| 0003129 | Path | Bug | public | 2017-07-16 15:59 | 2018-02-08 19:01 |
| Reporter | GeneFC | Assigned To | sliptonic | ||
| Platform | Windows 7 | OS | Windows | OS Version | 7 |
| Summary | 0003129: Path - Bug in Start Point when one coordinate is zero | ||||
| Description | The Path workbench provides an option to select a specific starting point for a machining path, overriding the automatically chosen starting point. This allows for special cases that may be required by certain machines and certain workpieces. The selected start points works correctly with one important exception. If one of the requested coordinates (for example X-position or Y-position) is exactly zero that coordinate is completely ignored when creating the internal path code and the resulting gcode. If the coordinate is very slightly different from zero, say 0.00001 mm, then the operation works correctly. | ||||
| Steps To Reproduce | * Create FreeCAD model, Path Job, Path Tools, etc in the usual manner. * Create a path, such as a Pocket or Profile, so that the final position of the tool is not left at (0,0). For instance, the tool ends up at (10,10) at the completion of the path. * Create another path, such as a Profile, with a requested start point of (20,0), for example. * The actual start point in the resulting gcode will be (20,10) instead of the requested (20,0). * If the requested start point is (20,0.00001) then the actual start point will be correctly set as (20,0.00001). | ||||
| Additional Information | OS: Windows 7 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.11576 (Git) Build type: Release Branch: master Hash: 828793f8f49d67e502b7456c3b3d14afef4c7eaa Python version: 2.7.8 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 Forum discussion at: https://forum.freecadweb.org/viewtopic.php?f=15&t=23451 | ||||
| Tags | Path | ||||
@realthunder, can you weigh in on this? |
Just submit a PR for this. This reported behavior is actually intentional. But it does disallow the user to specify the origin as the start position. With the above PR, the behavior of Path.fromShapes is changed such that it will respect any start position you pass in. If no start parameter is given, only then will it auto select one. |
@GeneFC, The PR has been merged. Can you please verify a fix and report back so this can be closed? |
No response. Assuming the PR resolved the issue. Will reopen if OP reports differently |
| 2017-07-16 15:59 | GeneFC | New Issue | |
| 2017-07-16 15:59 | GeneFC | Tag Attached: Path | |
| 2018-01-22 06:22 | sliptonic | Note Added: 0010810 | |
| 2018-01-22 08:46 | realthunder | Note Added: 0010813 | |
| 2018-01-22 08:47 | realthunder | Note Edited: 0010813 | |
| 2018-01-22 08:48 | realthunder | Note Edited: 0010813 | |
| 2018-01-26 23:16 | sliptonic | Note Added: 0010872 | |
| 2018-01-27 13:19 | Kunda1 | Tag Attached: #tobeclosed | |
| 2018-02-08 15:35 | sliptonic | Assigned To | => sliptonic |
| 2018-02-08 15:35 | sliptonic | Status | new => closed |
| 2018-02-08 15:35 | sliptonic | Resolution | open => fixed |
| 2018-02-08 15:35 | sliptonic | Fixed in Version | => 0.17 |
| 2018-02-08 15:35 | sliptonic | Note Added: 0010936 | |
| 2018-02-08 19:01 | Kunda1 | Tag Detached: #tobeclosed |
