| 0003137 | FreeCAD | Bug | public | 2017-07-24 06:57 | 2017-07-24 14:58 |
| Reporter | m42kus | Assigned To | wmayer | ||
| Summary | 0003137: Unit UserString wrong | ||||
| Description |
I think the problem here is obvious: mm*kg/(s^3*K) is not the same as W/mm/K (= kg*m^2/(mm*s^3)) | ||||
| Additional Information | OS: Linux Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.11479 +72 (Git) Build type: Debug Branch: exec_framework Hash: 10c18f28f8bfeba64abc83f4c3a45543ccb82643 Python version: 2.7.13 Qt version: 5.9.0 Coin version: 3.1.3 OCC version: 7.1.0 | ||||
| Tags | units | ||||
Related forum thread: https://forum.freecad.org/viewtopic.php?f=18&t=22576&p=183698#p183698 |
Am I right that the first and third expressions are correct? It's on the second one that is wrong which should be:
Yes, that is correct. |
Although I would prefere "237.0 mW/mm/K". |
This commit introduces the bug: https://github.com/FreeCAD/FreeCAD/commit/f9c5661096ade266dd2981afe05ae47043959d61 |
This fixes the issue: https://github.com/FreeCAD/FreeCAD/commit/7ab8a9996d47e8858e9be6ddaf07eaf5e5ab7378 And I have found a good way to perform consistency checks. If you have a certain quantity q then q.UserString must be equal to Quantity(q.UserString).UserString. Now for all the more difficult expressions the tests can be added to testSelfConsistency. This way we can also verify that the parser can handle the output string. |
| 2017-07-24 06:57 | m42kus | New Issue | |
| 2017-07-24 06:59 | m42kus | Tag Attached: units | |
| 2017-07-24 10:25 | Kunda1 | Note Added: 0009804 | |
| 2017-07-24 11:36 | wmayer | Note Added: 0009805 | |
| 2017-07-24 11:36 | wmayer | Note Edited: 0009805 | |
| 2017-07-24 11:53 | m42kus | Note Added: 0009806 | |
| 2017-07-24 12:06 | m42kus | Note Added: 0009807 | |
| 2017-07-24 12:29 | wmayer | Note Added: 0009808 | |
| 2017-07-24 14:58 | wmayer | Assigned To | => wmayer |
| 2017-07-24 14:58 | wmayer | Status | new => closed |
| 2017-07-24 14:58 | wmayer | Resolution | open => fixed |
| 2017-07-24 14:58 | wmayer | Fixed in Version | => 0.17 |
| 2017-07-24 14:58 | wmayer | Note Added: 0009809 |
