| 0003139 | Draft | Bug | public | 2017-07-26 06:23 | 2018-01-11 16:02 |
| Reporter | Uname3D | Assigned To | yorik | ||
| Platform | freecad 64 bits 0.17.11616 (Git) | OS | Linux 64 | OS Version | Ubuntu 16.04LTS |
| Summary | 0003139: Draft ShapeString tool doesn't have utf-8 support | ||||
| Description | Hi, I have a problem with freecad in draft mode with the shapestring tool. In french version, when I have to type the shapestring in the subwindow "Texte surfacique", i.e. "text on a surface". I can see a bug, it requires a "Chaîne" (french for string) but it shows something like "Cha®ne" (accent_maj_a + registered_sign) So it is obvious that there is a unicode/latin problem. Even worse, I cannot type a string with accents. And, I cannot use a .ttf file in a subdirectory with accents. There are no other problem with UTF-8 in freecad except here. | ||||
| Steps To Reproduce | Set your OS locals to french for instance. Open freecad. Open a new project. Go to draft. Use the shapestring tool. Choose any coordinate. Then the bug appears. Then if you type an accentuated string like "élo", it will show you a square in spite of the "é" char. If you search the .ttf file in a directory which contains "é" it will not validate the path. | ||||
| Additional Information | OS: Ubuntu 16.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.11616 (Git) Build type: None Branch: master Hash: aba4338808178b508f3170237f205e0066a5b437 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 Locale: French/France (fr_FR) | ||||
| Tags | font, locale, shapestring, unicode | ||||
| related to | 0001947 | closed | wandererfan | FreeCAD | Non-ASCII Character in ShapeString FontFile Path |
@NormandC can you replicate this ? |
The tool is not called "String", it's called ShapeString!!! Please fix the summary and description. I confirm that in the GUI, the text labels are not translated correctly, see file attached. Although the ShapeString object is correctly created for me with accented letters (second capture). I do not have font files located in a path with accented letters. I believe that on Linux that goes against conventions regarding the file system. OS: Ubuntu 16.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.11659 (Git) Build type: None Branch: master Hash: 37258b918def361c8f80b3e82a6a420904af1229 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 Locale: French/Canada (fr_CA) |
fixed summary and description. |
Sorry for the wrong name it is ShapeString indeed. Accented letters in the file system is not conventional. But in french ubuntu 16.04, the "/home/$USER/Download" path is renamed "/home/$USER/Téléchargement". This is where the fonts you just downloaded are located by default. Yes I can move the file or rename the path without accentuated directories. I didn't, I like utf-8 accented paths. May I can have some information about your test ? I'd try to reproduce it with the same font and see if it is a font file related problem. Thanks for the fast answer and for your time NormandC ! |
@Uname3D please open a forum thread and bi-directionally link this ticket and the thread together. CC @normandc |
@normandc ping |
Any downloaded file is saved there by default unless you specify the path, but it does not mean that they should stay there. Downloaded font files should always be moved to /home/$USER/.fonts so they are recognized by the system. For completeness, here is the error message in the Report View when selecting a font located in a path with accented letters:
But again, on Ubuntu, fonts should either go to the system folder (/usr/share/fonts) or the dedicated ~/.fonts user folder. |
@normandc Is this a dupe of 0001947 ? |
Indeed the shapestring tool font path is not encoded correctly. I'll take care of it |
FreeCAD Pull Request 1149 |
https://github.com/FreeCAD/FreeCAD/commit/750661de3503e5cca3a1d7ae5614340d4948d9df |
| 2017-07-26 06:23 | Uname3D | New Issue | |
| 2017-07-26 11:03 | Kunda1 | Tag Attached: locale | |
| 2017-07-26 17:20 | Kunda1 | Note Added: 0009828 | |
| 2017-07-27 00:49 | normandc | File Added: FC017_Sraft_ShapeString_French_02.png | |
| 2017-07-27 00:49 | normandc | File Added: FC017_Sraft_ShapeString_French_01.png | |
| 2017-07-27 00:49 | normandc | Note Added: 0009832 | |
| 2017-07-27 00:49 | normandc | Note Edited: 0009832 | |
| 2017-07-27 01:03 | Kunda1 | Summary | Draft string tool no utf-8 support => Draft ShapeString tool doesn't have utf-8 support |
| 2017-07-27 01:03 | Kunda1 | Description Updated | |
| 2017-07-27 01:03 | Kunda1 | Steps to Reproduce Updated | |
| 2017-07-27 01:04 | Kunda1 | Note Added: 0009833 | |
| 2017-07-27 04:02 | Uname3D | Note Added: 0009835 | |
| 2017-08-14 00:17 | Kunda1 | Note Added: 0009923 | |
| 2017-08-14 00:18 | Kunda1 | Status | new => feedback |
| 2017-09-13 12:22 | Kunda1 | Note Added: 0010114 | |
| 2017-09-13 12:24 | Kunda1 | Tag Attached: #post-to-forum | |
| 2017-09-13 14:09 | normandc | Note Added: 0010116 | |
| 2017-09-13 14:11 | normandc | Note Edited: 0010116 | |
| 2017-09-30 11:38 | Kunda1 | Tag Attached: shapestring | |
| 2017-09-30 11:38 | Kunda1 | Tag Attached: font | |
| 2017-09-30 11:39 | Kunda1 | Tag Attached: unicode | |
| 2017-09-30 11:41 | Kunda1 | Note Added: 0010217 | |
| 2017-09-30 11:41 | Kunda1 | Relationship added | related to 0001947 |
| 2017-10-27 19:56 | yorik | Note Added: 0010362 | |
| 2017-10-27 19:56 | yorik | Assigned To | => yorik |
| 2017-10-27 19:56 | yorik | Status | feedback => assigned |
| 2017-12-07 04:16 | Kunda1 | Tag Detached: #post-to-forum | |
| 2017-12-07 04:17 | Kunda1 | Note Added: 0010528 | |
| 2017-12-07 09:44 | wmayer | Note Added: 0010536 | |
| 2018-01-11 16:02 | yorik | Status | assigned => closed |
| 2018-01-11 16:02 | yorik | Resolution | open => fixed |
