| 0003163 | Arch | Bug | public | 2017-08-17 19:35 | 2018-01-11 16:13 |
| Reporter | HoWil | Assigned To | yorik | ||
| Summary | 0003163: Draft Draft2Sketch does drop lines if there is a T-crossing of three lines | ||||
| Description | Draft Draft2Sketch does drop lines if there is a Y-crossing of three or more lines in a single point as shown in the first row of the attached image. There the right line going into the same point as the left and bottom line is dropped when converted to draft-lines or wires. The white lines are the lines drawn in sketcher and the black lines are the results after the conversion. | ||||
| Steps To Reproduce | Draw three lines in sketcher where one end of each line is connected to the others to form a T or Y- junction as shown in the first row of the attached image. Convert the drawn lines with the Draft Draft2Sketch tool. Some lines are missing as Draft- wires or d-lines. | ||||
| Additional Information | This affects also the use of sketches with junctions for the wall tool in Arch. | ||||
| Tags | Draft, Sketch | ||||
The lines from sketcher are better seen in this additional screenshot. |
Here is link to the related discussion in the forum https://forum.freecadweb.org/viewtopic.php?f=23&t=23932 |
I think it would be fairly easy to fix the problem of ArchWalls by using Part.getSortedClusters() instead of Part.__sortEdges__() ... However, given that this issue is tagged "Draft" and "Sketch", I'm unsure if this is the desired solution. Do you think there is a problem in the Sketcher? I guess it could be argued that three edges of a wire should never share a vertex, but surprisingly I didn't find that spelled out anywhere in FreeCAD so far. OTOH basing ArchWalls on wires instead of clustered edges has the downside that an edge might be shared by two wires. |
I don't think it'sn issue in the sketcher, rather a matter of deciding what we want to do in Draft/Arch. Your suggestion of using getSortedClusters() is very good, Sketch2Draft could produce several objects, and Arch Walls could handle Y-situations more gracefully. I'll implement it. |
Implemented in https://github.com/FreeCAD/FreeCAD/commit/e16c152da424a7e9b94f4f50e7b4ddd9f4a4d030 But there is still a minor problem to solve, for some reason splitter removal doesn't work in Arch Walls... |
The splitter removal issue is not related to this problem (happens in other cases as well), so this issue can be closed |
| 2017-08-17 19:35 | HoWil | New Issue | |
| 2017-08-17 19:35 | HoWil | Status | new => assigned |
| 2017-08-17 19:35 | HoWil | Assigned To | => yorik |
| 2017-08-17 19:35 | HoWil | File Added: Y- and T-junction problem of sketcher-draft-converter.png | |
| 2017-08-17 19:35 | HoWil | File Added: Y-junction_sketcher-draft-converter.fcstd | |
| 2017-08-17 19:35 | HoWil | Tag Attached: Draft | |
| 2017-08-17 19:35 | HoWil | Tag Attached: Sketch | |
| 2017-08-17 19:38 | HoWil | File Added: Screenshot from 2017-08-17 21-36-46.png | |
| 2017-08-17 19:38 | HoWil | Note Added: 0009945 | |
| 2017-08-17 19:46 | HoWil | Note Added: 0009946 | |
| 2017-10-27 14:03 | lambda | Note Added: 0010358 | |
| 2017-10-27 16:44 | yorik | Note Added: 0010359 | |
| 2017-10-27 18:43 | yorik | Note Added: 0010360 | |
| 2017-11-08 19:36 | Kunda1 | Changeset attached | => FreeCAD master e16c152d |
| 2018-01-11 16:13 | yorik | Note Added: 0010740 | |
| 2018-01-11 16:13 | yorik | Status | assigned => closed |
| 2018-01-11 16:13 | yorik | Resolution | open => fixed |
