| 0003122 | PartDesign | Bug | public | 2017-07-08 21:22 | 2018-08-26 15:21 |
| Reporter | CharlieMAC | Assigned To | wmayer | ||
| Summary | 0003122: FC 0.17 crashes when a sketched located outside a body object | ||||
| Description | I'm trying to pad a Sketch created with the old part design within FreeCAD 0.17 and I'm doing the following steps: First, I launch FreeCAD 0.17 then open a file containing the Sketch created with 0.16, I create a new file and create a new body using the new part design, later I copy the sketch created with 0.16 and I paste it under the body I just created. I click on pad, and then select "make independant copy (recommended)". When clicking "ok" FreeCAD just crashes. | ||||
| Steps To Reproduce | 1.- Create a simple Sketch in 0.16 and copy it. 2.- Create a new body using the new part design workbench in 0.17 3.- Paste the copied sketch within the body. 4.- Click on pad. 5.- Click on "Make independent copy (recommended)". Note: It's actually not necessary to create the sketch using 0.16. Creating the Sketch in 0.17 and moving it outside the body object is sufficient to reproduce the crash. | ||||
| Additional Information | GDB Information about Crash:
FreeCADs information: OS: Debian GNU/Linux 9.0 (stretch) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.11509 (Git) Build type: Release Branch: master Hash: fdedf8fb4d36043145e8498244177aae16c806a5 Python version: 2.7.13 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
Forum's discussion: https://forum.freecadweb.org/viewtopic.php?f=3&t=23310 |
@yorik can you weigh in on why this crash occurs ? |
Better to add the PartDesign boys :) |
@kkremitzki can you weigh in on this? |
https://github.com/FreeCAD/FreeCAD/commit/7cfc084e476fcf6c189a9d41596d68fd265d71d9 |
| 2017-07-08 21:22 | CharlieMAC | New Issue | |
| 2017-07-08 21:26 | CharlieMAC | Note Added: 0009692 | |
| 2017-07-12 12:24 | Kunda1 | Note Added: 0009734 | |
| 2017-07-12 12:24 | Kunda1 | Tag Attached: #pending | |
| 2017-07-12 15:47 | yorik | Note Added: 0009741 | |
| 2017-07-12 16:46 | Kunda1 | Project | FreeCAD => PartDesign |
| 2017-07-15 11:01 | Kunda1 | Note Added: 0009761 | |
| 2017-07-15 11:02 | Kunda1 | Note Edited: 0009761 | |
| 2017-07-16 14:57 | wmayer | Assigned To | => wmayer |
| 2017-07-16 14:57 | wmayer | Status | new => closed |
| 2017-07-16 14:57 | wmayer | Resolution | open => fixed |
| 2017-07-16 14:57 | wmayer | Fixed in Version | => 0.17 |
| 2017-07-16 14:57 | wmayer | Note Added: 0009765 | |
| 2017-07-18 18:17 | wmayer | Changeset attached | => FreeCAD master 7cfc084e |
| 2017-07-18 18:17 | wmayer | Note Added: 0009776 | |
| 2018-08-26 15:21 | Kunda1 | Tag Detached: #pending |
