| 0003149 | PartDesign | Bug | public | 2017-08-07 05:43 | 2021-02-06 06:43 |
| Reporter | ickby | Assigned To | ickby | ||
| Summary | 0003149: Duplicate body creates a mess | ||||
| Description | https://forum.freecad.org/viewtopic.php?f=3&t=15949 While experimenting on how Part-o-magic withstands object duplication, I found a bug in PartDesign. 1. New Part, New body 2. New sketch. Draw rectangle. Close. 3. Pad the sketch. 4. Select Body and menu Edit->Duplicate... When asked whether to duplicate dependencies, click Yes. The body is duplicated. But. Problem No.1. Body is not added to active Part. OK, that can be fixed manually... Problem No.2. and all looks fine, until one dives into dependency graph. There, a total mess can be seen. Graph problem No.1: Duplicates of Sketch and Pad were added to original body, as well as to the copy of body. Graph problem No.2: Pad001 references Pad (that is, gets fused to it). | ||||
| related to | 0003768 | closed | FreeCAD | Losing Origin and/or Geofeatures |
With the implementation of scoped links the issue has been fixed. There is only a minor issue left because when duplicating the body this error comes up:
The question is if it can be avoided to raise the error message. |
IMO the bug is still very big. a) when I duplicate a body, a message pops up, if FreeCAD should duplicate dependencies. If I answer No, the contents of the body is not duplicated; errors in report view, and the new Body shares an Origin object with the old body. This is a mess. b) the original Body (which I deactivated before copying) got activated back. I expect that the active object should not change. c) the action of the "copy dependencies" question applies the old logic of isolated PartDesign of 0.16, which partly explains point a). What I expect: "No" = body should be copied with all its contents duplicated, but none of the objects outside of the body should be duplicated. "Yes" - same, but with all dependencies not in body too (e.g. master sketches). This might get really tricky if for example there is a shapebinder of a partdesign feature from another body. |
I can verify, that this bug is still present in some form in the 0.19 daily build from today (May 9th 2019). 1. Please open "Duplicate_Part.FCStd" - This design has one master spreadheet to parameterize all parts. 2. Select Part "Rahmen" 3. Edit -> Duplicate Selection 4a. Answer "No" to "copy dependencies" - In this case only the Part itself without any content is duplicated. To me, this is an unneeded state and I fully agree with DeepSOIC's suggestion c) to solve this. 4b. Answer "Yes" to "copy dependencies" - The Part and its contained objects are duplicated, BUT the duplicate references the original spreadsheet: Reference in Rahmen001 -> Rahmen_vorne001 -> Position.x now points to "Spreadsheet.w_rahmen" which is the original Spreadsheet. This should be "param001" (or "Spreadsheet001" if neccessary). Similar to Rahmen001 -> Rahmen_vorne001 -> Length that points to "param.h_nut" which is also the original spreadsheet In any case, my suggestions are - The original part should stay unaltered - Independent of saying "Yes" or "No" to copy dependencies, I expect that all objects within the selection (also recursively) appear in the resulting object tree. Anything else is not a duplicate. - If saying "No" only objects within the selection tree should be duplicated (but still recursively). That would mean, that the duplicate references the master spreadsheet exactly the same way like the original. - If saying "Yes" also dependecies outside the selection tree (e.g. master spreadsheet) should be copied and correctly referenced by the duplicate objects (again, also recursively through the tree) Many thanks for bringing this great tool to us! Best Regards, Stephan OS: Linux Mint 19.1 (X-Cinnamon/cinnamon) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19. Build type: Release Python version: 3.6.7 Qt version: 5.9.5 Coin version: 4.0.0a OCC version: 7.3.0 Locale: German/Germany (de_DE) |
Hi! When I mirror a pad,the body of the part becomes empty. When I delete a copy, I cannot return the pad back to the body. Error message is: Object can only be in a single GeoFeatureGroup Sometimes when creating a sketch, the message drawing during migration appears, and when choosing automatic, an empty body is created, and everything settles as before. When I make a mirror copy of the body - everything is fine. But so far I have understood it, I made a lot of mistakes in the drawings. Now, in order to change something, I need to make copies of the sketch and create the parts again. [url=https://youtu.be/aRHqHNmfftc ]youtube screen record[/url] Full console output
There is a new "copy dialog" in FC 0.19. If all dependencies are selected, the body is copied. It is not copied within the part (one has to move it in manually), but the dependency graph shows an independent object. The error message Werner indicates is still there. |
This ticket has been migrated to GitHub as issue 5720. |
| 2017-08-07 05:43 | ickby | New Issue | |
| 2017-08-07 05:43 | ickby | Status | new => assigned |
| 2017-08-07 05:43 | ickby | Assigned To | => ickby |
| 2017-10-01 21:01 | wmayer | Note Added: 0010232 | |
| 2017-10-01 21:07 | Kunda1 | Description Updated | |
| 2017-10-01 21:08 | Kunda1 | Description Updated | |
| 2017-11-20 10:29 | DeepSOIC | Note Added: 0010436 | |
| 2018-01-30 17:55 | wmayer | Target Version | 0.17 => 0.18 |
| 2019-01-13 17:03 | wmayer | Relationship added | related to 0003768 |
| 2019-02-23 20:22 | wmayer | Target Version | 0.18 => 0.19 |
| 2019-05-09 18:30 | Bicycle Repair Man | File Added: Duplicate_Part.FCStd | |
| 2019-05-09 18:30 | Bicycle Repair Man | Note Added: 0013096 | |
| 2019-05-09 18:33 | Bicycle Repair Man | Note Edited: 0013096 | |
| 2019-05-09 18:35 | Bicycle Repair Man | Note Edited: 0013096 | |
| 2020-01-06 06:19 | SimonLitt | Note Added: 0013985 | |
| 2020-07-08 15:07 | abdullah | Note Added: 0014639 | |
