| 0003117 | PartDesign | Bug | public | 2017-07-08 00:22 | 2017-08-13 15:25 |
| Reporter | vectro | Assigned To | |||
| Platform | Linux | OS | Ubuntu | OS Version | 16.04.2 |
| Summary | 0003117: PartDesign Pocket yields non-manifold shape | ||||
| Description | See attached file. The Pocket is non-manifold with intersecting and missing edges. | ||||
| Steps To Reproduce | Load attached file. Deleting Pocket and Sketch002, the issue still occurs. | ||||
| Additional Information | OS: Ubuntu 16.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.11509 (Git) Build type: None Branch: master Hash: fdedf8fb4d36043145e8498244177aae16c806a5 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 | ||||
@vectro thanks for reporting. In general we recommend running issues through the forum first so the community can determine if said issue is in fact a bug. @normandc do you mind having a look at this? |
Odd, I didn't get an email notification. Inexplicably, the real problem starts with Pad; Part Check Geometry report it as invalid with "BOPAlgo SelfIntersect" and "BOPAlgo TooSmallEdge" errors. (RunBOPCheck must be set to true in parameters) Forcing a recompute of the model (right-click on the document label "3117" in the Model tree and select "Mark to recompute" then refresh the document (CTRL + R) fixes the issue for me. Since it seems impossible to me to find out how the file got that way, and since a recompute fixes the model, I would suggest closing this report as "no change required". I also agree this should have been discussed on the forum first. Tested on OS: Ubuntu 16.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.11509 (Git) Build type: None Branch: master Hash: fdedf8fb4d36043145e8498244177aae16c806a5 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 |
@vectro I'm marking this as resolved unless you can't reproduce workaround. Please respond nevertheless. Thanks NormandC! |
@vectro I'm closing this ticket as 'no change required' since we've heard no response and information from you and workaround has been provided. Closing. |
| 2017-07-08 00:22 | vectro | New Issue | |
| 2017-07-08 00:23 | vectro | File Added: 3117.fcstd | |
| 2017-07-08 11:13 | Kunda1 | Note Added: 0009676 | |
| 2017-07-08 11:13 | Kunda1 | Note Edited: 0009676 | |
| 2017-07-08 11:41 | Kunda1 | Status | new => acknowledged |
| 2017-07-09 20:37 | normandc | Note Added: 0009698 | |
| 2017-07-10 12:50 | Kunda1 | Status | acknowledged => resolved |
| 2017-07-10 12:50 | Kunda1 | Resolution | open => no change required |
| 2017-07-10 12:50 | Kunda1 | Note Added: 0009702 | |
| 2017-08-13 15:25 | Kunda1 | Status | resolved => closed |
| 2017-08-13 15:25 | Kunda1 | Note Added: 0009902 |
