0003133FreeCADBugpublic2017-07-26 10:59
Reporterplgarcia Assigned To
Product Version0.16
Summary0003133: Fusion of two adjacent cones fails
DescriptionFusion of multiple parallel cones fails if one of their bases is on the same plane.
Note from NormandC: this description does not detail the true situation.
Original French text:
La fusion de plusieurs cones parallèles ne fonctionne pas, si l'une de de leurs bases se trouve dans le même plan.
Steps To ReproduceIn the attached example, the two cones have the same length.
if one of the cones is moved in z direction, the fusion works.
Dans l'exemple donné, les 2 cone ont la même longueur.
Si l'on bouge l'un des cones sur l'axe z la fusion fonctionne.
plgarcia
2017-07-22 19:19
reporter
bugCone.FCStd (199,021 bytes)
plgarcia
2017-07-24 20:38
reporter   ~0009811
An error whith the file provided.
Here is the minimum example I wanted to provide.
bugCone1.FCStd (4,728 bytes)
2017-07-24 21:26
administrator   ~0009814
@plgarcia please open a forum thread and link both ticket and thread to each other. Remember, 0.16 is thousands commits behind 0.17dev, and we ask folks to open forum threads to check if in fact their issues merit opening tickets in the first place.
plgarcia
2017-07-25 17:34
reporter   ~0009820
Testing with 0.17 seems to become far more complex than I want to invest on this topic as there is no msi package for windows.
I provide a minimal example: 2 identical cones and a fusion of these 2 cones that is not working. If you change the Z position of one of the cone almost whatever value (add a micron to it and make it -21.001), and then the fusion works. The fusion works as long as both of the ends of one cone are not in the same plan as one of the end of the second cone.
Some values to make more tests:
HC1 = Height cone 1
HC2 = Height cone 2
ZP1 = Z pos cone 1
ZP2 = Z pos cone 2
HC1 ZP1 HC2 ZP2
20 -21 20 -21 Failed end 1 cone 1 in the same plane as end 1 of cone 2, the same for ends 2
20 -21 19 -21 Failed end 1 cone 1 in the same plane as end 1 of cone 2
20 -21 19 -20 Failed end 2 cone 1 in the same plane as end 2 of cone 2
20 -21 20 -20 Works
I think this information suffices to investigate and correct the problem encountered.
You can also note that the icon link to an object with errors is not restored when opening the saved file.
Sorry not to do more.
2017-07-25 21:27
administrator   ~0009821
@normandc care to weigh in ?
normandc
2017-07-26 01:11
manager   ~0009822
In bugCone1.FCStd, the document needs to be recomputed for the fusion to fail.
The reason why it fails is simple: the two cone bases are tangent to each other and only meet on one infinitesimal point. This is an invalid condition because it would create a non-manifold solid.
Therefore this bug is invalid and should be closed as such.
2017-07-26 02:01
administrator   ~0009823
@normandc thanks
@plgarcia thanks for submitting the bug. Please follow the recommended guidelines to first post and verify the issue on the forums.
2017-07-26 10:56
administrator   ~0009825
Closing
2017-07-22 19:19 plgarcia New Issue
2017-07-22 19:19 plgarcia File Added: bugCone.FCStd
2017-07-24 20:38 plgarcia File Added: bugCone1.FCStd
2017-07-24 20:38 plgarcia Note Added: 0009811
2017-07-24 20:39 plgarcia Note Edited: 0009811
2017-07-24 21:26 Kunda1 Note Added: 0009814
2017-07-24 21:26 Kunda1 Status new => feedback
2017-07-24 21:26 Kunda1 Tag Attached: #post-to-forum
2017-07-25 17:34 plgarcia Note Added: 0009820
2017-07-25 17:34 plgarcia Status feedback => new
2017-07-25 21:27 Kunda1 Note Added: 0009821
2017-07-26 01:11 normandc Note Added: 0009822
2017-07-26 01:14 normandc Summary Fusion de cosnes, cone fusion => Fusion of two adjacent cones fails
2017-07-26 01:14 normandc Description Updated
2017-07-26 01:14 normandc Steps to Reproduce Updated
2017-07-26 02:01 Kunda1 Note Added: 0009823
2017-07-26 02:01 Kunda1 Tag Attached: #tobeclosed
2017-07-26 02:01 Kunda1 Tag Detached: #post-to-forum
2017-07-26 10:56 Kunda1 Status new => closed
2017-07-26 10:56 Kunda1 Resolution open => no change required
2017-07-26 10:56 Kunda1 Note Added: 0009825
2017-07-26 10:59 Kunda1 Tag Detached: #tobeclosed
