| 0003124 | Draft | Bug | public | 2017-07-09 11:30 | 2017-10-19 11:37 |
| Reporter | Ihateusername | Assigned To | yorik | ||
| Platform | Macbookair(very Old) | OS | Windows 7 | OS Version | Pro |
| Summary | 0003124: Can't open DWG File | ||||
| Description | When I try to open a DWG file, it fails because importDwg.py have some problem on line 32. I already install DWG support (teigha_file_converter) | ||||
| Steps To Reproduce | 1. install freecad 2. download teigha_file_converter 3. open a dwg file | ||||
| Tags | Draft, DWG, python | ||||
in 0.17 , looks like it is half working, but I can't see anything |
Please Always post your full FreeCAD versions you've tested on. Especially 0.17 since it intensely developed and recently had some updates to DWG. |
0.17.11528 |
@Ihateusername Full FreeCAD version = Help > About FreeCAD > Copy to clipboard |
Opened a forum thread (per the guidelines): https://forum.freecadweb.org/viewtopic.php?f=8&t=23375 |
@Ihateusername, can you upload the file you were trying to import? I don't have any .dwg files to test at the moment. Does it happen with every .dwg, or only specific files? |
@Ihateusername please follow up 0003124:0009725 |
There can be many reasons why dwg import fails, if there is a message error appearing, please paste it here entirely (open View -> Panels -> Report view to get the whole message) also as peterl94 suggests there can be problems inside the dwg file (please upload so we can have a look), also try to avoid file paths with non-ASCII (accented, etc) characters, as teigha seems to not swallow them right... |
@Ihateusername please respond to yorik in 0003124:0009778 |
@Ihateusername ping |
Closing as no response from OP. |
| 2017-07-09 11:30 | Ihateusername | New Issue | |
| 2017-07-09 11:30 | Ihateusername | Tag Attached: Draft | |
| 2017-07-09 11:30 | Ihateusername | Tag Attached: python | |
| 2017-07-09 12:12 | Ihateusername | Note Added: 0009695 | |
| 2017-07-10 12:46 | Kunda1 | Note Added: 0009701 | |
| 2017-07-10 12:46 | Kunda1 | Status | new => feedback |
| 2017-07-11 11:00 | Ihateusername | Note Added: 0009708 | |
| 2017-07-11 11:00 | Ihateusername | Status | feedback => new |
| 2017-07-11 11:10 | Kunda1 | Tag Attached: DWG | |
| 2017-07-11 11:11 | Kunda1 | Tag Attached: #post-to-forum | |
| 2017-07-11 11:12 | Kunda1 | Note Added: 0009712 | |
| 2017-07-11 11:16 | Kunda1 | Note Added: 0009713 | |
| 2017-07-11 11:17 | Kunda1 | Tag Detached: #post-to-forum | |
| 2017-07-12 01:35 | peterl94 | Note Added: 0009725 | |
| 2017-07-15 10:53 | Kunda1 | Status | new => feedback |
| 2017-07-15 10:53 | Kunda1 | Note Added: 0009759 | |
| 2017-07-19 01:00 | yorik | Note Added: 0009778 | |
| 2017-07-19 01:04 | yorik | Assigned To | => yorik |
| 2017-07-19 01:04 | yorik | Status | feedback => assigned |
| 2017-08-14 20:23 | Kunda1 | Status | assigned => feedback |
| 2017-08-14 20:23 | Kunda1 | Note Added: 0009935 | |
| 2017-09-22 19:46 | Kunda1 | Note Added: 0010158 | |
| 2017-09-22 19:50 | Kunda1 | Tag Attached: #tobeclosed | |
| 2017-09-25 11:12 | Kunda1 | Status | feedback => closed |
| 2017-09-25 11:12 | Kunda1 | Resolution | open => unable to reproduce |
| 2017-09-25 11:12 | Kunda1 | Note Added: 0010187 | |
| 2017-10-19 11:37 | Kunda1 | Tag Detached: #tobeclosed |
