant. (2) BSpline can be fully effected and changed by the constraints. I am looking to use the Length Equality between line and BSpline, which should be the easiest thing, it has to measure it and then apply it. |
This ticket has been migrated to GitHub as issue 5716. |
| 2017-07-01 08:45 | normandc | New Issue | |
| 2017-07-01 08:45 | normandc | Status | new => assigned |
| 2017-07-01 08:45 | normandc | Assigned To | => abdullah |
| 2017-07-01 11:02 | Kunda1 | Tag Attached: bugtracker | |
| 2017-07-01 11:02 | Kunda1 | Tag Attached: constraints | |
| 2017-07-01 11:03 | Kunda1 | Tag Detached: bugtracker | |
| 2017-07-01 11:03 | Kunda1 | Tag Attached: b-splines | |
| 2018-10-06 15:11 | abdullah | Target Version | => 0.19 |
| 2018-11-29 11:14 | JulianTodd | Note Added: 0012229 | |
| 2021-02-06 05:55 | abdullah | Target Version | => 0.20 |
