| 0003156 | PartDesign | Bug | public | 2017-08-10 21:52 | 2017-08-17 17:55 |
| Reporter | FrViPofm | Assigned To | |||
| Summary | 0003156: Bad dependency in PartDesign Revolution | ||||
| Description | When doing several revolution of different sketches in partDesing, the result is the first made. | ||||
| Steps To Reproduce | 1. New document 2. New body 3. New sketch "Small" (e.g. XY plane) 4. Draw a circle ( r10 mm) at 20 mm from Y 6. Close the sketch "Small" 7. make a revolution from this sketch The result is a torus 8. Unselect the sketch 9. New sketch "Big" (e.g. XZ plane) 10. Draw a circle ( r20 ) at 60 mm from Z 11. Close "Big" 12. Make a revolution from this sketch (with "vertical axis" or "Z axix") The result should be a second torus. But I get the same first torus. 13. Delete "Revolution" from "Small" The result is as expected for the "Big" torus. | ||||
| Additional Information | The dependency graph shows that the second revolution depends on the first, that would not be. The bug has been found during a try of the tuto : https://www.youtube.com/watch?v=yo79c2gm0pc The test as been made several times. The problem has not been found on FC 0.16. Thanks for your work ! ********** OS: Ubuntu 16.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.11740 (Git)/Daily-PPA Build type: None Branch: master Hash: 6b05302c2e70f191a2a5787f55c5b549155b9824 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 Locale: French/France (fr_FR) | ||||
| Tags | Part Design | ||||
@normandc can you weigh in on this? |
Sorry... I my previous post, I have copied the FreeCAD info from FreeCAD 0.17. but it gave me the infos of the 0.16 version installed. I had not seen the mistake. The trying version, where I'm testing today the bug is 0.17.11751 (pub date 2017/08/10). So,there is another minor bug: when copying the infos of FreeCAD daily, I get the info of FreeCad stable. Some more test... At step 8 ( in the above test) I see that "Revolution" is still displaied in bold in the left pannel. Kind of selection that could explain the dependency. And I can't unselect it. So before the 9th step, I create a basic cube (in Part) to have it selected. It doesn't change nothing. But... If I create a second body for the second sketch and the second torus, it works as expected. |
@FrViPofm please do us a favor a post your ticket and create a discussion (per the bugtracker guidelines) on the forum to discuss all these issue. When you post, please remember to reference the ticket from the forum thread and vice-a-versa from this ticket to the thread. Thanks! |
@Kunda1 Done. https://forum.freecadweb.org/viewtopic.php?t=23889 |
@ickby what do you recommend we do with this ticket based on your comment in the forums? |
No bug because it's the aim of the body feature that the result is always a *single* solid. If you want something similar as in v0.16 you must create a Part object first and then inside this create two body features with the two sketches. |
Closing ticket as 'no change required. Please continue discussion in the forum thread. |
| 2017-08-10 21:52 | FrViPofm | New Issue | |
| 2017-08-10 21:52 | FrViPofm | File Added: Torus-test.fcstd | |
| 2017-08-10 21:52 | FrViPofm | File Added: Torus-test.png | |
| 2017-08-10 21:52 | FrViPofm | Tag Attached: Part Design | |
| 2017-08-14 00:15 | Kunda1 | Note Added: 0009922 | |
| 2017-08-14 00:15 | Kunda1 | Summary | Bad dependency in PartDesing Revolution => Bad dependency in PartDesign Revolution |
| 2017-08-14 00:15 | Kunda1 | Additional Information Updated | |
| 2017-08-14 09:46 | FrViPofm | File Added: Torus-test2.fcstd | |
| 2017-08-14 09:46 | FrViPofm | Note Added: 0009927 | |
| 2017-08-14 11:31 | Kunda1 | Note Added: 0009928 | |
| 2017-08-14 11:32 | Kunda1 | Tag Attached: #post-to-forum | |
| 2017-08-14 12:14 | FrViPofm | Note Added: 0009929 | |
| 2017-08-14 14:43 | Kunda1 | Tag Detached: #post-to-forum | |
| 2017-08-14 14:43 | Kunda1 | Note Added: 0009930 | |
| 2017-08-17 13:23 | wmayer | Note Added: 0009942 | |
| 2017-08-17 17:55 | Kunda1 | Status | new => closed |
| 2017-08-17 17:55 | Kunda1 | Resolution | open => no change required |
| 2017-08-17 17:55 | Kunda1 | Note Added: 0009943 |
